‘65 A100 with four link rear. #2570760
10/28/18 10:19 PM
10/28/18 10:19 PM
Visalia, CA.
P
poison_ivy Offline OP
P
Visalia, CA.
I have a ‘65 A100 pickup that I’m putting a four link rear suspension into. My concern is the pinion angle. I’m thinking because the four link locks the rear in place and theoretically doesn’t allow it to rotate, then pinion angle is perhaps not as big an issue as say with stock suspension. Am I thinking right or not? Thanks for the help.
Re: ‘65 A100 with four link rear. [Re: poison_ivy] #2570823
10/29/18 12:33 AM
10/29/18 12:33 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'm thinking that you probably want the pinion angle to be pretty close to correct compared with the trans center line, if that was what you meant by not being a big issue. If the angle is 0 degrees, 3 degrees, 5 degrees, or 10 degrees, the theory is it wouldn't change through the suspension travel. I would want it as close to 0 degrees as I could get it. Gene
Re: ‘65 A100 with four link rear. [Re: poison_ivy] #2570952
10/29/18 12:52 PM
10/29/18 12:52 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Even with that setup,I would still go 1 degree down,allowing for some flexing.
Re: ‘65 A100 with four link rear. [Re: poison_ivy] #2571424
10/30/18 02:23 AM
10/30/18 02:23 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I agree with a little bit of flex.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
