Re: Main Studs for Mopar Aluminum block
[Re: ntstlgl1970]
#2558816
10/04/18 11:14 AM
10/04/18 11:14 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey Eric, I emailed Prefix for you for the #3 main cap oil pick up stud, waiting on their reply.
[Re: hudsonhornet7x]
#2560379
10/07/18 03:08 PM
10/07/18 03:08 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Unless I am mistaken his name is Rick Talbot. Correct. I need to correct that in my phone
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: ntstlgl1970]
#2561375
10/09/18 01:05 PM
10/09/18 01:05 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Eric, Dale Matthews emailed me back just now and they have the oil pick up stand off available. It goes on top of the main cap stud same as in my engine What is your zipcode for shipping? They are $13.21 email RylisPro@gmail.com to order Thanks!
[Re: RylisPro]
#2561490
10/09/18 05:03 PM
10/09/18 05:03 PM
sixpackgut
Charleston
Eric, Dale Matthews emailed me back just now and they have the oil pick up stand off available. It goes on top of the main cap stud same as in my engine What is your zipcode for shipping? They are $13.21 email RylisPro@gmail.com to order Thanks! Just sent you $30. Send me 2 of them
[Re: sixpackgut]
#2561562
10/09/18 07:40 PM
10/09/18 07:40 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey Eric & Ray, I emailed Prefix on shipping quotes for your respective address. Will get a reply from them tomorrow. If anyone else needs parts from Prefix email us your shipping address at RylisPro@gmail.com for a quote. Thanks!
[Re: Stewart]
#2561739
10/10/18 01:35 AM
10/10/18 01:35 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I'm not sure if the aluminum block main studs are available separately from the block? The #2, #3 and #4 main caps utilize a vertical 4 bolt mounting structure for added strength. All of the 5 main caps utilize the production cross bolts. J 80-01-0001 M8 X 1.25 X 35 HEX FLANGE HD qty. of 10 Also the main studs and caps are a unique size for the aluminum 6.1 block casting. These will NOT fit any production cast iron cylinder block. I am pretty sure the 16 main studs and part numbers are: H 80-03-0002 STUD - 7/16 BOTH ENDS - SHORT qty. of 6 G 80-03-0001 STUD - 7/16 BOTH ENDS - LONG qty. of 10 on the instructions .pdf and will have to email Prefix to confirm.
[Re: Stewart]
#2562284
10/11/18 02:26 AM
10/11/18 02:26 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey Stewart, You have a couple of McLaren blocks don't you? Those are different than the 6.1 Gen 3 aluminum blocks obviously. If your main cap studs have the metric ends that go into the block and the 7/16 end that holds down the main cap, I'm thinking that the oil pick up stand off may work if you modify it with a 7/16-20 fine thread helicoil maybe? Unfortunately the main studs on our 6.1 aluminum block looks like they are 7/16-14 coarse thread. There is no way that is a fine thread. You can see the oil pick up stand off in the background. I had forgotten to email Prefix until the last minute today haha I'm still out of town. Awaiting their reply.
[Re: ntstlgl1970]
#2562313
10/11/18 06:33 AM
10/11/18 06:33 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
might want to look in to these , won't help with the pick up tube. ARP Chevrolet Small Block LS/WP Warhawk LS aluminum block Kit #:134-5802
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ntstlgl1970]
#2562373
10/11/18 12:01 PM
10/11/18 12:01 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey Eric, Prefix got back to me they have the main stud in hand which looks to be like a 7/16-14 coarse thread on both ends. I had asked for the specs but they didn't respond with detailed info? They are $10 bucks each and I had them ship one to you via the cheapest way possible. I'll send you an invoice but don't worry about it right now. I would rather have you pay me in person at the Spring Fling Speed Festival at Big Willow in April 2019 haha! If anyone else needs one please email us your zipcode. Thanks!
[Re: RylisPro]
#2562465
10/11/18 03:38 PM
10/11/18 03:38 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Here is the part number and specs on the invoice for the main stud that got sent out to ntstlgl1970 Part # 80-03-0001 STUD; MJ12X.4375X4.452 190 4340, 190 KSI MIN, BLACK OXIDE FINISH. STUD-MAIN CAP LONG
