'68 Lynch Rd fender tag question #2565107
10/16/18 10:25 PM
10/16/18 10:25 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Would they be any different for a '68 Road Runner than the '68-up ones are?
The tag I'm looking at looks & reads exactly like my St Louis '68 Road Runner.
Re: '68 Lynch Rd fender tag question [Re: topside] #2565250
10/17/18 09:37 AM
10/17/18 09:37 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
A 68 tag will look the same. All plants used the abc format.
1969 model year is when the layout changes and Lynch Road tags start to look different..
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '68 Lynch Rd fender tag question [Re: topside] #2565336
10/17/18 01:25 PM
10/17/18 01:25 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks. None of the decoders I could find were clear on that.
Wonder why Lynch Rd decided to re-invent the tag for the '69s?
Re: '68 Lynch Rd fender tag question [Re: topside] #2565362
10/17/18 02:24 PM
10/17/18 02:24 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Mopar tags all changed in 1969. Lynch Rd did it a bit different than the rest.
Re: '68 Lynch Rd fender tag question [Re: topside] #2565371
10/17/18 02:32 PM
10/17/18 02:32 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Yeah, I'm well aware of that, just always wondered why the Lynch Rd variation. And whether there was a variation pre-'69 model year.
Re: '68 Lynch Rd fender tag question [Re: topside] #2565890
10/18/18 01:07 PM
10/18/18 01:07 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I think that the '69 Lynch Road fender tags only have Body-In-White or paint necessary information on them, and no options like radio, trim, etc. About the only option I don't know why it would be necessary for BIW to have on a metal tag that won't burn from welding sparks and can still be read if painted (the reason for raised characters) is the axle/ratio? Everything else on a LR fender tag relates to gates, firewall type (A/C, heater) floor pan for bench seat or buckets, radiator support size, engine for K-frame, paint color interior and exterior. Things that could be burned or painted over in the early production process are not on the tag like the the other assembly plants???
Re: '68 Lynch Rd fender tag question [Re: A12] #2565918
10/18/18 01:54 PM
10/18/18 01:54 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
But for a BIW you need to know if it has a radio so you put the right fender on it
Re: '68 Lynch Rd fender tag question [Re: Morty426] #2566251
10/19/18 12:40 AM
10/19/18 12:40 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Good one......BUT the fenders are bolted on and I thought bolted on away from the welding where the large broadcast sheet on the front of the car would be used to put the fenders, doors, hood, trunk lid, etc. I think they even drill the emblem and callout holes, etc. in the fenders, doors, hoods, trunk lid as needed when they are moved to those areas away from BIW.
