70RR- Rear shock mounting hardware #2560484
10/07/18 07:50 PM
10/07/18 07:50 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
In need.... best place...?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70RR- Rear shock mounting hardware [Re: JMCFAN] #2560581
10/07/18 11:21 PM
10/07/18 11:21 PM
BlueRacer69 Offline
BlueRacer69  Offline
Are you talking about the inner and outer washers, and the nuts? If so, they are being reproduced and you can buy them on E-bay. Do a search for Mopar rear shock washers. Sellers name is: dodgeboy
Re: 70RR- Rear shock mounting hardware [Re: JMCFAN] #2560821
10/08/18 12:34 PM
10/08/18 12:34 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks! I found the listing but shows not compatible with 70RR....?
Re: 70RR- Rear shock mounting hardware [Re: JMCFAN] #2561115
10/08/18 10:20 PM
10/08/18 10:20 PM
BlueRacer69 Offline
BlueRacer69  Offline
Look again. The same seller has them advertised for B and E bodies also in another listing. If you don't trust that they are the right ones, check with YearOne or Classic Industries. I'm sure they both have them too. Don't always trust the compatible charts, sometimes they are wrong.
Re: 70RR- Rear shock mounting hardware [Re: BlueRacer69] #2561125
10/08/18 10:35 PM
10/08/18 10:35 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks! ordered from Classic Indus. Not too bad $$
