Best steering/suspension/brakes for 71 B body? #2561109
10/08/18 10:09 PM
10/08/18 10:09 PM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
I have a 1971 Sebring that I Solo II autocrossed in the 1990's. To keep it on par with the new cars of the day I made the following mods to the car:
- Circa 1978 11.75" front disk brakes
- 205lb/inch torsion bars
- 1 1/8" front anti-sway bar
- Firm Feel steering box
- Fast ratio Pitman & Idler
- Poly bushings all around
- Heavy Duty rear leaf springs
- Subframe connectors, welded
All of which kept it competitive against cars of the 90s.
Then a few years back I added the Hotchkis upper control arms, shocks, and adjustable struts.
And now, well I've been saving up for some more modifications and wanted to ping the suspension brains here on Moparts for suggestions. Here's what I'm thinking of doing next, but I'm open to ANY suggestions:
- Borgeson steering box (w/ shorter stock Pitman/Idler)
- Rear anti-sway bar of some kind (I have a 1" bar on the shelf)
- Upgraded brakes of some kind
- New torsion bars, maybe a higher spring rate
- To get a little crazy, an Independent rear susp?
What do you all think? Thanks in advance.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2561175
10/09/18 12:03 AM
10/09/18 12:03 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I use the fast ratio arms and the borgeson box, 1.8 turns lock to lock, you will have to put a different flow control valve on it (I bought the one off jegs but I'm thinking of enlarging it a little bit or going with a smaller pulley to make it easier to turn through the quick slalom) You will have to weld up the k member with all the extra forces applied to it if you haven't already. Also do you have inner fender braces, lower rad brace, subframe braces ect? if not I'd suggest that first. Rear sway bar is good (although some guys prefer to run without) I would go with bigger torsion bars and heavier spring rate on the rear. Dr. diff has a great rear brake kit that won't break the bank(and still use your stock ebrake cable) I've been looking and debating on the rear independant kits - If I do I would buy this: http://rick486.wixsite.com/dobbertinperformance
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2561215
10/09/18 01:12 AM
10/09/18 01:12 AM
Los Angeles, CA
Los Angeles, CA
Wow, thanks for that link. I had no idea there was such a C6 suspension package available. Likewise with the Dr. Diff brakes.
I have NOT done any of the welding you mention, nor the braces. That's a good start.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2561238
10/09/18 02:20 AM
10/09/18 02:20 AM
AndyF Offline
AndyF  Offline
What tires do you have on the car? I'd think that big tires would be the most important modification but I don't see it listed. You might need to find a competitive tire and then work backwards from there. If you use 17 inch or larger then you can step up to some bigger brakes. Not sure if you really need big brakes for autocrossing but it is an option.
Re: Best steering/suspension/brakes for 71 B body? [Re: AndyF] #2561631
10/09/18 10:24 PM
10/09/18 10:24 PM
Los Angeles, CA
Los Angeles, CA
I forgot to mention them - 255/45-17s all around.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2561633
10/09/18 10:27 PM
10/09/18 10:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What brand/model tires?
Radial T/A's, wasting your time.
Michelin Pilots, good street performer.
Hoosier slicks, ah no
MasterCraft SUV tire, lol
It does matter
Don't be the exception.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2561759
10/10/18 02:32 AM
10/10/18 02:32 AM
AndyF Offline
AndyF  Offline
Here is what I run on my street car. For an autocross car I'd probably step it up a notch or two.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2561884
10/10/18 12:41 PM
10/10/18 12:41 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Is that a MAGLEV setup like on the bullet trains?
Carl Kessel
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2561964
10/10/18 03:18 PM
10/10/18 03:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nope, it's the flying wiener dog option
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2562151
10/10/18 09:50 PM
10/10/18 09:50 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
What class do want to run in?
Re: Best steering/suspension/brakes for 71 B body? [Re: Mattax] #2564699
10/16/18 01:27 AM
10/16/18 01:27 AM
Los Angeles, CA
Los Angeles, CA
I don't care about the classes, I just want the best handling streetable car possible. I don't Solo II anymore and if I decide to do it again I'll take whatever class they give me. smile
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2564808
10/16/18 01:22 PM
10/16/18 01:22 PM
AndyF Offline
AndyF  Offline
You'll need a better description than "best handling streetable" before you can get very far. Both handling and streetable behavior are very subjective.
If you are looking for advice I'd say you should start by riding in some modified cars and finding the compromise between handling and comfort that you like. It is very easy to turn a mushy factory Mopar into a dump truck by installing big torsion bars and cheap shocks. If you don't like mushy and you don't want to drive a dump truck then you'll need to find something that works for you.
Hotchkis has a complete handling package that takes the guess work out of the equation so that is one place to start. Otherwise just do what everyone else does - experiment. Try a few different sizes of bars and see what you like. Try a few different brands of shocks to see which one feels the best to you.
Re: Best steering/suspension/brakes for 71 B body? [Re: AndyF] #2564831
10/16/18 02:16 PM
10/16/18 02:16 PM
Los Angeles, CA
Los Angeles, CA
I don't mean to be vague. What I've always tried to do with this car is get it as close as possible to modern sports car handling, knowing that the size and weight of a B-body was a bit of a challenge. If possible, I'd have steering and handling like a modern Corvette. If I could get something close to a modern pony car, I'd take it.
Right now I pretty much have the Hotchkis system installed. The brakes on the car are decent.
If nothing else, I'll just install a Borgeson box and be done with it. But before I make any changes I thought I'd find out what other options were out there, if at all.
Thanks.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2564836
10/16/18 02:26 PM
10/16/18 02:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What is your budget?
Best improvement, lightest rims you can get, fattest tires you can stuff into it. Good tires, really, really good tires.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2564849
10/16/18 02:47 PM
10/16/18 02:47 PM
AndyF Offline
AndyF  Offline
There are lots of options, just depends on your skill level, the size of your budget and how hard you want to work at it. Baer sells brake packages that go all the way to 15 inch rotors. DoctorDiff has 13 inch kits, I build my own brake kits using Viper or Porsche parts.
Fikse will build you custom rims that are lightweight, super strong and the correct offset. Lots of performance tires are available you just need to figure out what size you are willing to put under the car. Really good shocks like Koni are available or you can step up to even higher quality stuff with a little fab work.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2564851
10/16/18 02:49 PM
10/16/18 02:49 PM
Los Angeles, CA
Los Angeles, CA
For tires I am currently running Falken FX452 255/45ZR-17 98Y. The rims are a set aluminum Ion wheels I bought about 10 years ago when my favorite set of Amer Racing Hurricane II's were damaged.
My budget should accommodate most or all available options. I was considering buying a Hellcrate but then decided to reroute that cash towards handling & suspension.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2564898
10/16/18 03:49 PM
10/16/18 03:49 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Borgeson sounds like a nice idea. Never tried one, so no personal feedback on it. after that:
- lighter wheels, wider and stickier tires.
- map out your wheel rates to see what you F/R percentages are.
- step up your rates 10%, match with equivilent shocks.
- evaluate if you want more.
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2564937
10/16/18 04:46 PM
10/16/18 04:46 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Get some bigger tires on it and get back to us.
Those were fine a decade or so ago.
You can't put too big of tire on a car that size if handling is your goal, even on the street stirthepot
Re: Best steering/suspension/brakes for 71 B body? [Re: JF_Moparts] #2565085
10/16/18 09:32 PM
10/16/18 09:32 PM
AndyF Offline
AndyF  Offline
255/45-17 is a decent size tire. It is way bigger than anyone had back in the 70's but way smaller than what BMW or Porsche engineers would put on a car your size these days. So you just have to decide how "modern" you want to be.
A 17 inch rim allows you to run a 13 inch brake rotor which should be big enough to stop that car. Do you know how much the car weighs and what the weight distribution is? If you haven't had the car scaled then that should be a high priority. You need to know what you're working with before you start working.
I assume the car is at least 4000 lbs and probably has 52 or 53% on the front tires. So there is a lot of weight up there which means the tires are getting tortured. A 255/45-17 tire can handle around 1500 lbs of load but that doesn't mean it is going to handle great when it is fully loaded.
Since you have a running combination you should be able to crawl underneath it with a tape measure and figure out if you can put a bigger tire on it. If you can great, if not then you know what your limitation is. If you are limited to a 255 section width then consider a bigger wheel. Perhaps a 255/40-18 or a 255/35-19 would work better for you. A 19 inch rim would allow a 15 inch brake rotor which is what the Porsche guys would use these days on a 4000 lb vehicle with 500+ horsepower.
Go spend some time on the BMW website and look at the tire sizes and brake rotor sizes they are putting on their 4000 lb cars. Or visit your local Dodge dealer and look at what the Dodge engineers put on the Hellcat Charger. That is a big car and they put big wheels, big tires and big brakes on it. Once you have the correct size wheels, tires and brakes then you can fine tune the spring rate and shock valving.
You'll also need to stiffen up the chassis a bunch. Ma Mopar made these cars as limp as a noodle back in the day. XV is out of business but you might be able to dig up some of the stuff they published on chassis stiffness. They were the only business to ever take the subject seriously but the market must not have been big enough to keep them in business. Basically you'll need to add some crossmembers and a monte carlo bar.
Re: Best steering/suspension/brakes for 71 B body? [Re: AndyF] #2565110
10/16/18 10:32 PM
10/16/18 10:32 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Tire size? My DD Tacoma PU @3000lbs w/140 hp has 295/35/18 all around, it sticks. boogie
