Re: What could cause lash to open? [Re: 1mean340] #2564957
10/16/18 05:32 PM
10/16/18 05:32 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Gold not good
Re: What could cause lash to open? [Re: 1mean340] #2564959
10/16/18 05:34 PM
10/16/18 05:34 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Hopefully it's gold silicone, but doesn't look like it.
Re: What could cause lash to open? [Re: 1mean340] #2565096
10/16/18 09:54 PM
10/16/18 09:54 PM
Suffolk County, New York
1mean340 Offline OP
1mean340  Offline OP
I'm confused? What are you guys seeing that's gold? That pan is the picture of after I blew out the filter with brake cleaner, the gold color stuff looked to me like just a mix of the brake cleaner and the oil. It was all clear liquid, I didn't see any grittyness or metallic sheen to it. The oil that came out of the filter before I hit it with brake cleaner had a gray look to it but not metallic either, at least I don't think so. You can see where it seperated from the brake cleaner there. I was thinking it was still assembly lube in there.
Re: What could cause lash to open? [Re: 1mean340] #2565097
10/16/18 10:00 PM
10/16/18 10:00 PM
1mean340 Offline OP
1mean340  Offline OP
As for the results, cylinder 2's intake was at 20 thousandths, cylinder 4's intake was at 20 thousandths and cylinder 8's intake was at 30 thousandths (lash should have been 16). Every other rocker on both sides were within 1 or 2 thousandths of where I set them.
No sign of any wear on the ball or cup, adjuster nuts all took muscle to break loose. I don't get it.
What does suck is the piston faces of almost all the cylinders look wet and black. Curious to see what the leakdown says.
Re: What could cause lash to open? [Re: 1mean340] #2565099
10/16/18 10:04 PM
10/16/18 10:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It appears there are two copper/gold chunks in the upper right quarter of the second photo.
Re: What could cause lash to open? [Re: 1mean340] #2565100
10/16/18 10:08 PM
10/16/18 10:08 PM
1mean340 Offline OP
1mean340  Offline OP
THe bigger chunks? I'm 99% sure those and the sliver onnthe filter are pieces of the Fram filter housing after my grossly less than surgical air chisel job. I think anyway. Stupidly I threw everything away but I'm pretty sure those had the orange fram paint on them lol
Re: What could cause lash to open? [Re: 1mean340] #2565103
10/16/18 10:12 PM
10/16/18 10:12 PM
1mean340 Offline OP
1mean340  Offline OP
I think most of that metal towards the bottom right was from the filter cutting job actually. It was pretty awful, never doing that again lol. I inspected the filter very closely before blowing it out with brake cleaner and didn't see any of those bigger chunks, I think they were part of the filter housing that ended up there probably stuck to the rag I was using. Probably the worse filter inspection ever, I know. It had a long day that day haha.
Re: What could cause lash to open? [Re: 1mean340] #2565115
10/16/18 10:38 PM
10/16/18 10:38 PM
Make sure your intake manifold is not sucking oil into the bottom of the runners scope
This is not a uncommon problem with built (heads and block cut)B & R/B type motors with the stock valley pans
Are you using a single plane intake or dual plane like stock? If a single plain pull the carb. and look down the intake runners towards the heads, it the intake is dry and dull looking and the intake ports in the heads are shiny and wet then you have located a problem to fix that will make your motor run a lot better scope
Re: What could cause lash to open? [Re: Cab_Burge] #2566454
10/19/18 01:32 PM
10/19/18 01:32 PM
1mean340 Offline OP
1mean340  Offline OP
Cab, I definitely have to check that. I had some fitment issues with intake manifold from the start from the milling of the block/heads. I had to use a custom .120 thickness intake gasket to mate it all up. That would definitely be a better issue to have then the rings LOL
Wouldn't put it past the rings though as this FITECH ran disgustingly rich for a while during break in (and still does, though not as bad) due to a host of issues. Lean tip in problems that I couldn't adjust away with more accelerator shot, AFR's fluxuating like a pendulum that seemed to improve when I limited the systems learns to +/- 10% instead of 30, Issues with AFR's plummeting rich after coming to a stop with no sign of any changes in fuel pressure, vacuum leaks or anything. I've really had it with that system.
