Any Summit discount codes out there? #2561812
10/10/18 10:01 AM
10/10/18 10:01 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
TIA.
Re: Any Summit discount codes out there? [Re: RATTRAP] #2561949
10/10/18 03:00 PM
10/10/18 03:00 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Not sure if the 50years code still works or not, but could try it anyways. $25 off 250 and $50 of 500 if I remember right.
Re: Any Summit discount codes out there? [Re: DusterKid] #2562334
10/11/18 10:22 AM
10/11/18 10:22 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I could use one also, Last one I got didn't work.
The only Carbs I care about are under the hood!
Re: Any Summit discount codes out there? [Re: Azzkikrcuda] #2562429
10/11/18 01:27 PM
10/11/18 01:27 PM
tboomer Offline
tboomer  Offline
If you fellas aint in a big hurry you can watch ebag for the 15% off code they put up once in a while.. wave
Re: Any Summit discount codes out there? [Re: tboomer] #2562435
10/11/18 01:36 PM
10/11/18 01:36 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Those of us going to the Halloween Classic next week should be able to pick some up. Bump this post after October 22nd.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Any Summit discount codes out there? [Re: RATTRAP] #2564562
10/15/18 08:16 PM
10/15/18 08:16 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Website is showing $50 off $500 now thru 10-21.
Code is 50wins
Re: Any Summit discount codes out there? [Re: pittsburghracer] #2570286
10/27/18 05:26 PM
10/27/18 05:26 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Anyone get any codes? I need one for something expensive. Please PM me one if you have one. Thanks
Re: Any Summit discount codes out there? [Re: blowndart] #2570294
10/27/18 06:02 PM
10/27/18 06:02 PM
PA.
"Little"John
"Little"John
PA.
Sent you a PM.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Any Summit discount codes out there? [Re: RATTRAP] #2570302
10/27/18 06:25 PM
10/27/18 06:25 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Today 10% off use code SUMMIT50
