Steering Linkage Help #2570329
10/27/18 07:53 PM
10/27/18 07:53 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 2WD 3.9. When I removed my rack and pinion, the steering shaft slide out of the fire wall. I slide it back in (rack not in yet) and now I can't remove the key from the ignition. I put pressure on the spring, but key still won't come out. I can start the engine though. What now?
***UPDATE***
I thought about it over night and decided this morning to see if the column shift was all the way in park. DOOH! It wasn't and the key came right out. Must have moved when the shaft came out. WHEW! Didn't want to tear down the column.
Grandma always said I had "hands of gold"!
Re: Steering Linkage Help [Re: CHRGR69] #2570756
10/28/18 10:14 PM
10/28/18 10:14 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I get solutions sometimes that way too
Re: Steering Linkage Help [Re: CHRGR69] #2571431
10/30/18 02:44 AM
10/30/18 02:44 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Did you sleep at a Holiday Inn Express?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
