Re: Actual track results - diff vs. spool
[Re: StealthWedge67]
#2568773
10/24/18 11:21 AM
10/24/18 11:21 AM
Posts: 3,081 Michigan
A727Tflite
This is most likely a case of “the whole is more than the sum of the parts”. “High performance” is usually not a piece by piece equation. When we do testing we don’t make 9 changes and hope for an improvement. Oh well, onward and upward. That’s not what I was suggesting at all. It is more than plausible in my opinion however that you could measure each of these modifications in a vacuum by themselves and see no improvement with any single one of them. But when the right ones are hooked together; bam...... a full tenth. I see your point now, thanks for clarifying. And yes, I agree with you now.
[Re: justinp61]
#2568790
10/24/18 12:05 PM
10/24/18 12:05 PM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
Don Which fans were you running? Electric fan= Derale..... nice unit......Moroso billet water pump Stock was stock production fan setup and waterpump
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2568823
10/24/18 12:44 PM
10/24/18 12:44 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Don Which fans were you running? Electric fan= Derale..... nice unit......Moroso billet water pump Stock was stock production fan setup and waterpump Thanks. I have the MP viscous fan kit on my Dart and am curious if there was enough gain to justify the cost to change over. My deal is street/strip so if I changed it would have to work on the street too.
[Re: A727Tflite]
#2568831
10/24/18 12:57 PM
10/24/18 12:57 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I changed too much at once to do a back to back on the stock water pump vs electric. But the quick cool down between rounds is priceless, I can be ready for another run in minutes. I have also had no problems on the street.
68 Barracuda Formula S 340
[Re: A727Tflite]
#2568859
10/24/18 01:32 PM
10/24/18 01:32 PM
Posts: 878 Missouri
jwb123
Missouri
Few companies make them any more, but I have had some decent results with the 4-2-1 type collectors, they pick up the low end torque. I built my current headers and used a set of Hedmans on it and they are about 1/2 tenth quicker. compared to a standard 4 into 1 style collector.
[Re: justinp61]
#2568890
10/24/18 02:26 PM
10/24/18 02:26 PM
B3422W5
Portage,michigan
Don Which fans were you running? Electric fan= Derale..... nice unit......Moroso billet water pump Stock was stock production fan setup and waterpump Thanks. I have the MP viscous fan kit on my Dart and am curious if there was enough gain to justify the cost to change over. My deal is street/strip so if I changed it would have to work on the street too. I have done water pump and fan at the same time, never one or the other at same time.
[Re: A727Tflite]
#2568916
10/24/18 03:00 PM
10/24/18 03:00 PM
Posts: 3,516 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
My notes below
1) Going from 11” drum brakes to drag race weight disc brakes My experience was going from ten inch drum brakes to four wheel disks, I saved forty pounds but did not pick up any ET or MPH that I could tell. However it sure stops a lot better and I would do it again. Dual calipers on the back are very much like having a transbrake.
2) Merge collectors vs. standard I have them on a 2 hp per CI small block but no AB tests. 3) Eliminating the water pump drive ( going to electric drive drive ) There is a good episode on "Engine Masters" where they tested this, big gain if I remember plus the ability to cool faster between runs and mentioned by Bad340Fish. Meziere would be my choice if for no other reason their great support.
5) 904 vs 727 with 2.45 low gear. ( heard .10 e.t. reduction ) The low gear may or may not help you but the 904 is worth at least a tenth.
8) Diamond piston versus old cast piston used in item 7. In my opinion anything you can do to raise the compression, use thinner rings and have lighter recpicating weight will help. Even at the same horsepower things that will help the engine accelerate faster will help on the track. (My opinion).
You did not mention it but in my experience, documented on the dyno, vacuum pumps make horsepower in engine with gas ported pistons, thin rings and low tension oil rings. Your mileage may vary.
Good luck and let us know your experiences.
Bill Lamb
[Re: A727Tflite]
#2568937
10/24/18 03:40 PM
10/24/18 03:40 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Getting rid of the stock clutch fan, but keeping the belt driven water pump dropped my ET a tenth on a high 11 sec combo.
Going to an electric water pump over a belt driven pump (electric fan already installed) dropped the ET another tenth on a mid 10 sec combo. These tests were all done w/ 440 engines in my cuda.
[Re: justinp61]
#2568997
10/24/18 05:21 PM
10/24/18 05:21 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Don Which fans were you running? Electric fan= Derale..... nice unit......Moroso billet water pump Stock was stock production fan setup and waterpump Thanks. I have the MP viscous fan kit on my Dart and am curious if there was enough gain to justify the cost to change over. My deal is street/strip so if I changed it would have to work on the street too. Do it, leave it off for quicker warm ups, cools stupid fast between rounds or after you park on the street and the et gains are real as others eluded to me included picked up a couple tenths going to elec. fan and pump.....
[Re: Thumperdart]
#2569073
10/24/18 07:48 PM
10/24/18 07:48 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
[Re: A727Tflite]
#2569249
10/25/18 08:34 AM
10/25/18 08:34 AM
Posts: 287 PA
Harry's Taxi 2
PA
I remember an article by Cecil Yother (maker of leak down testers, torque plates etc.) saying a limited slip differential was quicker than a spool in his high 10 second 70 cuda.
I don't recall many other details from that article except that it was flat top piston, iron head 440, auto trans. I'm not even sure what tire size, but I think it was leaf spring equipped ....I wish I could find the article.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
