Re: Remote side mirror installation on 71 B-Body
[Re: JF_Moparts]
#2562344
10/11/18 10:48 AM
10/11/18 10:48 AM
Posts: 2,015 Frederick, MD
71charger
Frederick, MD
That bottom thing in your photo that's marked as a tie should be secured to the leading edge of the door. There's a hole for it and the barbed end of the plastic piece gets pushed through from the inside out. That keeps the cables from getting caught up when the window goes up and down.
[Re: JF_Moparts]
#2564276
10/15/18 08:43 AM
10/15/18 08:43 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Mine got jus 2 ties. One snaps on in front of door close to the door hinge, the other one on inner side/face ( covered by the door panel ) this has being talked and posted at the 3rd gen charger board
[Re: JF_Moparts]
#2565232
10/17/18 07:51 AM
10/17/18 07:51 AM
NachoRT74
Valencia, España
your lucky day! found the pic I grabbed back in the day from the thread mentioned ( not the one I posted )
Check for the words MIRROR wrotten with a sharpie... front of door and close to the joystick location. The thread I posted is not right on one of the locations posted.
[Re: JF_Moparts]
#2565236
10/17/18 08:00 AM
10/17/18 08:00 AM
NachoRT74
Valencia, España
no, round holes.
check where the arrows are pointing out
[Re: JF_Moparts]
#2565879
10/18/18 12:53 PM
10/18/18 12:53 PM
NachoRT74
Valencia, España
Somebody told on board you could try lace the clip with small cord or nylon and get it trought the front hole to pull it out with it. I could reach it with my arm thought. Not easy!
[Re: NachoRT74]
#2566312
10/19/18 03:08 AM
10/19/18 03:08 AM
Posts: 2,592 None
71rm23
None
Somebody told on board you could try lace the clip with small cord or nylon and get it trought the front hole to pull it out with it. I could reach it with my arm thought. Not easy! Thanks for the picture Nacho and yes, round hole in the previous question. As far as the first hole, I too, couldn't get that sucker in and isn't easy. After spending over an hour trying to get my arm in there, to find that hole, try to push it through, I put one of these on for the first hole and done. http://www.clipsandfasteners.com/Push-Mount-Cable-Tie-For-Imports-200mm-Length-p/a20380.htm
