Universal RED Antifreeze?
#2562844
10/12/18 12:16 PM
10/12/18 12:16 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
So my neighbor offered to supply me with some Universal Red antifreeze since my trucks are due for a coolant change.
They both have always had green (at least to my knowledge) and I seem to recall several years ago there were issues with switching from one color to a different color.
He is saying this product can be mixed with green with no problems. I do not know the brand of the product. He works as a route driver, and this would be from the fleet service department.
So, my question is: Is there a universal red coolant that will mix with green?
Is the red coolant better or worse for aluminum core radiators?
If the red will not play well with the green, is a switch recommended with a proper flush?
Or just keep it green and sell the 5 gallons of red on facebook marketplace?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Universal RED Antifreeze?
[Re: hp383]
#2562927
10/12/18 03:02 PM
10/12/18 03:02 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Just make sure its not Dexcoool.I know some mfgs use a pnk color.Most universal is yellow but maybe they make different colors.Just make sure the jug says mixes with anything.Rocky
Chrysler Firepower
[Re: AndyF]
#2562957
10/12/18 03:52 PM
10/12/18 03:52 PM
hp383
State of Confusion
I use the NAPA antifreeze which is red or pink in color. I don't think the color matters anymore if it ever did. The problems people had with the red GM antifreeze was due to the fact that they never had their coolant changed. Any modern coolant will work just fine in a musclecar as long as it gets changed annually. Changed annually? I thought coolant had a 4 to 5 year lifespan?
[Re: hp383]
#2563156
10/12/18 11:15 PM
10/12/18 11:15 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I just know when you mix green coolant with Toyota red it turns into black coolant with an iron block. The new Toyota pink is good coolant but not much lubricant in it, eats water pumps prematurely. I always put the good old pure red in all my cars. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: hp383]
#2563157
10/12/18 11:20 PM
10/12/18 11:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Remember that "universal" means "fits nothing".
[Re: hp383]
#2563174
10/12/18 11:56 PM
10/12/18 11:56 PM
therocks
Niles , Ohio
Universal in coolant means its good for all.Probally thousands of cars I did had it.No problems since Ive used it since it came out.Rocky
Chrysler Firepower
[Re: hp383]
#2563185
10/13/18 12:15 AM
10/13/18 12:15 AM
Supercuda
About to go away
About to go away
up yours
Water is a universal coolant too.
[Re: hp383]
#2563253
10/13/18 08:26 AM
10/13/18 08:26 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I have been using the Yellow universal coolant in everything, since about 2008. I would have to look at the 55 gallon drum at the shop to be sure. NO Problems in anything...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: hp383]
#2564643
10/15/18 11:11 PM
10/15/18 11:11 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
1. Color means nothing at all.....I mean nothing at all...it's food coloring.
2. There are several families of coolant...conventional, OAT, NOAT, HOAT, Asian, European.....a bunch of different types.
3. Some coolants do very bad things when mixed....even if they are the same color (see 1 above).
4. In general, you don't want a coolant containing nitrite in a car. That is for heavy duty diesel (semi-truck or larger vehicle) engines...cranes, Navy ships, etc. The one exception is G-05 which uses a low level of nitrite & was used by Chrysler for a few years. Nitrite (and molybdenum) are used to protect wet sleeve liners.
5. Any coolant that lists ASTM D3306 is fine for just about any car...as long as it is not mixed with any other coolant & you use distilled water (or deionized water)...never use tap water or God forbid well water.
Hope This Helps!
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
