Page 1 of 2 1 2 >
#2557126 - 10/01/18 02:53 PM Main Studs for Mopar Aluminum block
ntstlgl1970 Offline
Loc: Sac, CA, USA
Looking for specs on the main studs for the aluminum block. Thread pitch, length etc. specifically for the oil pump pickup stud. My engine came with studs, but has a stock bolt for the oil pump. I already talked to ARP and they said their stud is not long enough to fully engage the all the threads on the aluminum block. I also talked to Arrow/Prefix and they did not respond to my repeated emails and questions. Looking for specs to find another stud from another engine maybe? LS etc. ?!?
My motor is at the machine shop and this is holding it up....
#2557798 - 10/02/18 03:33 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
shruggy
#2558049 - 10/02/18 10:20 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Cool, thank you. I’ll try calling him tomorrow.
#2558052 - 10/02/18 10:30 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
hudsonhornet7x Offline
Loc: Plumer, Pa
Unless I am mistaken his name is Rick Talbot.
XP29H8B198192
#2558695 - 10/03/18 10:39 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
Stewart Offline
Loc: Loganville, GA
I have the same problem. Do you have one of the Mclaren blocks? The studs have no name on them and are 7/16x20 on one end and 12x1.75 on the other. ARP doesn't have them but told me an AUF-6.000-1B is the pick-up stud. Could be the guy that told me that didn't know they were too short. I have never gotten a reply from Arrow/prefix.
#2558816 - 10/04/18 09:14 AM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
RylisPro Offline
Loc: NorCal
Hey Eric,
I emailed Prefix for you for the #3 main cap oil pick up stud,
waiting on their reply.
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bells
Lightened Billet Steel Flywheels
Prefix Performance
#2560379 - 10/07/18 01:08 PM Re: Main Studs for Mopar Aluminum block [Re: hudsonhornet7x]
sixpackgut Offline
Loc: Charleston
Correct. I need to correct that in my phone
#2561375 - 10/09/18 11:05 AM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
RylisPro Offline
Loc: NorCal
Eric,
Dale Matthews emailed me back just now and they have the oil pick up stand off available. It goes on top of the main cap stud same as in my engine
What is your zipcode for shipping?
They are $13.21 email RylisPro@gmail.com to order
Thanks!
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2561490 - 10/09/18 03:03 PM Re: Main Studs for Mopar Aluminum block [Re: RylisPro]
sixpackgut Offline
Loc: Charleston
Originally Posted By RylisPro
Eric,
Thanks!
Just sent you $30. Send me 2 of them
#2561562 - 10/09/18 05:40 PM Re: Main Studs for Mopar Aluminum block [Re: sixpackgut]
RylisPro Offline
Loc: NorCal
Hey Eric & Ray,
I emailed Prefix on shipping quotes for your respective address. Will get a reply from them tomorrow.
If anyone else needs parts from Prefix email us your shipping address at RylisPro@gmail.com for a quote.
Thanks!
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2561714 - 10/09/18 10:44 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
Stewart Offline
Loc: Loganville, GA
Are the studs available and are they 12x1.75 by 7/16x20 and are the standoffs 7/16 where they fit the stud?
#2561739 - 10/09/18 11:35 PM Re: Main Studs for Mopar Aluminum block [Re: Stewart]
RylisPro Offline
Loc: NorCal
I'm not sure if the aluminum block main studs are available separately from the block?
The #2, #3 and #4 main caps utilize a vertical 4 bolt mounting structure for added strength. All of the 5 main caps utilize the production cross bolts.
J 80-01-0001 M8 X 1.25 X 35 HEX FLANGE HD qty. of 10
Also the main studs and caps are a unique size for the aluminum 6.1 block casting. These will NOT fit any production cast iron cylinder block. I am pretty sure the 16 main studs and part numbers are:
H 80-03-0002 STUD - 7/16 BOTH ENDS - SHORT qty. of 6
G 80-03-0001 STUD - 7/16 BOTH ENDS - LONG qty. of 10
on the instructions .pdf and will have to email Prefix to confirm.
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2561748 - 10/10/18 12:02 AM Re: Main Studs for Mopar Aluminum block [Re: RylisPro]
RylisPro Offline
Loc: NorCal
Here are some cool schematics on the 6.1 aluminum block if anyone needs them.
Pay attention to the torque sequence for the main studs and cross bolts along with the increasing torque per fastener.
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2562217 - 10/10/18 10:02 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
Stewart Offline
Loc: Loganville, GA
My blocks are different. I have 4 bolts + side bolts on all 5 caps with one end metric and 1 end Std.
#2562284 - 10/11/18 12:26 AM Re: Main Studs for Mopar Aluminum block [Re: Stewart]
RylisPro Offline
Loc: NorCal
Hey Stewart,
You have a couple of McLaren blocks don't you? Those are different than the 6.1 Gen 3 aluminum blocks obviously.
If your main cap studs have the metric ends that go into the block and the 7/16 end that holds down the main cap, I'm thinking that the oil pick up stand off may work if you modify it with a 7/16-20 fine thread helicoil maybe?
Unfortunately the main studs on our 6.1 aluminum block looks like they are 7/16-14 coarse thread.
There is no way that is a fine thread. You can see the oil pick up stand off in the background.
I had forgotten to email Prefix until the last minute today haha I'm still out of town.
Awaiting their reply.
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2562313 - 10/11/18 04:33 AM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
ric3xrt Offline
Loc: Trumbauersville PA
might want to look in to these , won't help with the pick up tube.
ARP Chevrolet Small Block LS/WP Warhawk LS aluminum block
Kit #:134-5802
Edited by ric3xrt (10/11/18 04:34 AM)
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2562373 - 10/11/18 10:01 AM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
RylisPro Offline
Loc: NorCal
Hey Eric,
Prefix got back to me they have the main stud in hand which looks to be like a 7/16-14 coarse thread on both ends. I had asked for the specs but they didn't respond with detailed info?
They are $10 bucks each and I had them ship one to you via the cheapest way possible. I'll send you an invoice but don't worry about it right now. I would rather have you pay me in person at the Spring Fling Speed Festival at Big Willow in April 2019 haha!
If anyone else needs one please email us your zipcode.
Thanks!
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2562460 - 10/11/18 12:54 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
johnscudashop Offline
Loc: Mrytle Beach SC
I wish Arrow had these avail back in 2010 when I bought my Aluminum crate hemi.. I ended up making some stand offs for mine.. One thing I noticed. When I saw sixpackgut (Ray's) block the other day, I only saw 3 or 4 threads sticking out above the stud nut. I remember mine had alot more Threads above the main cap nut
#2562465 - 10/11/18 01:38 PM Re: Main Studs for Mopar Aluminum block [Re: RylisPro]
RylisPro Offline
Loc: NorCal
Here is the part number and specs on the invoice for the main stud that got sent out to ntstlgl1970
Part # 80-03-0001
STUD; MJ12X.4375X4.452 190 4340, 190 KSI MIN, BLACK OXIDE FINISH. STUD-MAIN CAP LONG
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2562520 - 10/11/18 03:50 PM Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970]
Stewart Offline
Loc: Loganville, GA
Don't know what I was thinking when I said all 5 caps were 4 bolt, only 2,3 and 4. No wait, it was not me. I was hacked, ya thats what happened, I would never make that mistake. Think i will order the pickup stud from the 5.7 ARP kit and see I can get it to work it works.
PS. It was me.
Page 1 of 2 1 2 >
25,743 Registered Members
193,014 Topics
I'm back and I survived ! and I have a new Mopar!
by NAS Backyard
Today at 12:36 AM
Largest Tire on cop car rim to fit a 67 Monaco ?
by NAS Backyard
Today at 12:15 AM
1985 Dodge W150
by Neil
Yesterday at 10:51 PM
What brand main and rod bearings do you like?
by vinnyd76
Yesterday at 10:14 PM
