Re: led headlights
[Re: plycuda]
#2572001
10/31/18 09:46 AM
10/31/18 09:46 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
The Trucklight brand ones are the best looking that I have seen, but I have done zero research. I have several friends with them in Jeeps and they all love them.
It's an upgrade I need to do. The drag week route last year was in some crazy mountain roads that we luckily did in the daylight. At night With all the curves all my crappy old halogens would have done was show where we were going to crash.
68 Barracuda Formula S 340
Re: led headlights
[Re: plycuda]
#2572012
10/31/18 10:17 AM
10/31/18 10:17 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Trucklite here...better in every way. Less current, more light, I am powering them through the OEM wiring, no relay or anything. Measure the voltage drop at the light and it was negligible. Only thing, they stick out slightly past the trim ring. Made in USA, 3 year warranty, DOT approved http://www.truck-lite.com/webapp/wcs/sto...catalogId=10002
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
Re: led headlights
[Re: OUTLAWD]
#2572346
10/31/18 08:31 PM
10/31/18 08:31 PM
Posts: 4,981 new jersey usa
11secdart
new jersey usa
I put them on my D150 last year after seeing a Dually in the Carlisle show field that had them. The are bright when on and look good also when not turned on
Re: led headlights
[Re: plycuda]
#2572405
10/31/18 11:04 PM
10/31/18 11:04 PM
Posts: 20,573 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I just put a set of the Hella HID conversion lights I bought from Summit in my old Chevy pickup to replace the old oem style sealed beam halogen lights and they are way better. No mods required at all, even the factory stainless GM trim bezels that go around the lights fit. The high setting is absurdly bright, so much so that I know they would 100% blind people coming the other way. They look pretty stockish and are DOT approved. http://www.myhellalights.com/index.php/products/auxiliary-lamps/sealed-beam-conversion-headlamps/
Re: led headlights
[Re: Neil]
#2572451
11/01/18 12:27 AM
11/01/18 12:27 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I just put a set of the Hella HID conversion lights I bought from Summit in my old Chevy pickup to replace the old oem style sealed beam halogen lights and they are way better. No mods required at all, even the factory stainless GM trim bezels that go around the lights fit. The high setting is absurdly bright, so much so that I know they would 100% blind people coming the other way. They look pretty stockish and are DOT approved. http://www.myhellalights.com/index.php/products/auxiliary-lamps/sealed-beam-conversion-headlamps/ I used them on a 2 headlight car I had years ago,MUCH brighter and high beams were blinding! Also like the way the glass was fluted.You can also put a brighter bulb in! They are on my bucket list!
Re: led headlights
[Re: plycuda]
#2572700
11/01/18 06:37 PM
11/01/18 06:37 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
looks like trucklite only has the 7" no 5 3/4 for 4 head lights and the hella headlights are not led they are h4 draw 55 and 60 watts each My Aug issue of Mopar Action had a Article on a Street/Strip 67 Dodge Dart. In it the owner installed 7 inch Led Head lights from a Harley Davidson motor cycle. He said the lights dropped right in, just had to redo the factory head light plug. So I don’t see why these wouldn’t work in your car. You woukd just have to do some wiring. But the lights don’t look cheep, https://www.revzilla.com/motorcycle/hogw...3xoC68gQAvD_BwE
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: led headlights
[Re: mopar65]
#2572752
11/01/18 08:47 PM
11/01/18 08:47 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
looks like trucklite only has the 7" no 5 3/4 for 4 head lights and the hella headlights are not led they are h4 draw 55 and 60 watts each My Aug issue of Mopar Action had a Article on a Street/Strip 67 Dodge Dart. In it the owner installed 7 inch Led Head lights from a Harley Davidson motor cycle. He said the lights dropped right in, just had to redo the factory head light plug. So I don’t see why these wouldn’t work in your car. You woukd just have to do some wiring. But the lights don’t look cheep, https://www.revzilla.com/motorcycle/hogw...3xoC68gQAvD_BwE wow your not kidding $720 for4 lights
Re: led headlights
[Re: plycuda]
#2572796
11/01/18 10:49 PM
11/01/18 10:49 PM
mopar65
looks like trucklite only has the 7" no 5 3/4 for 4 head lights and the hella headlights are not led they are h4 draw 55 and 60 watts each My Aug issue of Mopar Action had a Article on a Street/Strip 67 Dodge Dart. In it the owner installed 7 inch Led Head lights from a Harley Davidson motor cycle. He said the lights dropped right in, just had to redo the factory head light plug. So I don’t see why these wouldn’t work in your car. You woukd just have to do some wiring. But the lights don’t look cheep, https://www.revzilla.com/motorcycle/hogw...3xoC68gQAvD_BwE wow your not kidding $720 for4 lights Here are some that look a lot cheaper. But I know nothing about them. https://www.ebay.com/i/173419010643?chn=ps&ul_ref=https%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmpre%253Dhttps%25253A%25252F%25252Fwww.ebay.com%25252Fi%25252F173419010643%25253Fchn%25253Dps%2526itemid%253D173419010643%2526targetid%253D483853064107%2526device%253Dm%2526adtype%253Dpla%2526googleloc%253D9023210%2526poi%253D%2526campaignid%253D1499095126%2526adgroupid%253D64669591424%2526rlsatarget%253Dpla-483853064107%2526abcId%253D1139396%2526merchantid%253D118862638%2526gclid%253DCjwKCAjwyOreBRAYEiwAR2mSkkahOcQDZOSp20Vbd6B6nctX8EjTYrtsqSRh6HDgDcKR5-wYHCmCQRoC8y4QAvD_BwE%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1725493652493%2526rvr_ts%253Dd1e2c0521660ac1e0ab553fdfff58c46
support our troops
Re: led headlights
[Re: plycuda]
#2572799
11/01/18 10:53 PM
11/01/18 10:53 PM
mopar65
support our troops
Re: led headlights
[Re: plycuda]
#2572800
11/01/18 10:54 PM
11/01/18 10:54 PM
mopar65
support our troops
Re: led headlights
[Re: plycuda]
#2572802
11/01/18 10:55 PM
11/01/18 10:55 PM
mopar65
Sorry I don’t know why it’s doing that. Just go to EBay and put in 5-3/4 led head light.
support our troops
