Drag racing rules
#2569317
10/25/18 12:22 PM
10/25/18 12:22 PM
Posts: 34,942 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Since racing for the year is done ..Not much to talk about
How would you feel about this
You are racing a basic small NHRA track and its for the smaller version of a gold man.
Not a huge amount of cars, something like 60 or something like that
and its index bracket racing 1/8 mile
the mark is set for 6.50
You take a couple time trials , adjust your throttle , car works well, driver does his part . things go well ..
You find yourself in the Semi finals
Your opponent goes red at the hit, you think well .. lets run it out an see how close I am to 6.50 now
car goes 6.49 with a 9 ..and you get slip, says win , you think
well, this might be fun
on the loudspeaker you are called to tower and told you went past index and are out, opponent is back in ..
How does the court of Moparts rule on that one ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Drag racing rules
[Re: bigdad]
#2569326
10/25/18 12:41 PM
10/25/18 12:41 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Never assume you have won until you see the slip. Run the race as if your opponent was right next to you. It's like in an old western movie shootout, when the guy who has been laying there, presumed shot dead, lifts his gun for one more shot.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: bigdad]
#2569342
10/25/18 01:22 PM
10/25/18 01:22 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
A lot of tracks are switching to that now. Its worst not first. Norwalk has been doing it for over a year now.
JAKES AUTOMOTIVE
[Re: bigdad]
#2569349
10/25/18 01:41 PM
10/25/18 01:41 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If there was no track event handout about that rule, i cry foul. Simply on the basis of past practice at bracket events. Was it worst package, like .01 red + .01 under equals a negative .02 package? Doubtful here, since you only went .001 under. At any case, i say foul.
[Re: bigdad]
#2569354
10/25/18 01:47 PM
10/25/18 01:47 PM
fast68plymouth
So. Burlington, Vt.
If they were going to stray from what the traditional well established practices have been for years, it should have made clear to the drivers before eliminations started.
[Re: bigdad]
#2569411
10/25/18 03:18 PM
10/25/18 03:18 PM
Posts: 11,673 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You got screwed, period. NHRA track? They run NHRA rules? It's in the rule book, Section 2, page 7, breakout rules. I would want to see it in writing if it's some kind of track rule. But it has always been, when one car redlights, the race is over at that point. That's about as basic as it gets. The only exception is if you would have crossed a boundary line.
The only other thing that's recent is the Trustart or whatever they call it where the driver with the worst red - in the event both drivers are early - is the loser, regardless who has the handicap. But even with that, the race is over when someone's red light comes on.
[Re: bigdad]
#2569412
10/25/18 03:23 PM
10/25/18 03:23 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Even the safety rules - bars vs cages, license, certs, etc - don't apply until you go 6.39, so they couldn't use that for a reason.
[Re: JAKE68]
#2569440
10/25/18 04:15 PM
10/25/18 04:15 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
A lot of tracks are switching to that now. Its worst not first. Norwalk has been doing it for over a year now. What Norwalk( thankfully) went to, along with lots of other tracks, has nothing to do with what the OP had happen. In his case he broke out after the opponent red lit. Never seen losing for doing that anywhere.
[Re: bigdad]
#2569441
10/25/18 04:19 PM
10/25/18 04:19 PM
B3422W5
Portage,michigan
Love trustart. Its nice to take the wallet out of racing to some degree. Wallet has been more destructive to this sport than anything
[Re: bigdad]
#2569444
10/25/18 04:33 PM
10/25/18 04:33 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
You got hosed, unless you hit a barrier or cone along the way The red light takes precedent over all but those situations. Red lights area free time shot for you. Only way you can not get the win is hit a cone, cross the center line, or hit a barrier PERIOD. ESPECIALLY at an NHRA sanctioned track Truestart has ZERO to do with this situation. It is only in play when both go red and the worst red gets the loss. Takes the advantage of being the faster car automatically winning if the slower cars goes red. Great addition to the sport IMO, much more level playing field. After all rule is first or worst. Slower car goes .005- red so he is first, faster car goes .010- red, he has the WORST of the two lights and should be the one who is done. The only instance where the first or worst rule doesn't mean squat is red lights with NO trustart
