Page 30 of 48 1 2 28 29 30 31 32 47 48
Re: Modern Bullitt build [Re: ] #2520915
07/12/18 09:21 AM
07/12/18 09:21 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By Superfreak
Good lord that looks awesome.
Thank you sir!
Re: Modern Bullitt build [Re: Keepat] #2528566
07/29/18 11:48 AM
07/29/18 11:48 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I picked up all the new tinted glass for the charger at Carlisle 2 weeks ago. So I put the vent windows together using Metros vent window gaskets. The gaskets fit great and required no modifications. I tested all of the new window glass against my original glass and for the most part the cut and shape seems to be very close, however the etched labeling for the vent windows was not only on the wrong side but it was also much larger than my originals. Ordered the tinted glass as that’s what the original Bullitt charger had.
I had all of my original vent parts re-chrome by Paul’s two years ago, and I polished stainless steel. I used a commercial grade black double stick tape to reattach the lower chrome trim to the vent glass. (This worked very well on my 1st Charger 10 years ago) There are 6 raised rivets that are part of the chrome vent Frame used to hold the steel track in place. And on the two chargers I have restored the factory only uses 3 of these which makes it very easy to reattach the chrome to the steel frame in the same manner that the factory did buy peening over the rivets to hold the frame. Be careful peening over the small rivets as the metal is soft and you can dent the other side easily which I found out on my 1st Charger 10 years ago. Then reinstalling the vent glass along with the stop pin and locking handle is relatively easy after cleaning out any excess chrome plating left behind in the small holes.
Thanks!
Re: Modern Bullitt build [Re: Keepat] #2548655
09/11/18 04:13 AM
09/11/18 04:13 AM
Medford OR
FrankenScamp Offline
Medford OR
Hope all’s well.
popcorn
Re: Modern Bullitt build [Re: Keepat] #2563494
10/13/18 06:29 PM
10/13/18 06:29 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - hope all is well! We need our fix!
Re: Modern Bullitt build [Re: Keepat] #2568224
10/23/18 09:39 AM
10/23/18 09:39 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
All is well, just took a little brake from the Charger to work on a surviver 1934/64 Chevy Gasser
Pat
Re: Modern Bullitt build [Re: Keepat] #2569199
10/25/18 12:59 AM
10/25/18 12:59 AM
Medford OR
Medford OR
Thanks for checking in. Have fun with the Chevy. up
Re: Modern Bullitt build [Re: Keepat] #2569531
10/25/18 10:10 PM
10/25/18 10:10 PM
New Jersey
Vinny P Offline
Vinny P  Offline
New Jersey
Pat,
GREAT looking wheels! However, the center cap scale seems small in comparison to what I imagine would be necessary to accommodate the 4.5" bolt pattern. How would the center caps mount? I can't wait to see them on the Charger.
Thank you,
Vinny
Superbird B5 4 speed console black buckets
A12 Super Bee Bahama Yellow 4 speed black bench
Re: Modern Bullitt build [Re: Keepat] #2582770
11/25/18 12:59 PM
11/25/18 12:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Just starting the restoration and polishing of all of the exterior stainless steel. Fun!
Pat
Re: Modern Bullitt build [Re: Keepat] #2582823
11/25/18 02:43 PM
11/25/18 02:43 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Excellent!
Back in the saddle!
Re: Modern Bullitt build [Re: Keepat] #2583293
11/26/18 05:00 PM
11/26/18 05:00 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Re: Modern Bullitt build [Re: Keepat] #2584228
11/28/18 04:01 PM
11/28/18 04:01 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Quite a difference, nice.
Re: Modern Bullitt build [Re: Keepat] #2585121
11/30/18 12:27 PM
11/30/18 12:27 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
Nice work I still just absolutely love your wheel idea, This is going to be a cool car.
Re: Modern Bullitt build [Re: Keepat] #2585237
11/30/18 04:10 PM
11/30/18 04:10 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Where did you get the polishing wheel from?
69 GTX 68 Road Runner
Re: Modern Bullitt build [Re: CDN72SE] #2585411
11/30/18 10:55 PM
11/30/18 10:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
A lot of work to get stainless to look like chrome but it’s getting there
Thank you
Re: Modern Bullitt build [Re: UCUDANT] #2585415
11/30/18 10:57 PM
11/30/18 10:57 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you, I’m so looking forward to seeing those wheels on the car again, as it’s been so long since I’ve seen them :-)
Re: Modern Bullitt build [Re: JERICOGTX] #2585416
11/30/18 10:57 PM
11/30/18 10:57 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
https://www.tptools.com/TP-Tools-Buffers.html
Re: Modern Bullitt build [Re: Keepat] #2597390
12/27/18 12:59 AM
12/27/18 12:59 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The original Inland shifter had a mechanical reverse lockout which was disengaged with the T handle. The Tremec 6 speed also has an reverse lockout, but it is operated by a 12v solenoid. So I modified a door jam domelight switch to fit inside and added a top spring to hold tension on the T handle. This will either directly operate the negative side of the solenoid or a relay? I haven’t quite decided how I will wire that in yet. I just need to add a slight dogleg bend to the shifter, weld on the 2x1x1/2” mount block and then send it out for Chrome;-)
Re: Modern Bullitt build [Re: Keepat] #2597516
12/27/18 12:15 PM
12/27/18 12:15 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Very clever Pat! Nice work.
Re: Modern Bullitt build [Re: Keepat] #2600258
01/02/19 01:11 AM
01/02/19 01:11 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I’m using the American Autowire classic update series harness. Very nice harness as it uses all of the original connectors. None of the ends are installed so you can adjust the length of the wires as you see fit, along with having all of the additional wires needed for a modern car such as electric fan, electric fuel pump, door locks, power seats and power windows. It looks original with the same color code, but with one nice addition all of the wires are labeled every 4 inches. Instrument panel worked out great!
A few modifications along with a couple brackets I made to hold the new fuse box securely, with access from the glove box.
Need to paint the gray plastic face plate black to finish it off.
Pat
Re: Modern Bullitt build [Re: Keepat] #2600330
01/02/19 09:15 AM
01/02/19 09:15 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - impressive work on the dash and wiring! That harness kit is pretty interesting.
