Re: Choosing a converter company?
[Re: justinp61]
#2568123
10/23/18 12:08 AM
10/23/18 12:08 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Mine is going to Dynamic for the new build. Been dealing with Frank for 35+ years and can't stop now.............
[Re: justinp61]
#2568152
10/23/18 12:55 AM
10/23/18 12:55 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
I have one 8” converter 6200 stall that has some slip, but will print off 1.34 60 times and 6.13 1/8 times by the notebook full. I attribute the consistency to my 3rd place finish in the Hot Rod Heritage Series 2 years ago. My other 8” is tighter and 5800 stall. It can dip into the high 1.2’s on the 60 and has given me a best 1/8th increment of 5.94. Prob is that it can vary on launch and isn’t nearly as predictable. I bought this piece just to shut a guy up that thought he had me covered as he had intel from my slo piece. Good thing I have all these piled up next to my 727 as I’m switching over to a 904... dumb...dumb...dumb...
[Re: J_BODY]
#2568174
10/23/18 02:02 AM
10/23/18 02:02 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
[/quote] Good thing I have all these piled up next to my 727 as I’m switching over to a 904... dumb...dumb...dumb... [/quote] Hopefully I can help inspire you, just think of that glorious feeling you will have when you rip off that 1.35 60' and a 6.14 et with the new combo Who is supplying the new converter?
"Just a Bracket car dressed up like a streetcar"
[Re: justinp61]
#2568268
10/23/18 11:35 AM
10/23/18 11:35 AM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
ATI is probably an hour's drive from me (no traffic), but I've never been sure they were the way to go, either. They told me years ago that I should run an 8", which I thought was a bit absurd for a low-11 second car (at that time). ATI is still very popular with the stock/superstock crowd.
[Re: justinp61]
#2568271
10/23/18 11:41 AM
10/23/18 11:41 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I was gonna say why not ATI? The local guy that builds my converters and transmissions has a very close relationship w/ ATI and uses a lot of their parts. Atlantic Coast Converters in Conway, SC, is who I use. Almost everyone around this part of SC and NC uses them.
[Re: dOrk !]
#2568287
10/23/18 12:12 PM
10/23/18 12:12 PM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
No one mention Turbo Action ? While I have not got anything from them recently I have used Turbo Action for years. I had one converter that sat on the shelf long enough to be out of warranty when I used it. After a few races something let go internally and they still warrantied it. As I understand it Paul works part time now and he is who I would want to talk to. I think he comes in at 1:00 pm four days a week.
[Re: justinp61]
#2569592
10/26/18 12:33 AM
10/26/18 12:33 AM
Posts: 506 Utah, USA
1964superstock
Utah, USA
I would suggest calling A-1, and order a 8 inch converter. I have a 8 inch tight 4800 RPM stall converter in my 505 stoker, with 4:10 dana. Nothing but fun, works so nice, perfect drivability on the street, no slop. Stomp on the gas and holy crap, it flashes to 4800 in an instant and takes off. Very good product, no complaints, custom made per my dyno sheet, and car specs. May be a little more $$ than some, but is worth it in my opinion. Give them a call, you won't be disappointed. Very nice guys to talk with also. FYI...Dave Smith at Pro-Trans built my 727, and recommended that I order a 8 inch A-1 converter. I trusted his recommendation, glad I did. https://www.a-1perf.com/
[Re: 1964superstock]
#2569603
10/26/18 01:05 AM
10/26/18 01:05 AM
Posts: 43,173 Bend,OR USA
Cab_Burge
I would suggest calling A-1, and order a 8 inch converter. I have a 8 inch tight 4800 RPM stall converter in my 505 stoker, with 4:10 dana. Nothing but fun, works so nice, perfect drivability on the street, no slop. Stomp on the gas and holy crap, it flashes to 4800 in an instant and takes off. Very good product, no complaints, custom made per my dyno sheet, and car specs. May be a little more $$ than some, but is worth it in my opinion. Give them a call, you won't be disappointed. Very nice guys to talk with also. FYI...Dave Smith at Pro-Trans built my 727, and recommended that I order a 8 inch A-1 converter. I trusted his recommendation, glad I did. https://www.a-1perf.com/ I had A1 work on my nine inch Continental converter and Mikes Ultra Glide after it broke. It lasted 12 runs before it broke again I paid them to fix it again and it has lasted a little bit longer this time, so far If and when I have another glide converter built it will be a ATI I have used Dave at Pro Trans for years on my Mopar trans. cars He is building me a all out 727 now for one of my customers street and show car with a 800 HP pump gas 572 EFI Hemi motor, hopefully he will be able to supply me with a good converter for that car also OP, buy the best converter you can get Not the cheapest
[Re: justinp61]
#2569651
10/26/18 09:28 AM
10/26/18 09:28 AM
crabman173
crabman173
Just a thought IF you footbrake The fastest converter may not be the best for hitting the tree--Tighter makes it easier to nail the tree vs loose ( which is usually faster 60 ft etc)
[Re: justinp61]
#2569663
10/26/18 10:30 AM
10/26/18 10:30 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
My favorite two are ATI & PTC. I used to run a PTC 8" 5000 nitrous convertor in one of my old Pro street 69 Charger for 5-6 year on the street until I sold the car. Totally street friendly until you mashed the throttle & then it would do what it needed to do. I currently have another PTC 9.5" 3800 convertor in my street driven cruiser 70' Charger with well over 30,000 street miles on it & is about 10 years old now without any issues.
I also have another PTC 9.5" 5400 Nitrous convertor in my 70' Hemi street/strip 70' Challenger. No complaints from PTC from me.
ATI is usually more expensive than PTC but so many of my buddies are always returning them back & forth between ATI & Ultimate Convertors to adjust the stall up or down several hundred RPMs to get them right.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Just-a-dart]
#2569670
10/26/18 10:52 AM
10/26/18 10:52 AM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
[/quote]
All of Kris's stuff was purchased by Steve Casner at CRE if you still want to use the product. Just FYI Thanks Al, as always I appreciate the info. I did not know where the stuff went, the kid Peter was trying to put something together when they 1st closed. But that obviously did not happen. [/quote] Glad I clicked on this thread. Kris built me a converter a couple of years ago and it turned out to be one of his last. Great guy, great product, great price. I appreciate the update.
1970 Duster 340 clone
[Re: Spaceman Spiff]
#2569737
10/26/18 01:26 PM
10/26/18 01:26 PM
Posts: 1,237 North Central, Indiana
Roughbird72
No one mention Turbo Action ? GER? I learned the hard way on that way back when. Broke one GER(it sound like a box of glass), they replaced it and the replacement had 13% loss. I've been running a PTC for quite awhile.
72 Plymouth Roadrunner 11.08@123.25
[Re: justinp61]
#2569784
10/26/18 03:36 PM
10/26/18 03:36 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I've had a UCC in mine since 2005 no issues...
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Roughbird72]
#2569790
10/26/18 03:47 PM
10/26/18 03:47 PM
6PKRTSE
Motor City
No one mention Turbo Action ? GER? I learned the hard way on that way back when. Broke one GER(it sound like a box of glass), they replaced it and the replacement had 13% loss. I've been running a PTC for quite awhile. One of my buddies tried a 10" 4000 GER in his turbo 400 in his 68 Pontiac because they were so cheap. He got lucky. It lasted many years with abused street/strip miles in a 10 sec all steel street car. Still worked great when he just sold it a few years ago. The car has changed hands & is still going strong today & is back up for sale again now from new owner #2.
