Project 470 Finished!!!!! Dyno Results #2566767
10/20/18 01:47 AM
10/20/18 01:47 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
It’s been a long time since I’ve posted any progress on project 470 ci however today the 470 was on the dyno and made 603 horsepower and a real nice flat torque curve with 627 ft lbs all happening under 6000 RPM!! Until Moparts becomes Apple friendly, I refuse to post any pictures so don’t ask me to post the dyno sheets.
My customer was very happy with the results. Not bad for a engine with a smallish hyd rolller and a dual plane intake. The Thumper 950 carb from Dominic rocked out of the box!!!!!
Next project will be another 505 RB with a set of Trick flow 270’s bolted on!!! Stay tuned and hopefully by then I can kick back and post away with picks of the build from my IPad.
Oh, I almost forgot to mention that the girdle with the aluminum caps did not blow up and fail as some hoped for on Moparts and......... drum roll please........ the beehive springs operated flawlessly with the Hughes rocker arms......... NEXT!
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566790
10/20/18 02:53 AM
10/20/18 02:53 AM
AndyF Offline
AndyF  Offline
Nice numbers. Was that with Trick Flow 240 heads?
Re: Project 470 Finished!!!!! Dyno Results [Re: AndyF] #2566793
10/20/18 02:56 AM
10/20/18 02:56 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Std port Victors
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566806
10/20/18 03:45 AM
10/20/18 03:45 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Was a cool project to be part of with more to come.......dual plane, good power and should be a nice fun ride..... thumbs
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566816
10/20/18 05:52 AM
10/20/18 05:52 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Just dropped off a 400 block yesterday to get machined,using BB Chevy H beam rods,440source 3.915 stroke crank,custom pistons and being built for Trick Flow heads.
Is there a post somewhere with the specs on yours?
What’s the trouble posting pictures? I have been posting some from my iPhone,pretty straight forward.
who is that guy?
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566825
10/20/18 07:23 AM
10/20/18 07:23 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
That's making some good power. I'd be interested in hearing the specifics of the build, as well.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566839
10/20/18 09:43 AM
10/20/18 09:43 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Congrats, is this not for one of your vehicles?
Posting pics is easy. I use several different devices apple, android, pc, whatever, it all works the same. The main problem is most phones are set to take huge pics these says and Moparts seems to prefer 640x480.....
Re: Project 470 Finished!!!!! Dyno Results [Re: ZIPPY] #2566845
10/20/18 10:13 AM
10/20/18 10:13 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
This build was for a friend. I have tried to resize the pictures with little to no luck. Other car forums automatically resize the pictures you post. When I built my first 505 ci in 2014 posting pictures on Moparts from my phones was easy. Not anymore.
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566855
10/20/18 10:49 AM
10/20/18 10:49 AM
S.E. Michigan
S.E. Michigan
Yep gotta jump through a few flaming rings of fire to post 'em these days, it seems. Holler if you need help.
Well sounds like a really nice engine. Victors are plenty viable, that's for sure.
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566857
10/20/18 11:04 AM
10/20/18 11:04 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Sorry if I missed a previous thread but I'd like to hear specs as well. Planning my own 470" with Trick Flow 240s, hydraulic roller and a Performer RPM intake shooting for 600 hp.
'71 Duster
'17 Ram 1500
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566875
10/20/18 11:58 AM
10/20/18 11:58 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I like the idea of the beehive springs. Were they the recommended spring or did you just determine your own parameters?
If I can post pics from my Samsung Galaxy J3, I'm sure that there is a fairly established path to do it from your Apple.
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566877
10/20/18 12:03 PM
10/20/18 12:03 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Nice build! Years back I built a 470 with standard port Indy SR and 255@.050 solid ft, m1 and 950 carb. Made almost identical power, 605 /590 iirc. Loved that engine and got my 4000lb wagon to run 11.0's, and street driven everywhere. I'm guessing the standard port SR and victors are pretty similar.
2 kids and a dog
Re: Project 470 Finished!!!!! Dyno Results [Re: TonyS451] #2566879
10/20/18 12:10 PM
10/20/18 12:10 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
more or less .. just like my 470
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Project 470 Finished!!!!! Dyno Results [Re: RMCHRGR] #2566880
10/20/18 12:12 PM
10/20/18 12:12 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
This build has the following:
73 400 block .030 over
K1 3.91 crank
Molnar H beam rods Chevy journal
BRC aluminum main caps. Best in the industry!!!!!!!
Hughes girdle. I know they don’t work but they work great for my builds!!!!!
Diamond pistons custom 10:7 comp
Custom plastic windage tray/ gasket. Mancini and Summit sell them
Milodon 7 quart pan with 1/2” pickup
Std volume oil pump
Std port Victor heads ported by yours truly flowing
314 @ .500 lift In / 220 Ex
Hughes Hyd roller 550 lift 240 duration installed at 106
PAC beehives springs rock!!!!!
Hughes rockers
Trend pushrods
E performer RPM intake ported by yours truly
Thumper 4150 carb that flows lots of air indeed!!!
MSD pro billet distributor
Massive TTI 2” step headers
Re: Project 470 Finished!!!!! Dyno Results [Re: sgcuda] #2566882
10/20/18 12:22 PM
10/20/18 12:22 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
For street builds I only use beehives or conicals. The guys at PAC springs have done more testing on these types of springs than anybody else so if some want to stay stuck in the 70’s with a inefficient, heavy and unnecessary high pressured dual springs be my guest.
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566906
10/20/18 01:30 PM
10/20/18 01:30 PM
AndyF Offline
AndyF  Offline
Looks like a nice solid build. I think I'm going to sell the 470 that I ran last year since I have a few too many engines sitting on stands. They sure are great engines.
In an alternate universe the Chrysler engineers put a 470 six pack into production in 1970 and ate the Chevy big block for lunch.
Re: Project 470 Finished!!!!! Dyno Results [Re: AndyF] #2566914
10/20/18 01:54 PM
10/20/18 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I've never driven or rode in a 500+ ci Mopar but these 470's scream and make very respectable power...........
Re: Project 470 Finished!!!!! Dyno Results [Re: ccdave] #2566921
10/20/18 02:11 PM
10/20/18 02:11 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
What headers did you run on the dyno, were they 2" primary? 2" can be tough for non race-car stuff.
Also, how extensive was the porting on the intake? Did you take the divider out? Did you use a spacer?
'71 Duster
'17 Ram 1500
Re: Project 470 Finished!!!!! Dyno Results [Re: AndyF] #2566942
10/20/18 03:19 PM
10/20/18 03:19 PM
Granbury TX
Prochargedmopar Offline
Granbury TX
What is the benefit of the 470 over a 451?
My guess is:
19 cubes, slightly lighter piston and slightly longer stroke.
Is that it or is their something more I'm missing?
Thanks.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Project 470 Finished!!!!! Dyno Results [Re: RMCHRGR] #2566953
10/20/18 03:48 PM
10/20/18 03:48 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
The headers are TTI 2” headers. According to TTI, they will bolt right it to the 70 roadrunner. The intake was port matched and the divider was taken down to 3/4”. I also blended back all of the turns and pulled a lot of metal out just under the carb opening. A half inch 4 hole spacer was used.
