How do I change 1989 2wd Dakota UCA bushings #2561102
10/08/18 09:58 PM
10/08/18 09:58 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Howdy
I just started rebuilding the front suspension on my 1989 two wheel drive dakota. I have put upper control arm bushings in a bunch of A-bodies but this style with a pivot bar is new to me! I have torches, air chisel, a small shop press, and a decent collection of press tooling plus a good vise and big hammers.
All the ways I have removed UCAs before use allthread or bolts thru the bushings which are currently occupied by the pivot bar.
So far I got the lower control arm jacked up, the ball joints loose, the rusty shock stripped, marked the alignment for reinstallation, and took the pivot bar nuts off. I had to order a bigger upper ball joint socket- 2 9/64” or something. I won’t be removing the UCA to do the bushings until after I unscrew the ball joint so I have a couple days to think about how to get the top bushings out. I’m guessing it will be kind of like doing bearing caps on a universal joint where the pivot bar is captured in there?
Thanks in advance for any help!
Re: How do I change 1989 2wd Dakota UCA bushings [Re: radar] #2561144
10/08/18 11:11 PM
10/08/18 11:11 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Look on ebay.
There are all kinds of bushing, removal, and installation tools, kits to do that type of suspension work.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: How do I change 1989 2wd Dakota UCA bushings [Re: radar] #2561148
10/08/18 11:15 PM
10/08/18 11:15 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
I think I’m going to try the good old air chisel
Re: How do I change 1989 2wd Dakota UCA bushings [Re: radar] #2561206
10/09/18 12:59 AM
10/09/18 12:59 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
You might be able to find a local shop that will R&R the bushings if you take them the arms to them. This is the route I take.
twocents
John
Re: How do I change 1989 2wd Dakota UCA bushings [Re: radar] #2562357
10/11/18 11:30 AM
10/11/18 11:30 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Air chisel did the job on the UCA bushings I crushed the sleeves into themselves a little to relieve the press fit then hit and pried on the flange and after a while they came free. Unscrewing the upper ball joint was much worse I ended up dragging the ox/a torch out and using a six foot breaker bar before it started moving and that was still giving it everything I got. And I’m 6’3” 300lbs!
