Gear drives? #2561091
10/08/18 09:44 PM
10/08/18 09:44 PM
illinois
bigblk66_coronet Offline OP
illinois
Looking to switch to a gear drive on my 440. Anyone have any luck with this style gear drive?
https://www.jegs.com/i/JEGS/555/20361/10002/-1
66 Dodge Coronet 500 440w/727 11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust Best ET. 12.38 @110 in street trim
Re: Gear drives? [Re: bigblk66_coronet] #2561096
10/08/18 09:51 PM
10/08/18 09:51 PM
crabman173
crabman173
Why? It is a HP loss on average--do you just want the noise? If you want the whine then hey go for it! It is very popular--they sell tons of them but if you are after best performance it is not the way to go
Bear in mind you may have to grind on the block some depending on which unit you get--and if you were planning an in car install that would make it a no go
This is all just my opinion--you want the whine--I say do it
Re: Gear drives? [Re: ] #2561100
10/08/18 09:56 PM
10/08/18 09:56 PM
illinois
illinois
Well many many many years ago i used to run a noisey one on my camaro and loved it. i have the motor out installing new gaskets and detailing. Figured id check the chain out and if its bad id put a gear drive in it. I used to run the car and it will run 12.0s but pretty much over the racing. Just want to cruise. I see the Milodon style is totally different than this one.
Re: Gear drives? [Re: bigblk66_coronet] #2561107
10/08/18 10:07 PM
10/08/18 10:07 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
X2....
The gear drive noise is a product of friction. Not what you typically look for in engine parts, I’d worry about the harmonics creating issues in the valvetrain, but that’s just me. If you’re just looking to turn heads as you cruise, that’ll do the job.
Re: Gear drives? [Re: StealthWedge67] #2561127
10/08/18 10:42 PM
10/08/18 10:42 PM
Originally Posted By StealthWedge67
X2....
iagree
When that type(Jackson) of dual idler gear drives first came out they where a cheap alternative to the better racing brands like Milidon, Keith Black and Donovan. A friend of mine bought one for his BB Chey powered 1955 Thunderbird Modified Production car, one of the ends of a Tru Arc snap ring broke off and ended up in the oil pump shearing the shaft off ruining the motor down
He went back to a good timing set after that up work
I have used several different brands of the conventional gear drives and a Jesel belt drive as well as a bunch of the real expensive racing timing sets, pick your poison scope work All of them can fail if you beat on them long enough shock grin shruggy
Re: Gear drives? [Re: bigblk66_coronet] #2561130
10/08/18 10:51 PM
10/08/18 10:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I think those are made in chino. Milodon's are USA, at least that's what they claim.
Re: Gear drives? [Re: bigblk66_coronet] #2561133
10/08/18 10:55 PM
10/08/18 10:55 PM
Washington
madscientist Offline
Washington
If you are going to run a gear drive (I do, even in my SFT street engine) spend the money and buy the fixed idler style like the Milodon.
They don't make noise, they don't cost HP and they don't break cranks. For all I've heard, there is not ONE test I can find that proves any of that when comparing a chain or a belt to a fixed idler gear drive.
Spend the money, buy the Milodon and forget it.
Re: Gear drives? [Re: bigblk66_coronet] #2561170
10/08/18 11:45 PM
10/08/18 11:45 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Ran one for 20+ years without issue. Ran several cams with the same drive.
Re: Gear drives? [Re: gsmopar] #2561229
10/09/18 01:51 AM
10/09/18 01:51 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My brother has two engines with the Milodon gear drives. They do make a small amount of sound, but you only really notice it at idle. I can hear it because I know to listen for it, but I bet most people don't pick up on it. Once you put the car in gear and drive away the little sound it produces is drowned out by the exhaust.
I would buy a Milodon or just stick with a nice chain setup if you don't want to spend the $$$.
Re: Gear drives? [Re: bigblk66_coronet] #2561242
10/09/18 02:24 AM
10/09/18 02:24 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Milodon on my Challenger since 2005. It's been off and on the engine a couple times and had a couple of different cams. Pretty cool deal when you can dial in your cam and forget about it. Like a 40spline Dana 60. All I ever do is replace the lifters and intermediate shaft gear every couple hundred passes. I have a Jesel belt that I haven't to this day installed. If you are going to spend the money on a quality piece I would go ahead and buy the Jesel. If I could afford it, I would get a crank driven oil pump and an F.I. unit and eliminate ALL the gears from the engine.
Re: Gear drives? [Re: bigblk66_coronet] #2561282
10/09/18 07:21 AM
10/09/18 07:21 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've got a Million unit on my 605. I won't even consider a timing chain. I have .060 clearance between the cam lobes and the rods.
Re: Gear drives? [Re: bigblk66_coronet] #2561319
10/09/18 10:45 AM
10/09/18 10:45 AM
Boise
Moparteacher Offline
Boise
Ran one on the last engine break-in. Crank gear was a sloppy fit on the crank and required shim stock shimming for a zero fit. Cam bolts were cheap and required replacement. Buttons on idler gears grooved timing cover; nice little circles like eye balls after a few hours of run time.
But, FWIW my memory tells me it was a China brand. So....
Re: Gear drives? [Re: bigblk66_coronet] #2561321
10/09/18 10:49 AM
10/09/18 10:49 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Dual idlers can not compensate for any deviation in crank height from line honing. If the block was line honed then the fit will be tight - maybe too tight. Or left stock it could be too loose. Years ago I had a Milodon style but it could have been a Donovan or KB. It had an adjustable idler. The problem was the idler was a different diameter than the other two gears so if you started dialing in the cam with the dots lined up, they didn't line up again after one crank revolution. If you forgot how many turns you'd done you had to remove the sprockets to line the dots up again. I gave up and switched to a chain. With the Milodon style, water pump clearance will be an issue and then the crank pulley will need a spacer.
Re: Gear drives? [Re: bigblk66_coronet] #2561323
10/09/18 10:57 AM
10/09/18 10:57 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
There is no good reason to run a gear drive when belt drives are available!!
Re: Gear drives? [Re: DoubleD] #2561329
10/09/18 11:25 AM
10/09/18 11:25 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My crank guy has a 7 second car and he went from a gear drive to a belt and lost 60ft time. Put the gear drive back on out of curiosity and the car went back to what it used to run. He suspected the belt was stretching under load and altering the timing.
Re: Gear drives? [Re: bigblk66_coronet] #2561340
10/09/18 12:02 PM
10/09/18 12:02 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've used a Pete Jackson (that style) before. There's nothing wrong with them. They will work like everything else. Easy to set up. And I guess the 18 year old in me likes the whine.
2011 Drag Pak Challenger
Re: Gear drives? [Re: bigblk66_coronet] #2562063
10/10/18 06:19 PM
10/10/18 06:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We put a Pete Jackson in my sons 413 62 300.It was in at least 15 years and nevar a problem.Was still going good when he sold it.He put lots of highway miles and strip trips also.Probally more than most here.Rocky
Chrysler Firepower
Re: Gear drives? [Re: bigblk66_coronet] #2562439
10/11/18 01:44 PM
10/11/18 01:44 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Have the same Milodon drive for 25 years.If set up and clearanced properly it's not much whine.The whine on the blower is not that bad inless the belt is very tight.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Gear drives? [Re: bigblk66_coronet] #2562830
10/12/18 11:53 AM
10/12/18 11:53 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I agree with mad scientist. I have a milodon gear drive in my 408 stroker. I can't hear the whine over the exhaust.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Gear drives? [Re: mopardude318] #2562861
10/12/18 12:54 PM
10/12/18 12:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Do the Milodon drives fit under a stock cover?
'63 Dodge 330
11.19 @ 121 mph
