Different size bearing halves? #2564088
10/14/18 09:56 PM
10/14/18 09:56 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
Non mopar-I wouldn’t believe it if I didn’t see it. I’m reringing a motor for a friend it’s a 1950 Ford 8N tractor. I took the rods and pistons out yesterday and the bottom half of the bearing was stamped 030 and the top was stamped 010 I can’t believe it was running and probably was this way for a very long time. Any idea why someone would do this?
Re: Different size bearing halves? [Re: 65rbdodge] #2564118
10/14/18 10:35 PM
10/14/18 10:35 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
it is VERY common to find an odd mix of journal sizes in these engines. but different size half-shells on the same journal , never seen that one before, haha that's funny.
these engines turn relatively slow and usually make good oil pressure , but not something I would recommend.
Paul
Re: Different size bearing halves? [Re: 65rbdodge] #2564148
10/14/18 11:11 PM
10/14/18 11:11 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I mix standards with .001 to creep up on clearance when needed. Never an issue for my stuff.
Re: Different size bearing halves? [Re: 65rbdodge] #2564173
10/14/18 11:44 PM
10/14/18 11:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2, Ford factory manuals for the “Indy” 255, “Le Mans” 427, and “Trans Am” Boss 302 recommend this procedure.
Boffin Emeritus
Re: Different size bearing halves? [Re: 65rbdodge] #2564214
10/15/18 01:25 AM
10/15/18 01:25 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I had a crank polished, rods sized and machine shop sent me home with 4 standards and 4.001 for the rods,.001 go in top half, been together for 30 years and 114,000 miles.
Re: Different size bearing halves? [Re: 65rbdodge] #2564268
10/15/18 07:55 AM
10/15/18 07:55 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
My Uncle Tony when he was building those SCCA 302s back in the 60's-early 70s it was common practice to "make the upper rod loose" by .001 and the 427FE's if it was going to see high RPM 5500+(lol High RPM) the rods were .001 loose and for the 427s with a 428 crank he would also make the lower mains 2,3,4 loose by.001, idea there was if the crank flexed it there would still be some film.
Every Engine I have ever built has had the uppers loose by .001, some of the 6.1 hemis I've done lately have also had #2,3&4 main lower loose by .001
It's that old saying, if your engine is loose only you will know, if it's tight everyone will know.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Different size bearing halves? [Re: 65rbdodge] #2564314
10/15/18 11:27 AM
10/15/18 11:27 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
A lot of modern engine (at least on the Chrysler side) use a standard bearing half for the block, and different letter or color bearing halves on the caps. I think Honda does this, too.
[image][/image]
