clear coating over vinyl graphics? #2566502
10/19/18 03:02 PM
10/19/18 03:02 PM
IL . usa
cjs69mope Offline OP
IL . usa
Wondering if it can be done or is this a no no?
69 super bee would like to clear over tail stripe.
1969 Dodge Charger 1969 Dodge Superbee
Re: clear coating over vinyl graphics? [Re: cjs69mope] #2566524
10/19/18 03:47 PM
10/19/18 03:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There a V code 71 Challenger R/T that is out here that had this done.
Personally I think it looks terrible, but it can be done
Re: clear coating over vinyl graphics? [Re: Morty426] #2566569
10/19/18 04:58 PM
10/19/18 04:58 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
May be better to mask the stripe and paint in on instead. Vinyl may shrink over time would be my concern.
Re: clear coating over vinyl graphics? [Re: cjs69mope] #2566661
10/19/18 09:31 PM
10/19/18 09:31 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
On my old Yamaha Enduro gas tank, I had vinyl letters cut, put them on over the base coat and then cleared over them. Been 7 or 8 years now and they look good, no problems.
Master, again and still
Re: clear coating over vinyl graphics? [Re: cjs69mope] #2566692
10/19/18 10:16 PM
10/19/18 10:16 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I had a car that had it done before I got it... it was like that for years before I got it. Clear will protect it from the sun, uv rays etc. It's not something I personally will do, but no reason it won't work. One thing is spraying enough clear to where you can wetsand/buff it smooth if that's the plan. If it's an original stripe I want to keep, then I mask it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: clear coating over vinyl graphics? [Re: Silver70] #2566724
10/20/18 12:13 AM
10/20/18 12:13 AM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
I have painted several pulling tractors, and have done this many times. I have even sprayed clear coat over a partial vinyl wrap. I have not had any issues with any of them. At first I would put the decal directly over the base coat, then clear coat it. But on the last few due to the small margin for error, when there is no clear coat, I have been spraying a couple coats of clear, then wet sanding with 1500, before the decal. Then spray a couple more coats of clear, then cut and buff.
The other problem with putting decals directly over the base, without clear, is if there is a dust particle in the base, the decal may have a bump in it that will possibly get sanded through when cutting and buffing.
68 Gold Met. 383-4spd Roadrunner 69 T5 Hemi 4-spd Roadrunner 70 Limelight 440-6 Auto Superbird
