915's on a 400
#256610
03/17/09 09:46 AM
03/17/09 09:46 AM
Posts: 417 jamestown, ny
71scamp440
Hinged
Hinged
jamestown, ny
will i have any problems running a set of 915 heads on a 400 block from the early 70's? the block and all internals are factory specs. and will the cup style push rods for the 915 heads work in the 400 block? any info will help. thanks guys.
71 scamp
big block with 915 heads
727 trans
Re: 915's on a 400
[Re: Mr.Yuck]
#256613
03/17/09 11:09 AM
03/17/09 11:09 AM
71scamp440
Hinged
Hinged
jamestown, ny
no upgrades to bottom end. 60303 voodoo cam, eddy performer intake, eddy 750 carb on top. as far as the push rods go, i just figured that one out myself.
71 scamp
727 trans
Re: 915's on a 400
[Re: JohnRR]
#256614
03/17/09 11:09 AM
03/17/09 11:09 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
915's were only installed on 440's originally so NO the pushrods you have if off a 440 wil NOT work because they will be to long .
whoops yeah totaly wasn't thinking about that... your push rods should be fine.
Re: 915's on a 400
[Re: Mr.Yuck]
#256615
03/17/09 11:52 AM
03/17/09 11:52 AM
RapidRobert
get a set of steel shim head gaskets to match your originals & you're all set. I missed the pushrod length deal also
