Rear disc brake weight loss
#2565035
10/16/18 07:55 PM
10/16/18 07:55 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
Does anybody know the weight savings for swapping to a rear disc brake kit over a stock drum brake setup? I'm looking at a wilwood dynalite kit for my new rear axle.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Rear disc brake weight loss
[Re: 73cuda340]
#2565579
10/17/18 08:46 PM
10/17/18 08:46 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The stock 10" drums weigh about 36 pounds complete. What is the shipping weight of the aftermarket stuff ?
[Re: justinp61]
#2566860
10/20/18 11:09 AM
10/20/18 11:09 AM
73cuda340
clarks summit pa
I went from 11 X 2" to a Wilwood with the Explorer type internal parking brake and lost 16 pounds. Did you use the street or drag setup on these? The rotors are a lot thinner on the darg kits.
[Re: 73cuda340]
#2566915
10/20/18 02:02 PM
10/20/18 02:02 PM
Posts: 797 WA
pro451bee
WA
When I did the BAER iron sport rear on the Bee ,similar to DR diffs 11.7" kit. I measured 16 lbs each side weight loss , 35 lbs 11x2.5 drums to 19 lbs disk.
[Re: 73cuda340]
#2566938
10/20/18 03:08 PM
10/20/18 03:08 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I went from 11 X 2" to a Wilwood with the Explorer type internal parking brake and lost 16 pounds. Did you use the street or drag setup on these? The rotors are a lot thinner on the darg kits. It's the street kit, the race brakes I looked at didn't have the parking brake and are much lighter.
