Bad Vibrations, Chicago Fury saga #2563496
10/13/18 06:30 PM
10/13/18 06:30 PM
IL
furious70 Offline OP
IL
I can't figure this out. Flex plate tightened, all mounts tight, u joints feel good and are pretty new, pig is tight. Vibration is rpm dependent it seems, not speed. I've got 2 videos I'll link here. You can see the speedo and the tach. Around 55-60mph it's a very cyclical vibration comes and goes every 1-2 seconds. When I accel it'll jump to every 1/2 sec then smooths out when I'm going 65mph or so and 3300rpm. Then repeats the cadence on decel. On the video it sounds a bit like an exhaust leak, but that's actually the vibration noise. I feel it in the front, don't feel it in my butt or from the rear at all, which makes sense since its rpm related. I get a bit of the vibes as it gets to the top of the rev band before shifting as well.
Anytime it's doing it if I flip OD on it instantly goes away on the shift.
This engine had been together for decades hooked to a 727 in this car and hooked to the a500 for 10yrs. The First engine with the a500 did not do this that I remember. It developed blow by and I stuck this engine back in. This setup has done it for years, but I'm just getting the car back out from a slumber of 2yrs
Any thoughts?
https://www.youtube.com/watch?v=EXHfeZko0nA
https://www.youtube.com/watch?v=elas8Yz5hgk
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563516
10/13/18 07:19 PM
10/13/18 07:19 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Seems to me like a mismatch between the type of crankshaft and the torque converter.
Forged crank = torque converter usually with no balance weight
Cast crank + cid = torque converter with some sort of balance weight
HTH , Paul
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563542
10/13/18 08:27 PM
10/13/18 08:27 PM
IL
IL
I had started to wonder that. Every combo I've had in the car is supposed to be internally balanced. I've been concerned cuz this block has an 'E' stapmed on the pad and is a 71, not original to the car but was in the car when I got it with 43k in it. Engine has been rebuilt by a cheap house back in the day, had a reman tag on it.
It'd be sad that if it's always had a cast crack in it and in 21 years of ownership I didn't realize it.
This would be the first one I've mismatched, do they normally act up in only 1 rpm range?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563557
10/13/18 08:48 PM
10/13/18 08:48 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Generally once you get above a certain RPM , the vibration just stays with you. That being said, there are so many possible combos that it could limit itself to one RPM range , but I don't think its likely.
Also check your harmonic damper. Does the engine vibrate at RPM when in p/n?
Paul
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563596
10/13/18 10:24 PM
10/13/18 10:24 PM
Anytime it's doing it if I flip OD on it instantly goes away on the shift. Any thoughts?
This may be WAY too simple but I'd think internal trans related (or at least I would try & figure out what is changed/different when it goes into OD)
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563631
10/13/18 11:36 PM
10/13/18 11:36 PM
IL
IL
tomorrow I'll do the same test in 2nd gear. Those rpm's in OD create more speed than I should do without spending some time getting out of town smile
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563694
10/14/18 01:17 AM
10/14/18 01:17 AM
Sounds like a plan
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563708
10/14/18 01:49 AM
10/14/18 01:49 AM
Guitar Jones Offline
What changes when it shifts into O/D? The engine RPM changes that's what. If the vibration is there in park or neutral then you know it's an engine balance issue.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2563721
10/14/18 02:21 AM
10/14/18 02:21 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you have too much timing advance .
disconnect any vac advance and test drive it.
if it still does it back off timing or slow the advance rate.
Re: Bad Vibrations, Chicago Fury saga [Re: calrobb2000] #2563798
10/14/18 11:57 AM
10/14/18 11:57 AM
I would get in the same RPM range where it is vibrating & get it there both in & out of OD & see if it vibrates both times, if so that would for sure point to an eng balance issue.
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2564121
10/14/18 10:38 PM
10/14/18 10:38 PM
IL
IL
Timing was an interesting idea, a few taps of the keyboard ruled that out. Moved it from 38* to 32 to 28* made no difference.
It does it parked, first, and second gear but way more pronounced in drive for some reason.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2564187
10/15/18 12:10 AM
10/15/18 12:10 AM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
Check the rear bushing in the transmission.
Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: Bad Vibrations, Chicago Fury saga [Re: 69Mcode440] #2564274
10/15/18 08:31 AM
10/15/18 08:31 AM
IL
IL
Mike
Can I do that with it in the car?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2564287
10/15/18 09:54 AM
10/15/18 09:54 AM
Mike
If you have the vibration sitting still it is not in the driveline. It only seems worse in drive because of the load it's under.
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2564546
10/15/18 07:33 PM
10/15/18 07:33 PM
IL
IL
I'll check the dampner to make sure nothing goofy has happened there, but after that, pull the pan to see what the crank is?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2564758
10/16/18 10:48 AM
10/16/18 10:48 AM
IL
Dart451 Online content
Dart451  Online Content
IL
Had a friend who's clutch fan went bad and cause a vibration issue.
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2564790
10/16/18 12:28 PM
10/16/18 12:28 PM
IL
IL
interesting. cheap flex fan on this one. I did pay attention to the accessories this weekend, didn't notice anything out of whack with them.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2568891
10/24/18 02:27 PM
10/24/18 02:27 PM
IL
IL
anyone ever use a sirometer or this math?
https://grassrootsmotorsports.com/forum/tech-tips/cheap-simple-nvh-tool-and-write-up/117396/page1/
according to this, and my observation that the vibration is the worst at 2700 rpm means
2700/60 = 45hz if an external engine vibe. I think mine is internal so * 2 so 90hz vibration. How do I find which engine component that is?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2572414
10/31/18 11:22 PM
10/31/18 11:22 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Simple. Everything that is a suspect for vibration has a calculated frequency and there is the tool to count it. cool
Re: Bad Vibrations, Chicago Fury saga [Re: furious70] #2572443
11/01/18 12:11 AM
11/01/18 12:11 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm a little confused on the timeline but which transmission has it vibrated with, the 727, the A500 or both? If it shook with both, then it's in the engine. If it didn't shake with whichever trans was in it first but it does with what's in there now, it could be in the front of the transmission, whatever spins internally in neutral either directly or thru sympathetic motion.
I don't know if it was covered already but do you know the build history on the engine or did you get it the way it is? If it had say a cast crank and sixpak rods or a mix and match of LY's in it and it wasn't balanced, it would definitely have a shake. A cast crank and neutral balancer and flexplate could do it or any combination of the above.
Kevin
