15x7 steel wheel options #2558974
10/04/18 04:56 PM
10/04/18 04:56 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
I'm thinking of getting a set of Steel wheels (2998450s) for my T/A since I learned they were original on the car. I always liked them on my old red T/A.
I see Tony sells repos for $1k a set. But I see there are other companies who have them for less money. I don't really care about the part numbers or date codes but I do want them to look correct and hold the hub cap and trim ring and show the proper gap. Any thoughts on the competitors compared to Tony's wheels? Thanks!
1970 Dodge Challenger T/A
Re: 15x7 steel wheel options [Re: jeff968] #2559034
10/04/18 07:34 PM
10/04/18 07:34 PM
WV
Little Detroit Offline
WV
who are the other companies you are asking about??
Re: 15x7 steel wheel options [Re: jeff968] #2559050
10/04/18 08:40 PM
10/04/18 08:40 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Why would you not want to support Tony and his effort to get these things reproduced?
I don't know what the other guys wheels look like but Tony's are very close to the real deal.
Something else could stick out like a sore thumb.
Re: 15x7 steel wheel options [Re: Morty426] #2559056
10/04/18 08:46 PM
10/04/18 08:46 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
It's not that I don't want to support him. That quality wheel is not exactly what I'm looking for. My car is a driver.
These wheels are less $108 each. Are they the same minus the numbers? Thx
Steelies
Re: 15x7 steel wheel options [Re: jeff968] #2559058
10/04/18 08:51 PM
10/04/18 08:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Those do not have the distinct 450 look with the wide band in the outer rim, but with the trim ring on you can't see it anyway.
Re: 15x7 steel wheel options [Re: jeff968] #2559101
10/04/18 10:13 PM
10/04/18 10:13 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
You get what you pay for. You already know the answer. The parameters you list in your first post tell you what wheel to buy.
Re: 15x7 steel wheel options [Re: jeff968] #2559149
10/04/18 11:51 PM
10/04/18 11:51 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
It’s only money...life’s too short 😊
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 15x7 steel wheel options [Re: BloFish] #2559164
10/05/18 12:20 AM
10/05/18 12:20 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Only to those who have excess!! stirthepot
Re: 15x7 steel wheel options [Re: jeff968] #2559183
10/05/18 12:49 AM
10/05/18 12:49 AM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
If your gonna run a trim ring and hubcap on a driver you would be a fool to spend over twice the money for something you don't see. 9 out of ten guys walking by wouldn't know the difference.
Re: 15x7 steel wheel options [Re: 62maxwgn] #2559231
10/05/18 02:39 AM
10/05/18 02:39 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Who has excess?
Never met him
Still I would spend extra for quality
Actually since I am a purist I would only run an original wheel - even on a driver
But that's just me
Re: 15x7 steel wheel options [Re: ratroaster] #2559232
10/05/18 02:42 AM
10/05/18 02:42 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I can understand this, but if it is a real TA it needs real parts IMO. If you can't afford real parts get the best repo available.
If it's a Clown car then go ahead and get Clown parts because no one cares
Re: 15x7 steel wheel options [Re: ratroaster] #2559370
10/05/18 01:07 PM
10/05/18 01:07 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That being the case,the late 70's Diplomat/Grand Fury and LeBaron used a 15x7 wheel, (bottom two) with cap and trim ring,as said most wouldn't know the difference ,depends on what you want.
Re: 15x7 steel wheel options [Re: ratroaster] #2559417
10/05/18 02:14 PM
10/05/18 02:14 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Wise words and what I was looking for.
Thanks for the thoughts.
It is a real T/A, not matching numbers, a driver, not a clown car.
Re: 15x7 steel wheel options [Re: jeff968] #2559489
10/05/18 03:57 PM
10/05/18 03:57 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Didn't really get an answer to your question.
Re: 15x7 steel wheel options [Re: CDN72SE] #2559497
10/05/18 04:06 PM
10/05/18 04:06 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Nothing else is really close to original except Tony's.
Re: 15x7 steel wheel options [Re: CDN72SE] #2559511
10/05/18 04:31 PM
10/05/18 04:31 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
I did. Others have stated that there are differences with the alternatives but nothing you can see with the cap and trim ring installed. I still may go the Tony's route but I have to think about it. Again, thanks for the thoughts.
Re: 15x7 steel wheel options [Re: jeff968] #2559632
10/05/18 08:40 PM
10/05/18 08:40 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Jeff why not go used and save even more money?
I have two 15x7 wheels part number 4117054 that probably came on a 79 van or something.
I fitted the trim ring and center cap - they fit perfect. Once the trim ring is on you can't tell.
It would cost more in shipping then what I would want for the rims. You just need too find two more
Re: 15x7 steel wheel options [Re: jeff968] #2559710
10/06/18 12:20 AM
10/06/18 12:20 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
On the later wheels , the 15 x 7 ralley wheel trim ring does not fit correctly.
The center part of a 450 wheel is actually a 14 inch wheel center in a 15 inch ralley wheel band. So the ralley wheel trim ring fits the ralley wheel band correctly.
Later 15 steel wheel bands are 13.25 inside.
The 15 inch ralley wheel band is 12.25 inside.
So there is no way it looks right or fits right.
That's why the wheels are so special.
Also I sell the same 450 wheels as Tony , for the same price.
Frank
Re: 15x7 steel wheel options [Re: jeff968] #2560744
10/08/18 10:36 AM
10/08/18 10:36 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I have the cheap wheel vintiques 15x7 steelies. Compared to my factory 15x6 steelies, they aren't a crisp stamping. They also won't hold the hubcaps tight enough, they stay on when sitting still, but any driving is going to throw them off. My next set is going to be from Tony's. I've put 8k miles on them with no other complaints.
Duster 2, I saw your post after posting mine, I didn't realize you sold the newer repop as well. What town are you close to in Indiana? I'd love to take a look at those wheels if I ever have a free day again.
Re: 15x7 steel wheel options [Re: jeff968] #2560886
10/08/18 02:27 PM
10/08/18 02:27 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
I am near Terre Haute , Indiana. I sell the 450 wheels and the 10 inch dogdish cap wheel centers ( build your own , Welder Up style , artile in Mopar Collectors Guide ).
I also sell Magnum 500 , Ralley and steel wheels from Coker - Specialty Wheels for the last 20 some years.....
Frank
