Page 1 of 4 1 2 3 4
Proven strength of 8 3/4 diff #2569253
10/25/18 08:55 AM
10/25/18 08:55 AM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Due to Dominic Thumper's lack of computer savvy, he has asked me to post a pic of his Dart time slips over the years. Although it started out as a small block, it has been equipped a long time with a 470 low deck, Edelbrock heads, roller cam, fenderwell headers and carb of the day. He might have banged his head one too many times, but he has never hurt the rear axle assembly.
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569286
10/25/18 11:30 AM
10/25/18 11:30 AM
Washington
madscientist Offline
Washington
If Dom is like me, he will still be running with a flip phone. That's all I have. And when this flip phone junker dies, I'm back to a land line.
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569287
10/25/18 11:31 AM
10/25/18 11:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That looks like a bunch of passes in 2018 or just a few passes over 10 years lol. I don't race as much as I would like either.
68 Barracuda Formula S 340
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569296
10/25/18 11:52 AM
10/25/18 11:52 AM
New York
polyspheric Offline
polyspheric  Offline
New York
And the car weight was...
And the weight transfer was...
And the effective torque multiplication to the pinion was...
And the tire contact patch was...
A 1,000 hp car with 1,500 stall speed and 6.50-13 tires can use an 8-3/4 for 50 years.
A 500 hp 4,000 lb. car with 80 lb. flywheel leaving at 8,000 RPM on 14" tires can't do it once.
What does this mean? We don't have enough data to draw a conclusion, other than YRMV.
Boffin Emeritus
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569315
10/25/18 12:13 PM
10/25/18 12:13 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
3850# + Drag radials + 11.00s-11.10s killed the ring gear in mine 2 weeks ago. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: Proven strength of 8 3/4 diff [Re: Bad340fish] #2569346
10/25/18 01:29 PM
10/25/18 01:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This year maybe 10-12 passes but some are from the 90's and this was for fun but to prove I have beat the snot outta my junk and it's still going strong when some HOPED it wouldn't and even heard a few had bets on WHEN it would grenade.......... beer In the last 10 years most of my 60's were in the low 1.3's and that's with a stock 8 3/4(minus new gears of course)and stock caps between 3050-3150 lbs roughly......... thumbs
Re: Proven strength of 8 3/4 diff [Re: polyspheric] #2569356
10/25/18 01:49 PM
10/25/18 01:49 PM
jersey
Spaceman Spiff Offline
jersey
4600lbs wagon.
526 stroker, close to 700lb ft
2600 stall.
275/60/15
8 3/4 still alive.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Proven strength of 8 3/4 diff [Re: Spaceman Spiff] #2569368
10/25/18 02:06 PM
10/25/18 02:06 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
4600lbs wagon.
2600 stall.
275/60/15 12 year old 600 TW? laugh2
8 3/4 still alive.
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569391
10/25/18 02:52 PM
10/25/18 02:52 PM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
The 8 3/4 debate has gone on for years and will continue for years. Some guys have had great luck and some haven't. I'm one who didn't have good luck, my 408 broke mine on the second pass it hooked. The first was a 1.40 60'. The rear was pretty fresh and probably had 40-60 1/8 mile passes and a couple thousand street miles behind my 340 that ran 7.20's in the 1/8. It was quiet and had no vibration, all the bearings were replaced when the r&p were installed.
After having to go into my 727 after breaking the rear I went with the Dana for peace of mind.
IMO an 8 3/4 in a heavish hard leaving car with good power is a gamble. As Clint said, "Do you feel lucky"........ Ummmmm, no, no I don't.
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569401
10/25/18 03:05 PM
10/25/18 03:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Pro gear and ratio availability, aftermarket support, large diameter pinion, high strength aluminum cases, housing availability, etc., etc. 8.75s and D60s in Mopars are nice, but...
Re: Proven strength of 8 3/4 diff [Re: CMcAllister] #2569407
10/25/18 03:16 PM
10/25/18 03:16 PM
W. Kentucky
W. Kentucky
iagree, but I wasn't going there. catfight fan biggrin
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569408
10/25/18 03:16 PM
10/25/18 03:16 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I agree on the weight factor. I hacked on a stock 489 rear for 250+ passes, and who knows what it went through before I got it. No issues ever. I'm 3160 at the line, running a spool, drag radials, and a brake. 60's in the mid to low 1.4's.
My friend runs a 3800lb Road Runner that had an aluminum 8 3/4 housing. The car used to run 10.8's until he had the motor rebuilt this year and picked up 140+ HP and a bunch of torque. It picked up 1/2 tenth in the quarter. It lasted about 6 passes and disintegrated the case. This was foot braking.
I borrowed him my nodular 489, new this year, that had 3 weekends on it. It last about 6 passes and broke. We don't know what yet, but it broke.
I'm planning to bump up my program next year and drop a little weight in the process. I plan to run the nodular 8 3/4 next year. I'm more concerned about the stock 904 shafts than I am the 8 3/4 so those are getting upgraded first :}
Re: Proven strength of 8 3/4 diff [Re: CMcAllister] #2569413
10/25/18 03:24 PM
10/25/18 03:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My thoughts are I would never run an 8 3/4 rear-end in any of my cars running the times I am BUT my Sons Duster at 3200 pounds is. Its a non-back-braced 8 3/4 with 4.10 gears, stock caps, 35 spline axles and spool, trans brake car with 5600 stall and 727 transmission, 275 radials used to be 10.5 slicks, 1.38-1.42 sixty foot times. Approximately 200 passes since gear change with zero issues. Moparts member Tim Bowman of Bowman Performance helped set the gears up for him. He's stepping up to a 4.56 gear for next year since our class (box class) strictly runs 1/8 mile only. Car number 3X97
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Proven strength of 8 3/4 diff [Re: humpty] #2569422
10/25/18 03:41 PM
10/25/18 03:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That THUMPERCARBS power has a way of tearing stuff up............ beer
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569473
10/25/18 06:17 PM
10/25/18 06:17 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Put Drag radials on & broke the ring gear, 4050lb auto 68 Charger, that was when the car was slower than it is now.
Re: Proven strength of 8 3/4 diff [Re: justinp61] #2569493
10/25/18 07:23 PM
10/25/18 07:23 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I'll go there.
I had a Ford 9" in a street car. MILD 440. Took out six sets of gears in 11 years on the road. Street tires, 3100 pounds. I had WAR cases, nodular cases, Richmond gears, US gears, you name it. 31 spline 4 spider posi and a spool.
No gear set lasted very long, set up by four different people very knowledgeable IMO.
NO THANKS!!!!
CrAzYMoPaRGuY
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569542
10/25/18 10:24 PM
10/25/18 10:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I wish we had enough hard data on the stress points:
1. weight
2. G force on launch
3. contact patch
4. stall speed vs. flywheel mass + launch RPM
5. ring gear deflection (larger ring gear isn't always the best design)
etc. to assign a point value to each (as a multiplier) and get a total for "what will break it".
Boffin Emeritus
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569548
10/25/18 10:34 PM
10/25/18 10:34 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I think you can stop at #1 and ignore the other 4 in the calculations...lol
Every guy above that said they broke one was in a heavy car, and all the ones that survived were in a light car.
Pretty much sums it up.
Re: Proven strength of 8 3/4 diff [Re: polyspheric] #2569549
10/25/18 10:35 PM
10/25/18 10:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I find it hard to see how this would be fruitful for all the needed effort.. There are likely 50? other pertinent variables, GIGO is still relevant, and only three solutions, and confirmation bias still trumps them all.
Re: Proven strength of 8 3/4 diff [Re: sgcuda] #2569556
10/25/18 10:53 PM
10/25/18 10:53 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You can bulk up the housing enough to stop any deflection that causes problems. But that just gets you to the next weak point. The pinion shears off at the yoke.
My 8 3/4 took my 3700 lb trans brake car into the low nines. The housing was back braced, had cap load bolts in three directions with extensive internal bracing. Probably around 50 passes at the track, and who knows how many on the street. Started working on the sixty ft, and sheared off 3 different sets of gears at the yoke. Once the pinion shears off, you’ve done all you can, and need to move on.
I ended up going to an ultra case 9” with the large diameter pinion gear (3.50 ratio) and it took everything I could throw at it.
I would think with a lighter car and a higher (numerical) gear ratio, I could get an 8 3/4 to live for a pretty long time.
Page 1 of 4 1 2 3 4
