W5 vs new Edelbrock heads
#2570009
10/26/18 11:31 PM
10/26/18 11:31 PM
Posts: 278 Kentucky
71blackdemon
Kentucky
I have a 422 cubic inch small block with W5 heads that made 700 horsepower at the flywheel I was told the new Edelbrock small block heads would make more horsepower just asking for your opinions my heads the W5 Flowed 330 @ 700 can I make more horse power with the Edelbrock Victor heads
Re: W5 vs new Edelbrock heads
[Re: 71blackdemon]
#2570104
10/27/18 06:54 AM
10/27/18 06:54 AM
Posts: 2,578 sweden
1Fast340
sweden
I would say yes. Edit: i hope you are talking about Victor heads..
[Re: 71blackdemon]
#2570306
10/27/18 06:36 PM
10/27/18 06:36 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
Shady Dells give flow rates for most of the various Mopar heads. http://www.shadydellspeedshop.com/cylheads.htmThey put the W5 in the 320-330 area which is similar to the INDY 360-1. The Victor isn't listed by them on the website but my impression is that it is closer to the W7 which is in the 350-370 class. I bet if you called they would have an answer.
[Re: gzig5]
#2570312
10/27/18 07:10 PM
10/27/18 07:10 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Plan on getting new pistons for the new Victor heads.
[Re: 71blackdemon]
#2570497
10/28/18 07:26 AM
10/28/18 07:26 AM
Posts: 2,578 sweden
1Fast340
sweden
Why do I have to get new Pistons Different valveangle is the obvious answer,possibly location aswell.
[Re: 71blackdemon]
#2570503
10/28/18 09:04 AM
10/28/18 09:04 AM
Guitar Jones
[Re: 71blackdemon]
#2570753
10/28/18 10:00 PM
10/28/18 10:00 PM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
Victor head is capable of well over 800 horsepower. WAY more thani a W5. They are capable of flowing 380+ and have a good bit bigger valve than a W5. Guy i posted about( local to me) made 737 horse at a national dyno competition with a set on a stock stroke 360. And made even more power at bigher rpm than the contest limited the guys to. And that was under 12 to 1 per the contest rules. I used to have a stout 422 W5 motor than ran well into the 9’s at 3350 pounds. Victor is lot bigger and better head
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 71blackdemon]
#2570860
10/29/18 05:15 AM
10/29/18 05:15 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Wow. Didn't know the victor head was that good. Why isn't everybody running em?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2570930
10/29/18 12:08 PM
10/29/18 12:08 PM
Posts: 3,516 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Wow. Didn't know the victor head was that good. Why isn't everybody running em? In my opinion because they are expensive, take unique rocker gear and perhaps new pistons. That being said they may be the best 59 degree head available when properly ported.
[Re: mopardude318]
#2571010
10/29/18 02:30 PM
10/29/18 02:30 PM
Posts: 4,457 Washington
madscientist
Washington
Wow. Didn't know the victor head was that good. Why isn't everybody running em? Just like 340cuda said. The Chrysler guys are too cheap to buy anything other than stock wrecking yard blocks and stock rockers. It's silly. I never ever EVER once had a Chevy customer [censored] about buying rockers. Not one single time. Every time I told a customer you need to find some W-2 heads for this stroker at the minimum I would hear the inevitable whining, crying, bitching, moaning and all the other crap. By the end of an hour of that [censored] I'd say piss on it, buy some edelbrocks and continue on leaving big power on the table so you don't have to buy rockers. Same [censored] every day. For decades.
[Re: 71blackdemon]
#2571021
10/29/18 02:53 PM
10/29/18 02:53 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I would love to put a set on my 422 cubic-inch W5 motor but they're saying I need to change the piston everything I read says they was a direct bolt-on to a stock engine Frankly, the whole proposition is expensive enough that I wouldn’t expect pistons to be the deal breaker. Of course, I doubt I’d bother putting them on a stock block either........ then building it with a good block gets really expensive real fast.
