of the dyno SB #2567218
10/21/18 11:02 AM
10/21/18 11:02 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
i had my little r block w7 dynoed it is nothing to flash 12.6 comp 4 inch stroke 4.100 bore early w7 heads 2.100 intake 1.6 exhaust smallish headers 1 7/8 stepped to 2 inch with 3 inch collector 1050 dom pump fuel here ,here are the aspirated run and then a sniff of gas ,some of you guys may have seen it on fb
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: of the dyno SB [Re: Ian] #2567256
10/21/18 12:34 PM
10/21/18 12:34 PM
New York, USA
Chargerfan68 Offline
New York, USA
Wow. Nice numbers!!! Thats crazy though....an instant 120 hp from the shot of gas. Thats gotta be tough on parts. Must be sick when in the car and hammer down. Im happy even with those NA numbers. Congrats!!
Re: of the dyno SB [Re: Ian] #2567269
10/21/18 01:08 PM
10/21/18 01:08 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Thats some good numbers!
Re: of the dyno SB [Re: Ian] #2567405
10/21/18 06:17 PM
10/21/18 06:17 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I would be happy with that !great numbers
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: of the dyno SB [Re: Ian] #2567415
10/21/18 06:34 PM
10/21/18 06:34 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks guys here is a link to vid https://www.youtube.com/watch?v=LR0g61HWX7M
Re: of the dyno SB [Re: Ian] #2567419
10/21/18 06:43 PM
10/21/18 06:43 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's really impressive....wow.
Re: of the dyno SB [Re: Ian] #2567426
10/21/18 07:02 PM
10/21/18 07:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Bad ass................... drive punkrocka
Re: of the dyno SB [Re: ZIPPY] #2567437
10/21/18 07:35 PM
10/21/18 07:35 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks man
Re: of the dyno SB [Re: Ian] #2567499
10/21/18 10:24 PM
10/21/18 10:24 PM
It would be interesting to see what it would make at 8500 RPM also work scope
I wouldn't be a bit surprise to see it down from 3 to 7 HP from peak HP work devil
Same thing with the NOS shruggy
Congrats on good results also bow up
Re: of the dyno SB [Re: Ian] #2567511
10/21/18 10:48 PM
10/21/18 10:48 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Thanks for sharing awesome build can't wait to see how it runs in the car
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: of the dyno SB [Re: Cab_Burge] #2567534
10/21/18 11:20 PM
10/21/18 11:20 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
you are right, i left a fair bit on the table in the tunes and build there was another 15 cfm of air up top i did not get too because of lift this has only 2.100 valve no vac pump etc nitrous tune was rich and i would take that to 8200 in the car lol
Re: of the dyno SB [Re: Ian] #2567541
10/21/18 11:27 PM
10/21/18 11:27 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Really nice numbers...Could you share cam specs?
Re: of the dyno SB [Re: dizuster] #2567550
10/21/18 11:38 PM
10/21/18 11:38 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
custom cam in the 270s and 420 lobe and it cost me aspirated hp it trades of cylinder pressure so it runs on junk fuel
Re: of the dyno SB [Re: WHITEDART] #2567553
10/21/18 11:43 PM
10/21/18 11:43 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks man she will not run like your girl lol at 3600 lbs i hope for a 9.90 in street trim then a 8.90 on the gas but as you know you got to get it down the track cheers
Re: of the dyno SB [Re: Ian] #2568617
10/23/18 10:16 PM
10/23/18 10:16 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
he are the graphs n/a and nos it has a good flat torque curve
