E85 users - temperature question #2568780
10/24/18 11:48 AM
10/24/18 11:48 AM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Do you have any trouble getting your engine up to operating temp? I suspect my tune is way too rich, as I cannot get the engine to build any heat. In 80 degree weather I can cycle the water pump on and off and still barely get the temp gauge to move. And, Yes, I have verified the gauge operation. Thoughts?
bow
Re: E85 users - temperature question [Re: cagebob1] #2568791
10/24/18 12:07 PM
10/24/18 12:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Can you retard the spark?
Boffin Emeritus
Re: E85 users - temperature question [Re: polyspheric] #2568889
10/24/18 02:24 PM
10/24/18 02:24 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
never thought of that. I'm sure that would work. I guess my question really is: would a rich condition on E85 cause this issue?
Re: E85 users - temperature question [Re: cagebob1] #2568893
10/24/18 02:28 PM
10/24/18 02:28 PM
I have change jets on my E85 Dominator carb, it was sensitive to the amount of Ethanol content in the pump swill I tested with but I didn't drive it at the track with the original jetting until much later.
I would change the primary jets to leaner, maybe two sizes smaller, and increase the power valve restriction channel to get back to the same AFR at WOT or just change the primary jets first (leaner by two sizes) without racing it to see if it responds to that change only and go from there scope up
My car does warm up slow but it doesn't have a standard type or size radiator, it has two small oil coolers for the coolant instead shock It was that way when I got it and I haven't change it shruggy
Re: E85 users - temperature question [Re: cagebob1] #2568901
10/24/18 02:39 PM
10/24/18 02:39 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
Mine takes quite a bit of time to warm up and I always planned to add a lean out valve to help create heat. Maybe this year if we keep racing in the winter months.
Re: E85 users - temperature question [Re: cagebob1] #2568914
10/24/18 02:56 PM
10/24/18 02:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
AFAIK frequently reported.
Boffin Emeritus
Re: E85 users - temperature question [Re: cagebob1] #2568919
10/24/18 03:06 PM
10/24/18 03:06 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Hi Bob. I would lean it out at a idle and put a t-stat on it with a bypass hose to keep water circulating. Works for me
"Just a Bracket car dressed up like a streetcar"
Re: E85 users - temperature question [Re: cagebob1] #2569050
10/24/18 07:17 PM
10/24/18 07:17 PM
Absolutely up work
The local racer that convinced me to switch to E85 did a bunch of research on several different E85 forums before he switched over to E85 and all them said to jet the primary rich enough so the car would cool down coming back down the return road by at least 10 F from the end of the run temps work He bought the parts needed to convert one of his spare carbs. and tested with it until it made him happy shruggy
He did that and his car does run cooler than mine but he has a standard type radiator in it also work
Re: E85 users - temperature question [Re: cagebob1] #2569162
10/24/18 11:13 PM
10/24/18 11:13 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mine has zero problems making or controlling heat. I just put antifreeze in it last week. Fired it up with no fan on to circulate it, held it around 2k in neutral. Took about 2 min to hit the 180 thermostat, and about 3-5 more min until it was at 210.
Turned the fan on, and it came right back down to 180 where it always runs. This was in 40 degree weather outside.
Idles right around 13:1 af, cruises just a touch richer. I know when I leaned it up looking for fuel milage gains it did run hotter in the middle of summer...but we are talking 14:1 af cruise...nothing drastic.
Timing is locked at 35deg (unless under boost of course)
Shouldn't take a big carb move to make heat.
Re: E85 users - temperature question [Re: dizuster] #2569182
10/25/18 12:00 AM
10/25/18 12:00 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I know a lean out valve works great with straight alcohol. Nothing fancy just a rubber line going to a spacer plate or manifold fitting going inside to a 1/2 ball valve. Crack it open to build quick heat and close it up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: E85 users - temperature question [Re: cagebob1] #2569193
10/25/18 12:39 AM
10/25/18 12:39 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Got a question for you guys running E85 .... How do you deal with the big diffs in the formula of this fuel ? I have two buds down here that started out using E85 but now are using pure methanol. Bracket racing is deadly DEAD ON chit down here so dealing with the diffs in the formula was uNtolerable for them because their cars wouldn't run consistently.
Re: E85 users - temperature question [Re: dOc !] #2569213
10/25/18 01:59 AM
10/25/18 01:59 AM
The main reason the other guy converted was to help his car become more consistent, on race gas it would change .2 from first time trail(around 10:30 AM in the morning and slow down .2 for the first round after lunch around 1:30PM.
After getting the carb. dialed in it ran exactly the same number(6.84 in the 1/8 mile) from early morning to last round in the after noon for 6 different race days in the summer shock bow up
My car may vary .02 to .03 from first run to the last run on E85 shruggy up
I have not run this car on race gas either so keep that in mind, it runs between 5.98 to 6.03 in the 1/8 mile at 115.MPH and runs right at 9.01 to 9.04 in the 1/4 mile at 147. MPH at Woodburn, OR in the summer shruggy
I have slowed it down by being to rich in the summer also confused
Re: E85 users - temperature question [Re: cagebob1] #2569264
10/25/18 10:16 AM
10/25/18 10:16 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I've been running E85 now for 6 years. I have NEVER seen it test less then 83% here in Michigan. Obviously I'm not buying fuel in December, so those are all May to September race season checks.
The only time I even bother checking anymore is early or late in the season. Middle of the summer I dont even worry about it.
Re: E85 users - temperature question [Re: dizuster] #2569274
10/25/18 10:57 AM
10/25/18 10:57 AM
New Braunfels, TX
New Braunfels, TX
At the store I buy mine it has always tested right around 87%. I normally fill a 55 gallon drum in the spring for racing, so don't have to worry about any changes. I just fill up at the pump when I'm driving the car around.
Re: E85 users - temperature question [Re: cagebob1] #2569282
10/25/18 11:23 AM
10/25/18 11:23 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Don't think those guys actually tested it for a % but the cars were not consistent at all. With pure meth it is. POURING IT into a 55 gallon drum or two IS a good idea ... I think both of them would do 4 or 5 5 gallon containers at a time.
Re: E85 users - temperature question [Re: dOc !] #2569488
10/25/18 07:04 PM
10/25/18 07:04 PM
I buy my E85 fuel from a local gas station that sells all kinds of fuel from straight standard pump gas to diesel and VP brand race gas of several different octane ratings. The first ten gallons of E 85 I bought was in late fall and it ended up testing to be E75, not E 85 shock
That was the E 85 fuel I used to do the first dyno testing on my e85 Dominator race carb. that wanted to be jetted down leaner to get the best HP and torque. The dyno shop ended up buying ten gallons of E85 from the same station the next week after my first dyno test and left it in the two 5 gallons plastic fuel jugs in the dyno room that winter. I went back the next spring to do some more dyno tuning and they insisted that I use their fuel as they weren't going to use it, I tested it there before using it and it tested out to be E90 shock I assumed that some of the gasoline had evaporated out of the jugs while sitting in the dyno room shruggy
I have seen the same thing now in my fuel sitting in my plastic fuel jugs during the winter in my enclosed race trailer that sits outside all winter work Two winters ago it got down to -25F at night for several days that week, it freezes at night most of the winter here from mid October to at least mid March shruggy My message is it ain't hot in the trailer during the winter so it is not the heat causing the fuel change, maybe it is the plastic jugs work shruggy
Mine has tested to be right at E85 out of the pump to start with but ends up testing to be from E87 to E90 when it sits more than a month or longer in the plastic jugs work shruggy
