Re: 1970 Charger Full Build [Re: 70charger512] #2568713
10/24/18 02:45 AM
10/24/18 02:45 AM
AndyF Offline
AndyF  Offline
Originally Posted By Nick Stevanovski
So a lower LSA is actually better for the street?
No. Street cars have wide LSA, race cars have narrow LSA. First thing you need to do is figure out if you're building a street car or a race car. If you're building a street car you shouldn't be asking so many questions in the race forum. When you ask questions in the race forum you get answers from racers. Could be part of your confusion.......
Re: 1970 Charger Full Build [Re: 70charger512] #2568759
10/24/18 10:49 AM
10/24/18 10:49 AM
Washington
madscientist Offline
Washington
Originally Posted By Cab_Burge
On any BB Mopar big C.I. stroker motor you want a big carb, it is impossible to be to big whistling I would use a 108 LSA cam on your deal installed at or close to ,+ or - one degree at 104 on the intake lobes, that will give you more bottom end power with a small decrease in top end, upper RPM(above 6000 RPM) power work
That will make the stick shift motor a lot more fun and easy to drive on the street also devil grin up
Nothing wrong on planning ahead up
And this is exactly why you need to get on the phone and talk with someone who actually knows what they are doing and not some guy who is paid to answer phones and sell you a cam off the shelf.
Not to pick out any one company, but let's say my no name ass calls Comp. I'm a nobody. I'm going to get to talk to a dude whose job requires him to punch in some numbers in his computer and spit out a cam off the shelf. And maybe, if you are lucky, they'll move the LSA to make you think you are getting something worthy of what you should have.
If I call Cam Motion, I talk to the same guy every single time. When I was buying 10 cams a month, I developed a relationship with that guy, and he understood what I expected. Cam Motion never failed to deliver.
If you call Jones cams, you will talk to Mike Jones himself. We have different opinions on how things should be, so I didn't use many of his cams, but his stuff works and you get to talk to him, not some phone dude.
If I call Racer Brown, I get to talk to Jim. Jim answers the phone. Jim grinds every cam. On my last build, I had done some things most guys wouldn't do to a street engine. I also wanted to run 11:1 compression on pump gas (and did) and with my valve job and port work, I decided after spending way too much time on the flow bench, I needed to net .600 lift, even though the heads broke over at .500 lift and didn't gain it all back, but I got some back around .650 lift.
Jim was the ONLY one of the 5 cam grinders I called who even considered discussing why I wanted that much lift. Everyone else said I was wasting my time opening the valve that much.
In the end, I ended up with .620 gross lift and I net a bit over .600 and not because Jim caved and gave me what I wanted. I sent him copies of the flow sheets with my copious and boring notes. I also sent him a drawing of the cutter I used to the valve job so he could see what I was talking about.
In the end, the Racer Brown grind was about .060 or more lift than any other grinder said I should use, was a tight lash lobe and the LSA was nowhere near what anyone else thought it should be.
The engine will idle at 750, but I don't let it idle that slow. It doesn't idle any rougher that a 270 degree hydraulic but will pull to 7,000 all day long.
So sometimes it don't about the name on the box. It's about who you get along with that ends up getting you something worth the effort.
You just can't guess at an arbitrary LSA and say it's the magic number. It isn't. It's the sum of the events. It does make a difference for sure.
That's why I say put away your preconceived ideas of what you think you need. In fact, if I was building your engine, I'd be ordering the cam and not you, the customer. But that's how I did it.
Re: 1970 Charger Full Build [Re: AndyF] #2568764
10/24/18 11:04 AM
10/24/18 11:04 AM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
That's exactly what I thought, but Mr Cab said the lower LSA would be better for the street. I was thinking "man I know around where I should get for my LSA" then he answered that way and made me rethink. Before, his response I was 100% sure I should get a 110-112 LSA cam anyway. Im only asking in here because it's engine tech specifically too.
Re: 1970 Charger Full Build [Re: 70charger512] #2568768
10/24/18 11:13 AM
10/24/18 11:13 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
There are two hydraulic rollers from Howards Cams that I found that look to be in the right range, anyone have any experience with either of these:
1. 235/241 @.050, 110 LSA, 106 centerline, .545/.545 lift
2. 243/251 @.050, 109 LSA, 103 centerline, .530/.515
What exactly does the bigger difference in LSA and centerline mean, this would be installed 6 degrees advanced correct?
And what is affected when theres more intake lift than exhaust?
Re: 1970 Charger Full Build [Re: 70charger512] #2568769
10/24/18 11:13 AM
10/24/18 11:13 AM
Washington
Washington
If the above generalization is correct, why is my 98% street cam on a 105 LSA, installed on a 105 ICL?
It's difficult to make generalizations like that. I know that catalog cams all have a default LSA. Look at an Isky catalog. All that stuff is on a 108. Look at Comp. 99% of their stuff is on a 110.
That's why I hate catalog cams. There is never a reason to buy a cam off the shelf. LSA is a sum of the cam timing events and nothing more.
If you go to speedtalk.com and search for LSA and find dozens of threads where this has been hashed out and beat to death by some of the best minds on the web. Mike Jones is in some of them. David Vizard posts about LSA and those two don't always agree. The head dyno guy for one of the NASCAR teams posts in those threads and plenty of other guys who have forgotten more than I'll never know.
If you establish in your mind what ought to be, without enough background, knowledge and experience, you're going to have issues doing what you want.
I personally don't see a reason to build a pump gas engine at less that 10.5:1 for about anything. I may squeeze my junk to 11.5:1 later on. But you have to understand how everything else affects every other decision you make. Hell, I can't see any reason to use a 45* valve job on any performance build any more. I use a 50* seat. I can't think of a reason not to.
But that's just me.
Re: 1970 Charger Full Build [Re: 70charger512] #2568772
10/24/18 11:19 AM
10/24/18 11:19 AM
Washington
Washington
You are asking great questions. But you are asking the wrong people.
Call Howard's and ask them. Take notes. Then call 6,7 or even 10 other cam grinders and give them the exact same numbers and see what they say. Take notes. Then sit down and compare the answers.
Also, you should ask them why the split pattern cam? Are they adding exhaust duration, or reducing intake duration. Because it makes a difference.
I say they are reducing intake duration. Then they move the timing around on the exhaust side to get the LSA wider. This kills the all important mid range power, so the shift RPM will stay the same as if you put the intake duration back in and closed the LSA up.
With production style heads, I'm a big advocate of single pattern cams. The split pattern cams look cool on paper, but almost always they are down on power in the mid range. That's the worst place to give up power I can think of.
Get on the phone. Write down all the questions you can think of. Ask the cam grinders. Again, take notes.
You'll be surprised what you find.
Re: 1970 Charger Full Build [Re: 70charger512] #2568799
10/24/18 12:17 PM
10/24/18 12:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The actual overlap window, which has a large effect on idle quality and low speed response, is VERY different between 240° @ .050" & 112° LSA and 250° @ .050" & 108° LSA.
Averaging cam event timing is banging your head against the wall. Ask a good porting service what your heads like w/r/t in/ex bias.
Boffin Emeritus
Re: 1970 Charger Full Build [Re: TonyS451] #2568807
10/24/18 12:28 PM
10/24/18 12:28 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Originally Posted By TonyS451
My critique:
Don't mess with the cc of the heads. Get the right pistons that give you the desired compression ratio with the stock 78cc head. Hopefully you've been in touch with an engine builder to handle the machine work and assembly.
i posted a question in the other thread, i can't keep up with all the threads and i think it might've acutally been deleted.
Nick, why not build a 440/512 with a -17cc dish piston...you would get 10.5:1 compression (roughly) with a 78cc combustion chamber...
Re: 1970 Charger Full Build [Re: krautrock] #2568864
10/24/18 01:37 PM
10/24/18 01:37 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
My critique:
Watch out now he'll start another thread about building a 512 over the motor he wants now
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 1970 Charger Full Build [Re: 70charger512] #2568867
10/24/18 01:40 PM
10/24/18 01:40 PM
AndyF Offline
AndyF  Offline
You were on the right track before you got derailed. For your type of build I'd go with a cam that is 230's in duration at 050 and 112 LSA. The old Mopar 0.528 solid cam is a good street cam for a stroker big block. It is 236 duration and 112 LSA. Works great on the street and pulls hard to 6000 rpm.
What you are trying to accomplish isn't difficult. The shop I work with has five BB Mopar stroker engines on the floor right now in various stages of assembly. Any one of those engines would work just fine in your car. They are all pump gas strokers with aluminum heads and street cams. They will all make at least 500 hp and one or two might be closer to 550. Building engines like this is routine for some of us.
Re: 1970 Charger Full Build [Re: 70charger512] #2568869
10/24/18 01:45 PM
10/24/18 01:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
108 lsa here installed at about 105 street/strip car, 470 stroker 6.15 at 112+ mph in the 1/8 9.6 in the 1/4 now it's more than you are looking for but PLENTY street-able just check out my video on here titled :How do I post a you tube video on here"...........Another approach I make when picking a cam as I have Isky grind mine, is weight.....heavy car and less powerful motor, less duration, lighter car good power, more duration........This is one of many other factors involved............... thumbs
Re: 1970 Charger Full Build [Re: AndyF] #2568904
10/24/18 02:44 PM
10/24/18 02:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
230 @ .050 at those cubes? Not how I would go as the cubes will make it purr like a kitten not roar like a TIGER......I know you build this n that Andy and if mellow is the goal then he should be REAL happy.......... whistling
Re: 1970 Charger Full Build [Re: krautrock] #2568918
10/24/18 03:04 PM
10/24/18 03:04 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
My critique:
Not a bad idea at all, if i can keep the .030 over id gladly do that, but i dont know what condition it is in. We will just have to see when its apart.
