Mystery Bolt
#2570313
10/27/18 07:15 PM
10/27/18 07:15 PM
Posts: 435 New Mexico
Scott440
New Mexico
A while back, the engine builder fastened the valley tray with these unusual bolt heads (capscrews). They have a sunburst head -- like a kind of inverse torx head. I'm having trouble finding the right tool that removes them. Is there a name for these? Thanks in advance. [img] https://lh3.googleusercontent.com/4mX7tk...2g=w825-h485-no[/img]
Re: Mystery Bolt
[Re: Scott440]
#2570321
10/27/18 07:28 PM
10/27/18 07:28 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yeah, the correct term is "12-point Flange Bolt" yours appears to be Grade 8.
Re: Mystery Bolt
[Re: Scott440]
#2570360
10/27/18 09:03 PM
10/27/18 09:03 PM
Posts: 11,552 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
!2 point socket. Useful for tight clearances, trans pans, intakes, headers, even head bolts.
Re: Mystery Bolt
[Re: Sammy]
#2570383
10/27/18 09:57 PM
10/27/18 09:57 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They may be 12 point 11/32 head size The 12 point nuts on 1/4 inch studs I use for valve covers use that size All Indy valley trays and intake tops use only 1/4-20 12 point bolts Not mine. lol. I make my stuff easy to work on so for applications like that hex head bolts work great.
