Re: Gear drives? [Re: GY3] #2562925
10/12/18 02:59 PM
10/12/18 02:59 PM
All of the after market BB three gear drives, Milidon, KB and Donovan have the idler gear attached in the timing cover, so no they won't fit under a stock cover shruggy
Re: Gear drives? [Re: GY3] #2562953
10/12/18 03:39 PM
10/12/18 03:39 PM
Washington
madscientist Offline
Washington
Originally Posted By GY3
Do the Milodon drives fit under a stock cover?
Only on engines with a thick, cast timing cover. So, small block Chrysler's, pontiacs...damn I think FE ford but for the life of me I can't think of what that cover looks like, the 385 series fords.
You get the idea. If it's a stamped tin cover then you need a cast aluminum cover to fix the idle to.
Re: Gear drives? [Re: mopardude318] #2562955
10/12/18 03:42 PM
10/12/18 03:42 PM
Washington
Washington
Originally Posted By mopardude318
I agree with mad scientist. I have a milodon gear drive in my 408 stroker. I can't hear the whine over the exhaust.
I run mine on a street car, with street mufflers. My gear drive makes zero noise. If I don't tell you it's there, you won't know it.
I've had people call me a liar at a car show I went to. I was talking to a few guys about it when I parked and I mentioned it was a gear drive. They had me start it again. When they couldn't "hear" the gear drive they said I was a bullshitter and walked away.
And how do you prove what you have if the gear drive is under the cover? Pull it apart I guess.
Re: Gear drives? [Re: madscientist] #2563052
10/12/18 07:17 PM
10/12/18 07:17 PM
Why would you want to argue with car shows guy confused
Aren't all of them car Experts, in their own minds whistling
I have that same problem here, a bunch of show and shine guys shruggy
Re: Gear drives? [Re: Cab_Burge] #2563183
10/13/18 12:14 AM
10/13/18 12:14 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
frown
I guess I'm kind of car show and race. It ran mid 10's with a little nitrous old school .590 and a Pete Jackson Noisy gear drive. I degreed the cam at 106 if I remember right. No issues with the gear drive. Ran it on a couple cams. First installed around 1993 and was in the engine when I sold it.
From what I've read, belts have less harmonics and are supposed to be faster. I have yet to read about anyone with real world experience that actually gained hp or lost et with/without one.
My new Hemi has a chain. MM asked me if I wanted a belt or chain. I asked if there was any HP to be gained with a belt. Mike said no.
My slow pig
Re: Gear drives? [Re: bigblk66_coronet] #2563301
10/13/18 11:13 AM
10/13/18 11:13 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Quite useful: you didn't know they were idiots until they self-identified: that's a "tell".
Boffin Emeritus
Re: Gear drives? [Re: bigblk66_coronet] #2563355
10/13/18 12:48 PM
10/13/18 12:48 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Ran a Milodon gear drive in the 572 (it came with it's own cover), hated the noise so changed it to a Jesel belt drive when funds allowed. No difference in ET and the valves springs still needed replacing at the end of the season. twocents
