Re: Dana 60
[Re: cdwmotorsports]
#2578629
11/15/18 02:43 AM
11/15/18 02:43 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Anything can fail, if you break a 60, go to a 70.....bearing sizes are the same, just a larger ring gear...pinion offset is the same as a 60 too.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Dana 60
[Re: dthemi]
#2578708
11/15/18 01:25 PM
11/15/18 01:25 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I think it's like a lot of things in racing. Back when the parts were stock based the Dana 60 reigned king but with aftermarket parts whatever is popular get's modified until it works.
Sheldon
Re: Dana 60
[Re: dthemi]
#2578713
11/15/18 01:36 PM
11/15/18 01:36 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Look under every PS car and tell us what you find. I've haven't seen a dana under one since the late 70's,but maybe they're missing the boat You won't find a ford 9 inch either. LOL
Re: Dana 60
#2578715
11/15/18 01:37 PM
11/15/18 01:37 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
We're all going about it wrong. An 8.75 is the best rear ever. It's just that no one ever sets them up correctly.
Re: Dana 60
[Re: an8sec70cuda]
#2578724
11/15/18 01:56 PM
11/15/18 01:56 PM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
We're all going about it wrong. An 8.75 is the best rear ever. It's just that no one ever sets them up correctly. Maybe ---- IDK. I will say look under Dave Dudeks car running in the F.A.S.T class and that's what he runs. He had a Dana under it when purchased but sold it and went to the 8 3/4. I run a Dana 60 running low 9's at 3450 lbs with no issues.
Re: Dana 60
#2578798
11/15/18 03:59 PM
11/15/18 03:59 PM
Posts: 5,894 Florida
Locomotion
There are always priorities. Is durability more important, like a Dana 60, or the ability to fine-tune gear ratios for varying car weights for different classes and/or changing weather conditions and/or altitude with removable center sections?
Re: Dana 60
[Re: Locomotion]
#2578802
11/15/18 04:06 PM
11/15/18 04:06 PM
Posts: 4,457 Washington
madscientist
Washington
There are always priorities. Is durability more important, like a Dana 60, or the ability to fine-tune gear ratios for varying car weights for different classes and/or changing weather conditions and/or altitude with removable center sections? EXACTLY. The 9 won that war decades ago because the guys who actually change axle ratios (and transmission ratios are changed nearly every run) like Pro Stock and Comp needed gear ratios that were every close in ratio. No one wanted to change D60 gears between rounds, so the 9 got the nod. I don't remember the year but Pro Stock was squealing for a 4.00 ratio. They finally got it, and IIRC, after a year or two, that ratio became obsolete. The average racer who tells me he changes his axle ratio at the track to tune for conditions is either a rare bird, or he's a liar. It just isn't done. I will say I worked with a die hard braket race with a pocket full of money who kept several gear boxes in the trailer, all with different low gear sets. He would change a transmission to get the car better on the starting line if he thought he needed it. Then someone pointed out to him that the 2 step could be altered to almost the same affect.
Re: Dana 60
[Re: CMcAllister]
#2578829
11/15/18 05:16 PM
11/15/18 05:16 PM
madscientist
Washington
I don't care what kind of piece of junk you get an old housing out of at the junk yard. It can't be made as strong or as useful as this one. Now, you may not need a unit like this, but the technology and aftermarket support trickles down even to bracket cars. Some folks will take advantage of it. Some will insist on being nostalgic. Nothing wrong with either one and nothing wrong with a 60 in an old Mopar. I think that was the point Pittsburghracer was making. What is called a 9 inch Ford today has zero in common with a 9 inch Ford, except the dimensions. The lowly 8.75 and the D60 have some aftermarket pieces, it's nothing compared to what the aftermarket made up for the 9. I've seen well tuned low 8 second stick cars run on almost stock D60's and not fail if you did maintainence on them.
Re: Dana 60
#2579001
11/16/18 01:12 AM
11/16/18 01:12 AM
Posts: 1,460 Martinsville, IN
cdwmotorsports
Martinsville, IN
8.75" it is. None of these point for or against the 60 and 9 are better or worse for my setup. I don't run at tracks with different altitudes, I don't need 15 different gear sets. So I'm gonna narrow what I have and move on to other projects.
eBay-cdwmotorsports
Re: Dana 60
#2579031
11/16/18 03:24 AM
11/16/18 03:24 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My next build I’m going all out and making it as lite as possible. Starting with a 7 1/4 rearend and upgrading it with unobtainium 4 bolt 3/8 aluminum stud axles. I’m going to flycut the ring and pinion thinkness and make up the thickness difference with Old Milwaukee beer cans. I’m going to save more weight and drag by leaving the rear cover off so I can spray the ring and pinion down with Pam cooking spray before each pass. Looking for some new bests in 2019
Re: Dana 60
[Re: moparx]
#2579096
11/16/18 12:19 PM
11/16/18 12:19 PM
madscientist
Washington
My next build I’m going all out and making it as lite as possible. Starting with a 7 1/4 rearend and upgrading it with unobtainium 4 bolt 3/8 aluminum stud axles. I’m going to flycut the ring and pinion thinkness and make up the thickness difference with Old Milwaukee beer cans. I’m going to save more weight and drag by leaving the rear cover off so I can spray the ring and pinion down with Pam cooking spray before each pass. Looking for some new bests in 2019 can i watch ? Only if you bring the beer and the Ben-Gay. And YOU have to apply the Ben-Gay.
Re: Dana 60
[Re: dthemi]
#2579141
11/16/18 01:47 PM
11/16/18 01:47 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't stop there. Take the seats out, and sit over the rear end like a sling shot dragster lol. Lol. Let’s not spill all the beans in one post. I got some top secret ideas brewing. I did get a great deal on some ghost carpet. It’s so lite it’s invisible
