727 won’t kickdown #2566465
10/19/18 02:01 PM
10/19/18 02:01 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
If I floor my t/a in 3rd it will not kick down. How can I fix?
1970 EK2 T/A 727
Re: 727 won’t kickdown [Re: f2502011] #2566471
10/19/18 02:14 PM
10/19/18 02:14 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
How fast are you going? Is the “kick down” linkage attached and adjusted? Stock carb? Auto shift trans?
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 727 won’t kickdown [Re: FurryStump] #2566506
10/19/18 03:10 PM
10/19/18 03:10 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
30 or less, yes to everything else
1970 EK2 T/A 727
Re: 727 won’t kickdown [Re: f2502011] #2566556
10/19/18 04:32 PM
10/19/18 04:32 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Make sure WOT at the pedal is WOT at the carb and the transmission lever.
IOW, have somebody sit in the car and floor the pedal then, from under the hood, push back on the carb lever to see if it's at WOT and then push back on the trans linkage to see if the lever is near full back.
