Page 1 of 5 1 2 3 4 5
440 daily driver (550 hp, 600 ft-lb tq) #2566114
10/18/18 08:01 PM
10/18/18 08:01 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
I am deciding to make yet another thread, since obviously most people wont read and reply to each post on my other threads. So to keep it simple, first heres the link to my original idea: Original 440 build
Fyi it will be a manual 5 or 6 speed, but most likely a 6 speed (tko600 or t56)
1. I have since decided to get the SD intake, and most likely a hydraulic roller cam.
2. If i want to make that power and torque with essentially everything the same, would i need to stroke it?
3. When it comes to a cams operating rpm, if its a 2200-6000 would i have to rev higher in first gear to move it on the street compared to a 1800-6000? Thats what i need to really understand.
4. Any suggestions on hydraulic roller cams (for w/ a stroker or w/o a stroker)? (And preferably with an operating rpm that begins anywhere from idle-2200 and goes to 5800 or more, if im not wrong on how operating rpm works)
5. I may edit this post (and italicize the changes) if i forgot to mention anything
6. What does everyone think about the lunati 60311? Would it work good with either the stock stroke or stroker? Adv duration: 270/278, duration @.050: 219/227, .515/.530 lift, 112 lsa/106icl
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566118
10/18/18 08:22 PM
10/18/18 08:22 PM
Kirkland, Washington
Pacnorthcuda Offline
Nick, as you know, I run the Lunati 60303 cam
440 .030 over
Oob Stealth heads
.017 below deck, Cometic .027 gaskets for quench
10.2 Compression ratio
Eddy RPM
Holley 850 DP
Headers
833 4 speed, 3.55 gears, 28 inch tires.
Cam was degreed, came in at 106.75. (Was supposed to be 106). I ran it that way for a year or so then advanced 2 degrees to 104.75-----I was bored, don't get too caught up in this detail.
I can pull away from a stop at 1000-1500 rpm as long as I'm light on the throttle until 1900 rpm, then full throttle is OK (and of course will fry the tires).
What I CANT do is pull away from a stop at less than 1900 under moderate or heavy throttle----if I do the engine will lug.
It's all about split second timing of the clutch vs throttle--that's all.
Similarly, I can cruise in 3 or 4th gear at 1500rpm, as long as throttle is LIGHT--if I want to accelerate from this condition I either stay gentle till 1900, or downshift.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566123
10/18/18 08:29 PM
10/18/18 08:29 PM
And yes, I think if you are after a true 550hp at the wheels below 6000rpm, you will need a stroked motor. (Unless you go with a power adder of course)
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: Pacnorthcuda] #2566126
10/18/18 08:31 PM
10/18/18 08:31 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
440 .030 over
Oob Stealth heads
Eddy RPM
Holley 850 DP
Headers
Thank you for your reply, and thats why i wanted the 60303 cam, but was told it will limit my numbers well below the 550 hp mark. What are you making?
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: Pacnorthcuda] #2566132
10/18/18 08:35 PM
10/18/18 08:35 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
And no, sorry not 550 at the wheels (i wish). At the crank.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566135
10/18/18 08:47 PM
10/18/18 08:47 PM
I've never dynoed it, so anything I state is a guess. If I give myself a WIDE range, low to high, I would say
425-525 flywheel hp........I'm sure reality is in there somewhere...LOL.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: Pacnorthcuda] #2566160
10/18/18 09:49 PM
10/18/18 09:49 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Lol, any guess on the torque, because id be more than happy with 525? (assuming ur on the high end lol)
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566175
10/18/18 10:13 PM
10/18/18 10:13 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Have you driven a 440 before? Chances are you could put that cam in a basic 10-1 short block and slap on OOTB or preferably mildly work heads and have a lot more fun than bench racing like this. It’s really no sweat changing the cam later if you find it doesn’t do what you want.
Unless you hit the mega millions or poweball you might find dollars spent on a mild almost stockish build go further than going hog wild right off the bat. You need to find a local machine shop you can trust or spend the money you’d otherwise spend on fancy stuff shipping in mopar specialist worked over equipment.
I want my fair share
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: SomeCarGuy] #2566182
10/18/18 10:37 PM
10/18/18 10:37 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Originally Posted By SomeCarGuy
Have you driven a 440 before? Chances are you could put that cam in a basic 10-1 short block and slap on OOTB or preferably mildly work heads and have a lot more fun than bench racing like this. It’s really no sweat chsngingthe cam later if you find it doesn’t do what you want.
Yes....i drive a 440 every day. And id rather not do trial and error starting with a very basic build. Itd be way cheaper and simpler to figure everything out in the beginning. Thats why i have asked so many questions and made so many posts.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566207
10/18/18 11:18 PM
10/18/18 11:18 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Can i only get replies on this thread about the questions i asked? If you have a suggestion or experience with something i brought up on the other thread pls post it on there, the point if this thread was for it to be as simple as possible.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566218
10/18/18 11:43 PM
10/18/18 11:43 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You are not going to make 600 torque without 500 cubes.
You are not going to make 550 HP with a 219 at .050" cam, hydraulic roller or flat tappet.
Does that help?
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566222
10/18/18 11:52 PM
10/18/18 11:52 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
"Default 500hp" (525hp) BB combo
_ since you asked...the default 600hp combo
_still the default 500 HP street/strip combo
You are not (re)inventing the wheel. You'll need a cam in the mid 250 @.050" to get it done and good heads. Even with a stroker motor.
So it's decision time, are you looking for the HP/TQ numbers or seeking validation for the cam you picked out? twocents
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566270
10/19/18 01:07 AM
10/19/18 01:07 AM
SomeCarGuy Offline
SomeCarGuy  Offline
The problem is you are going to do precisely trial and error with what you keep posting. You clearly don’t have the experience in the hobby many have on here, evidenced by not understanding cam selection. HP level, RPM range, etc are not the real deal.
People have given you the gospel over and over and over. The only question left to ask at this point is will you accept it?
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: SomeCarGuy] #2566278
10/19/18 01:26 AM
10/19/18 01:26 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
And id rather do trial and error on forums than on my car. Every cam suggestion i have gotten starts with an rpm range at 2500 or above. That is why im asking questions. No i havent built an engine. Why do u think im here. Youre right i dont have the complete knowledge on every aspect of motors. thats why im here. I even asked someone to help explain to me how operating rpm ranges affect performance and street use. So congratulations you pointed out that someone that has asked alot of questions is not an expert. Are you proud of yourself? Its not much of an achievement. So are you going to help answer my questions or continue to exert your superiority of engine knowledge? If youre not here to help dont respond.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: Skeptic] #2566279
10/19/18 01:27 AM
10/19/18 01:27 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
In a way you could say im seeking some sort of validation. Since the other guy wasnt even willing to help, would you care to educate me on camshaft operating rpm ranges? The reason i keep picking cams with less duration is their rpm ranges. I asked the question in number 3 on the original post. So could you help answer that? Thanks
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566280
10/19/18 01:29 AM
10/19/18 01:29 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Yep, you don’t learn. Still hung up on same stuff. You might try a book. It won’t talk back when you reject it.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566282
10/19/18 01:35 AM
10/19/18 01:35 AM
Nick,
You are filling in the blanks for the variables that affect your specific issue.
Like this...
You want 550hp
You don't want to spin the motor past 6000
Those two specifics dictate a cubic inch requirement that is likely higher than 440...likely.
Now you add in the requirement that it be a stump puller (my words) off idle
Now your REALLY making things difficult, if not impossible.
Does that make sense?
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: SomeCarGuy] #2566286
10/19/18 01:54 AM
10/19/18 01:54 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Show me how im hung up. All you were able to do is say i am not an engine builder.
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: Pacnorthcuda] #2566288
10/19/18 01:59 AM
10/19/18 01:59 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Nick,
Like this...
You want 550hp
But strokers greatly increase low end torque correct? So its very difficult to have a good street driving 550 hp 440?
Re: 440 daily driver (550 hp, 600 ft-lb tq) [Re: 70charger512] #2566303
10/19/18 02:55 AM
10/19/18 02:55 AM
Nick,
Like this...
You want 550hp
Well "good street driving" is kinda vague and people define it differently, but you seem to be caught up in the fact that a performance cam won't pull like a freight train from 1000 rpm. It won't. But it's not a big deal, at least the way I define "good street driving".
When it comes to camshaft selection, IF max RPM is a big factor for you (that's OK...MAX RPM is a big factor for many people and many engines!!!!!). Then a good selection technique is to select a cam with a max powerband that matches your max expected RPM.
After all....why select a cam that's good to 6500 when you never expect to use it?
The Lunati 60303 has a max powerband of about 6000, it's therefore a reasonable choice for you BASED ON MAX RPM.
Now with that comes a minimum.....call it 2000. You have to live with it (at least in terms of THIS cam), but a powerband that starts at 2000 is pretty damn good, for a performance cam.
If you select a cam that's lower....you're rapidly entering the realm of low-PO / stock cams and you simply are NOT going to make big power numbers.
For example, you might find a cam whose powerband starts at 1500, but it's not going to make big power at 6000, and it's not going to reach your 550 hp goal.
