Re: 1970 Charger Hood Turn Signals
[Re: 70sixpkrt]
#2564757
10/16/18 10:47 AM
10/16/18 10:47 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I got mine from Kruisin Moons. They are very nice as far as I am concerned. Link:
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70sixpkrt]
#2564804
10/16/18 01:12 PM
10/16/18 01:12 PM
70gtx440dana
Lansing, MI
Quality is very good.....thread fit was excellent and wire construction also very nice. You can call and confirm lengths and connector types required as well. It seems there were two different styles of connections used in 1970 from what I found. There were two male bullet connectors, or a T type connector that attaches to front wire harness. You will want to confirm connector type before ordering.
[Re: 70gtx440dana]
#2564817
10/16/18 01:48 PM
10/16/18 01:48 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
Quality is very good.....thread fit was excellent and wire construction also very nice. You can call and confirm lengths and connector types required as well. It seems there were two different styles of connections used in 1970 from what I found. There were two male bullet connectors, or a T type connector that attaches to front wire harness. You will want to confirm connector type before ordering. Thanks. I will call them.
[Re: 70sixpkrt]
#2565239
10/17/18 08:46 AM
10/17/18 08:46 AM
Posts: 601 Mass
charge70
Mass
All the hood turn signal wires have the bullet connector.Some headlamp harnesses have the T-type connector while others have the bullet.If you have the t-type connector on your h/lamp harness,there is an adapter harness you will need to connect the hood t/signals to the h/lamp harness.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 70sixpkrt]
#2565277
10/17/18 11:18 AM
10/17/18 11:18 AM
70gtx440dana
Lansing, MI
I ended up calling Charger Specialties today. They make the hood turn signal wires and supply them to Yearone and Megaparts and other suppliers. I ended up buying them from him. M&H supplies all other harnesses. Glad you were able to find what you needed.
