Strange 1979 440, what's it out of? #2561387
10/09/18 01:28 PM
10/09/18 01:28 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
Just picked up a 440, it's got 9T 440 E & 8-14 on the block stamping, cast date of 6-28-78, weird left side exhaust manifold and the std size spark plugs, not the small ones used in the motor home blocks. Any idea what this was used in?
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2561403
10/09/18 01:52 PM
10/09/18 01:52 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
It has a truck mount on it, so some kind of heavy duty truck? scope
JB Rhinehart, Realist
A-Body's RULE!
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2561500
10/09/18 05:34 PM
10/09/18 05:34 PM
IL
furious70 Offline
furious70  Offline
IL
those manifolds were used in vans and some chassis trucks from what I know. I own 3 of them and used in turbo set up - bought from 3 different people. Seems they only put them on 1 side for some reason.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Strange 1979 440, what's it out of? [Re: furious70] #2561595
10/09/18 08:52 PM
10/09/18 08:52 PM
On a side note, that maltese cross means something in that particular eng was undersize/oversized (it'd likely be in the archives if someone dont chime in).
Re: Strange 1979 440, what's it out of? [Re: RapidRobert] #2561600
10/09/18 09:01 PM
10/09/18 09:01 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I was told by a few people on this forum that the little "sight-glass" thingie on the timing chain cover was used on 440's that went into motor homes. The seller of the 440 block I bought said it was from a motor home, and my timing chain cover also had this feature.
Roger
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2561601
10/09/18 09:03 PM
10/09/18 09:03 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
I've only seen those valve covers on RV & van motors. In 30+ years, it may have been slightly molested. What are the casting numbers on the heads?
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2561703
10/10/18 12:27 AM
10/10/18 12:27 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I think it is incorrect to label it as a '79 engine. The June casting date is about 2 months earlier than when the next model year was usually cast.
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2561716
10/10/18 12:46 AM
10/10/18 12:46 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My guess, a B van, or a motor home/RV with the van nose.
An RV could easily have been a 79 model year, the chassis were sold in batches to the motor home builders and the model year would have been the assembly date of the finished RV. Depending on how many chassis were purchased, a big block Mopar RV could have had a build date as late as an 80 model year. That was not unusual in the RV business. Gene
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2561719
10/10/18 01:05 AM
10/10/18 01:05 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I agree but to call it a 1979 engine despite a June casting date?
Re: Strange 1979 440, what's it out of? [Re: Kern Dog] #2561775
10/10/18 03:58 AM
10/10/18 03:58 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
9 T 440 E
8 14
9 = 1979 model year
T = Trenton, MI engine plant
440 = 440 cu.in.
E = cast crankshaft
8 = August
14 = 14th of month (8/14/78)
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2561810
10/10/18 09:55 AM
10/10/18 09:55 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
truck or motor home...on the plus side its got extra ribs on the side and its most likly a good block to build
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Strange 1979 440, what's it out of? [Re: RapidRobert] #2561886
10/10/18 12:45 PM
10/10/18 12:45 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
http://www.moparts.org/Tech/Archive/motor/36.html
Re: Strange 1979 440, what's it out of? [Re: Hugh Jorgan] #2561936
10/10/18 02:22 PM
10/10/18 02:22 PM
The heads are 452's, casting dates on them are 1-25-78
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2562136
10/10/18 09:14 PM
10/10/18 09:14 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Those mounts and valve covers were used in Class B and C motor homes. Class A used a different mount.
The heads probably have steam ports on the exhaust valves. Motor home version of the 452. I have a set of those.
I agree that it is a 79 model year RV. 78 was the last year in cars and pickups but I have seen them in 79 and 80 model year RV's
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Strange 1979 440, what's it out of? [Re: GODSCOUNTRY340] #2562237
10/11/18 12:55 AM
10/11/18 12:55 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I thought that even the 413 "industrial" was used for several years after the cars and trucks were feing fitted with the 426 wedge and even 440 engines.
Re: Strange 1979 440, what's it out of? [Re: Kern Dog] #2571157
10/29/18 07:00 PM
10/29/18 07:00 PM
dogdays Offline
dogdays  Offline
6bbl definitely got it right
The 9 definitely means it was installed in a 1979 model year vehicle. The T means Trenton engine plant. The E means it came with a cast crank. The date is the date the engine was assembled. The last 440s were built in August of 1978 so this engine was one of the last 440s from the original molds. It took Chrysler another year to use up all of the 440s. I believe that there were some 1979 440 powered one ton pickups and vans.
Literature also says there were 413s being built into the late '70s. They were the heavier duty engines.
The Maltese cross means undersized bearing journals.
Here's a quote that is pretty right:
Decoding Engine Stampings and Casting Numbers
Decoding the Stampings on Engine Pads:
A .020 oversize cylinder bores
Diamond Oversize tappets
E Cast Crankshaft
HP High Performance
L or LC Low compression
Maltese Cross .001" undersize main bearing journals
Maltese Cross & an X .010" undersized crankshaft rod journals
O.S. .005" oversize valve stems
P Premium Fuel
R Regular Fuel
RX or MX All main and rod journals .010" undersized
S Special engine
WT or TW Water Test
X .010" undersize crankshaft
Decoding the Year Codes for B & RB Engines:
(Stamped on engine pad)
A 1965
B 1966
C 1967
D 1968
E 1969
F 1970
G 1971
H 1972
J 1973
P 1960
R 1961
S 1962
T 1963
V 1964
4T 1974
5T 1975
6T 1976
7T 1977
8T 1978
We have visual proof of a 9T as well, but that's all, folks!
Chrysler had a fire sale and declared they were going out of the bigblock business forever. They scrapped the molds and I remember seeing brand new 452 heads selling bare for $60 apiece. 400 shortblocks in crates were $400, and a cast 440 crank was something like $80. Of course, I didn't have any money at the time so they are only memories.
R.
If the "440" had a "T" after it, that meant the engine came in a truck.
