Drag radial head-scratcher #2564461
10/15/18 04:17 PM
10/15/18 04:17 PM
California
70Drop Offline OP
70Drop  Offline OP
California
I went to the ANRA event this weekend and had a blast! Just put new tires on the car: M/T Pro Drag Radial, 9x30-15. These replaced 10.5x30-15 bias ply slicks. For my first run, I used 16 psi. The tires gave me a 1.65 60'. That was terrible compared to my old tires that gave me a 1.58 typically. Everyone told me to go up in pressure to make them work better, but I instead went down to 12 psi, which was the low end of the recommendation from M/T: http://www.mickeythompsontires.com/tech-bulletins/street-air-pressure-guidelines
At 12 psi, the car gave me a 1.52 60', which is the best ever with the car. Multiple people said I should go up on pressure rather than down and that if I put 20 psi in the tire, it would do even better. Since I was going into competition rounds, I didn't want to change anything and ignored them. I continued to get great 60' times.
The next time I can get some T&T runs, I'm going to try higher pressures to see what happens, but I'm very interested in the experience of you guys. Relevant specs on the car:
About 3300 lbs. with me in it
Super Stock leaf springs + Caltracs and drag shocks
727 with 3500 stall, 4:10 gears
500" big-block with a 260 @ 0.050 solid roller
Re: Drag radial head-scratcher [Re: 70Drop] #2564471
10/15/18 04:42 PM
10/15/18 04:42 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run the Pro Bracket Radial in a 28x10.50. Mine has had the best 60ft of 1.41 at 19 psi. In reality it was probably higher, I made 3 passes in 40 minutes and that 19PSI was the cold pressure before the first run.
68 Barracuda Formula S 340
Re: Drag radial head-scratcher [Re: 70Drop] #2564472
10/15/18 04:42 PM
10/15/18 04:42 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Pretty new to drag radials myself as I haven't made a full pass yet. We started at 16 psi stone cold, the rear shocks are valved for radials. We were wadding up the bias plys real bad with the shocks set up for radials so I'm guessing you can go with a lot more aggressive settings with Radials. Our second "go for it" pass produced a big wheelstand and the landing did some damage after I lifted. There's some more info in the "tips for a drag radial newby" thread.
HTH's up
Re: Drag radial head-scratcher [Re: 70Drop] #2564499
10/15/18 05:23 PM
10/15/18 05:23 PM
an8sec70cuda Offline
If the track is good, I've run up to 21 psi in my 295-65 M/T ET Street radials. Typically gets quicker as air pressure goes up.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Drag radial head-scratcher [Re: an8sec70cuda] #2564509
10/15/18 05:45 PM
10/15/18 05:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep. Dragging less of a flat pair of tires down the track
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Drag radial head-scratcher [Re: 70Drop] #2564526
10/15/18 06:21 PM
10/15/18 06:21 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
what width rear rim ? That will affect psi . Do you have radial valved,tight, rear shocks ? Did you alter rear shock settings going to radials ? What sort of power/ ET ?
Whatever works for your car is best .
For what its worth , with Hoosier 275 radials I ran 17 1/2 - 18psi on a 8" rim . Similar with MT ET street radials . With MT Pro bracket radials I went to a 10" rim , with the 28x10.5 I ran 18psi , I now run the 29.5x10.5 version @ 19 psi . Looking at launch pics may even prefer another 1/2psi or so .
Oh yeah I was running 1.42-1.48 with my 505 , with my 440 I am around 1.5-1.52
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Drag radial head-scratcher [Re: tex013] #2564542
10/15/18 07:23 PM
10/15/18 07:23 PM
California
70Drop Offline OP
70Drop  Offline OP
California
Tex
They are 10-inch rims. I didn't change the shock settings for the radials. I hadn't thought about that.
ET is 10.60 to 10.70. I probably have about 550 hp at the wheels.
I didn't realize there was a thread about drag radials. I'll have a look.
Re: Drag radial head-scratcher [Re: 70Drop] #2564572
10/15/18 08:33 PM
10/15/18 08:33 PM
Canada north shore lake Ontari...
ross Offline
ross  Offline
My M&H Racemasters like 21.5 on my car.
Re: Drag radial head-scratcher [Re: 70Drop] #2564586
10/15/18 09:02 PM
10/15/18 09:02 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
see if you can get startline video or pictures , see what is happening
Tex
New best MPH 130.32
Re: Drag radial head-scratcher [Re: 70Drop] #2564664
10/15/18 11:59 PM
10/15/18 11:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
Generally speaking most drag radials like more pressure than any bias ply does, that being said I haven't raced a set of radials in a lot of years so keep that in mind. the last set of legal NHRA stocker bias ply tires I raced on where 9x30 on a ten inch wide rim that ET the best with 16.0 to 17.0 Lbs. cold, the 60 ft. and reaction times where great on those tires boogie
Do you know how accurate your tire pressure gauge is?
Are you using a low tire pressure gauge or a regular gauge that goes up to 60 Lbs. or more?
I've seen decent quality low pressure tire gauges vary a hoop, some read low and some read high compared to a very good known calibrated test gauge scope
I suggest you use your tire gauge only, DO NOT LOAN it out EVER tsk Add air 1/2 lb. at a time until the 60 ft. and reaction times slow down and then go the other way down 1/2 lb/. at a time until it reaches the limits on the low side scope The number on the gauge doesn't really matter as long it reads the same every time with the same pressure in the tire, what does matter is the time slip up work grin
Re: Drag radial head-scratcher [Re: ross] #2564686
10/16/18 12:57 AM
10/16/18 12:57 AM
Washington
madscientist Offline
Washington
Which tire are you using?
Re: Drag radial head-scratcher [Re: Cab_Burge] #2564708
10/16/18 01:58 AM
10/16/18 01:58 AM
California
70Drop Offline OP
70Drop  Offline OP
California
Good point. It wouldn't be the first time I've chased a gremlin that turned out to be bad data! My gauge is a low-pressure type, so I'm measuring at the top of the scale for the radials. Same gauge I've used with my old slicks. I think it was pretty accurate, but I should probably use another gauge to compare with
Re: Drag radial head-scratcher [Re: madscientist] #2564866
10/16/18 03:08 PM
10/16/18 03:08 PM
ross Offline
ross  Offline
I am using a 275-60-15 on a 68 Runner just shy of 4000lbs.
Re: Drag radial head-scratcher [Re: 70Drop] #2564890
10/16/18 03:34 PM
10/16/18 03:34 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Valving a rear shock for radial is looser than the equivalent bias ply shock on extension at least.
