Re: B body console top, strange cut out (pics)
[Re: Moparnut426]
#2571129
10/29/18 06:15 PM
10/29/18 06:15 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
69 or 70 B body? Hmmm.....never seen that before.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: Moparnut426]
#2571150
10/29/18 06:44 PM
10/29/18 06:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Looks like someone used an automatic woodgrain decal on a 4 spd plate and filled in the void with a little extra decal left over from the "surgery"...
[Re: DAYCLONA]
#2571167
10/29/18 07:18 PM
10/29/18 07:18 PM
70gtx440dana
Lansing, MI
Looks like someone used an automatic woodgrain decal on a 4 spd plate and filled in the void with a little extra decal left over from the "surgery"... Nice detective work Dayclona!
[Re: Moparnut426]
#2571534
10/30/18 12:08 PM
10/30/18 12:08 PM
Posts: 18,157 Mass
DAYCLONA
Mass
whoever did it did a really good job because the aluminum under the decal is cut just as cleanly as the decal its stuck to.
Is it really cut/pieced?, or is it just an old parting line from Chrysler's vendor modifying an automatic base plate mold to cast 4 spd plates?
[Re: Moparnut426]
#2571719
10/30/18 06:17 PM
10/30/18 06:17 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
No, the aluminum under the decal is cut and its cut is just as clean as the decal. its even raised up a lil bit since the way they secured it only used 2 tabs and some adhesive of some kind. Im using a heat gun to remove the old decal, and the plate under it looks good, just going to be hard to get the new decal to lay even with that .020 gap.
[Re: Moparnut426]
#2576756
11/10/18 01:21 PM
11/10/18 01:21 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Fill that gap with JB weld, sand it down smooth and no-one will ever know and it will last.
[Re: blewbyu]
#2577362
11/12/18 01:07 AM
11/12/18 01:07 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Did I see something once about an auto on the column car with buckets with a console without a provision for auto or 4 speed? ....
