Re: 436" w8 small block music.
[Re: Rob C]
#2561821
10/10/18 10:36 AM
10/10/18 10:36 AM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#2561848
10/10/18 11:43 AM
10/10/18 11:43 AM
Posts: 4,457 Washington
madscientist
Washington
Just curious...what dyno is that? As in brand.
[Re: W5DART66]
#2561850
10/10/18 11:44 AM
10/10/18 11:44 AM
madscientist
Washington
NEVERMIND.
I just looked on the left side of the dyno sheet.
[Re: W5DART66]
#2561896
10/10/18 01:01 PM
10/10/18 01:01 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Bad boy!
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: W5DART66]
#2561929
10/10/18 02:15 PM
10/10/18 02:15 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
Did it like the AFR or did you guys try leaning it down? If so what results did you get?
[Re: Cab_Burge]
#2561995
10/10/18 04:11 PM
10/10/18 04:11 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Did it like the AFR or did you guys try leaning it down? If so what results did you get? Was wondering the same thing.............
[Re: W5DART66]
#2562030
10/10/18 05:08 PM
10/10/18 05:08 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
[Re: W5DART66]
#2562086
10/10/18 07:20 PM
10/10/18 07:20 PM
Thumperdart
State of confusion
His o2 are off we just tune to best power just a number.
If you are at 12.8 - 13.2 on this dyno with q16 you will be down on power.
Look more at fuel flow/lbs per hour and what it's making 😉 Good info and looking back I think one guy on Q-16 was in the 12.5-12.7 range and ran quickest and fastest.........no magic #'s right just what each and everyone want's is what they get.......
[Re: Rob C]
#2562214
10/10/18 11:49 PM
10/10/18 11:49 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Once again another amazing build...Brett thank you for your knowledge and effort in furthering the performance of the small block Dodge...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Rob C]
#2562262
10/11/18 01:39 AM
10/11/18 01:39 AM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is there a thread with this engines build? LOL. He's not in the habit of sharing that. Flow numbers and dyno pulls only.
