proper way to repaint a car to best get factory look #2560104
10/06/18 09:52 PM
10/06/18 09:52 PM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
Is there any book or "how to" instructions to get the best look or technique for repainting a car? A friend of mine is starting a full blown resto on his car and is trying to get accurate information for the painter. I'm familiar with the dip tank primer process but is there any certain way or order the body color was applied?
thanks.
inherited a 69 roadrunner from my grand pop.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560123
10/06/18 10:30 PM
10/06/18 10:30 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
First - get the right paint
Second - have the car assembled like the factory assembled it before it was painted
Third - paint it the same way the factory did, all at once with overspray here and there
It's my opinion they painted the car from the inside out, so interior then trunk then engine compartment then the car
Need more info like what kind of car to better answer your question
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560152
10/06/18 11:12 PM
10/06/18 11:12 PM
Greenwood Lake, NY
Greenwood Lake, NY
He is doing a GTX. What would have been already assembled? I'm guessing doors, fenders, hood, trunk lid were all attached already? He is looking to do a base clear vs the single stage.
I also know the GTX got that organisol paint on the lower part of the car below the body molding. Would the color of the car been painted all the way down or just down far enough past that molding so as they did not waste paint?
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560161
10/06/18 11:33 PM
10/06/18 11:33 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The factory used single stage enamel so hes already going in the wrong direction using base clear if factory is truly the goal.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560178
10/07/18 12:02 AM
10/07/18 12:02 AM
Greenwood Lake, NY
Greenwood Lake, NY
true but isn't OE allowing base clear from what I heard? Either way, thats the paint he wants to use and I don't think he will ever go OE judging with the car. I guess his main goal is to make it appear like it was factory using modern paints and such.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560179
10/07/18 12:05 AM
10/07/18 12:05 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, well the problem with asking purists thier opinions/advice on details like these is that you may not always hear what you want to hear.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560183
10/07/18 12:11 AM
10/07/18 12:11 AM
Greenwood Lake, NY
Greenwood Lake, NY
no problem. since I'm going to be helping him disassemble and reassemble the car, I figured I'd try and get as much info for him as possible to help with the resto.
I do know that he has planned on keeping the undercarriage the primer gray and not paint it the full color of the car like over restored cars get.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560186
10/07/18 12:16 AM
10/07/18 12:16 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, the factory dip and primer with color over spray as per factory is definately the trend
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560193
10/07/18 12:36 AM
10/07/18 12:36 AM
Greenwood Lake, NY
Greenwood Lake, NY
yup, thats what he is trying to go for.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560198
10/07/18 12:49 AM
10/07/18 12:49 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you want a good factory look, have him drink a six pack about an hour before he starts. That should about do it.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560207
10/07/18 01:25 AM
10/07/18 01:25 AM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
The main issue with using two stage paint is that you paint all of the bolts in the engine compartment as the whole front clip is assembled. If you use base coat clear coat, what usually happens is the paint/clear builds up really thick on all of the fasteners in the engine compartment, and it just doesn't look right at all. If you use single stage, it doesn't look like thick frosting on the bolt heads and sheet metal edges. If you touch any of these bolts, obviously you crack the paint, and this doesn't look right either. I'm not aware of any "normal" factory process that adjusts the sheet metal after the car is painted. I understand that the doors, truck lid, and front clip are all adjusted and painted on the car - so there's no reason to adjust later. I know on E Bodies the rear fascia was installed after the car was painted, but that is the only piece as I understand. Also, look for other sealers on the front fenders or any other sprays anywhere on the car as it's taken apart. This is the best way to know how the car should look on reassembly. Document what you find if the car has never been taken apart as this is by far the best information you can use to put it back together. Best of luck!!!!!!
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560215
10/07/18 01:47 AM
10/07/18 01:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Is there a reason you can't tell us the year? Over communicate, please!
I'm assuming it's a 69 but it matters. It also matters what factory it came from.
As Scott pointed out if he's going two stage he's already failed so what's the point?
You asked for correct, is that what he wants or is he going down the Home Depot to buy some Krylon?
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560239
10/07/18 05:01 AM
10/07/18 05:01 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yes. Body shell plus everything that is body color, as carefully noted during disassembly, such as the following list that is correct for a '69 A body and may not be correct for a GTX. But this list will give you an idea what to look for.
Body shell, partially
Upper rear shock mounting studs
Side marker housings, 4
Hood, all over
Hood Hinges, partially, and fasteners
Hood Striker and fasteners, all over
Front Fenders (except wheel well) and fasteners, exterior only
Fender tag, all over, and one screw
Yoke Cross member and fasteners, partial
Hood Lock Vertical Support and fasteners, partial
Upper Grille Panel and fasteners, exterior only
Lower Grille Panel and fasteners, exterior only
Battery Tray, Battery Tray Brace, and fasteners
Doors, except interior of weatherstripping.
Door Hinges and fasteners, partial
Deck Lid, all over
Deck Lid Hinges.
Deck Lid Hinge Supports (welded to body), partially
Deck Lid Torsion Bars, partially
Other paint: doors interior of weatherstripping, called UDF (upper door frame) color and LDF (lower door frame) color, door frame plastic plugs, and also quarter panel interior; door lock knobs; roof rails; A pillar plastic covers; quarter panel lower garnish.
In addition there are some special things to note about sealers in the engine compartment at the cowl and on fenders as noted in the photos.
Body paint notes. Fender, battery tray..jpgBody paint notes. 4 putty blobs at cowl pinch weld..jpgBody paint notes. Putty blobs at front corners...jpgBody paint notes. Sealant ooze at cowl pinch weld..jpg
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560240
10/07/18 05:05 AM
10/07/18 05:05 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This photo shows quarter panel interior to be painted UDF color.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560241
10/07/18 05:40 AM
10/07/18 05:40 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
There are other instructions that you may want your painter to know, such as in these photos.
Body paint notes.  Color of gray dip primer..jpgBody paint notes.  Missing body paint at ody of firewall..jpgBody paint notes. Weld tear in hood.jpgBody paint notes.  F8 Dark Green on quarter panel garnish and roof rails..jpg
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560242
10/07/18 05:49 AM
10/07/18 05:49 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Another special paint consideration I have never seen discussed in this forum is: what will the backsides of parts bolted to the body shell be painted?
One example is the battery tray and brace. If they are painted while bolted to the inner fender, the backsides will receive no paint. And the part of the inner fender covered by the tray and brace won't get painted either. A solution is to paint the tray and brace all over while loose and bolt to the painted inner fender with painted fasteners. Or paint the parts all over while loose and again while bolted on.
A similar situation is the backsides of grille sheet metal panels. These backsides were coated with dip primer at the factory. For restoration painting, something better than primer would be preferable, such as a primer followed by a top coat that looks like factory dip primer before bolting on the car.
In the case of the hood hinges, the factory hand painted the hinge/hood interfaces with green zinc chromate paint. This green zinc chromate may have also been hand painted on the interfaces of some grille sheet metal parts, such as the yoke cross member, before it was bolted on. (I stripped all paint off this part before I knew to look for factory hand paint.)
Photo shows hood hinge painted body color F5 Limelight Metallic Green. The darker green on the bolt joint interface is factory hand painted zinc chromate.
23-6 Hood.L hinge3 darker green is hand brushed primer.jpg07-1 grille.sheet metal assembly.jpg
Re: proper way to repaint a car to best get factory look [Re: Morty426] #2560565
10/07/18 10:49 PM
10/07/18 10:49 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Those two points I agree are VERY important!!! Started to restore my '69 LA plant GTX with points that I knew from Lynch Road and St. Louis assembly plant '68 and '69 cars and they were not done the same at the LA assembly plant. Even some of the decal placements were different on the LA assembly plant GTX and there were reasons for them being place differently......one was funny to the point of disappointment as I thought someone had replaced the radiator support.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560576
10/07/18 11:14 PM
10/07/18 11:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Even within the same plant in the same month there are differences.
Lots of different employees, different shifts, temperature & humidity when the car was dipped, sprayed, etc., etc.
So........
Your car was there when it was built, so it is the best evidence you can find, explore & discover all you can.
Record the details with a camera & start a file.
Document what you find on your own car & then put it back to the same way, anything less (or more) is not a true restoration.
Re: proper way to repaint a car to best get factory look [Re: fuelishnsilly] #2560584
10/07/18 11:25 PM
10/07/18 11:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The elephant in the room is that the OP is not the owner/builder. This is the the kind of information that you really shouldn't rely on your buddy to seek out and supply. If you are doing a serious O.E. type build you need to be directly involved. .02
Re: proper way to repaint a car to best get factory look [Re: Morty426] #2560597
10/07/18 11:46 PM
10/07/18 11:46 PM
Greenwood Lake, NY
Greenwood Lake, NY
Morty,
He is using PPG automotive paint and not Krylon. Also, if using Base / Clear is so bad, why are manufacturers using that on cars today? And isn't OE now allowing base / clear also? Whats wrong with having radial tires on a car when the originals were the bias ply tires? Maybe he is missing the mark by using PPG instead of whatever brand of paint the factory used? Seriously, he is trying to make it look like how it would have been in 1969 with the gray primer showing and all but it shouldn't matter if he uses base / clear and radial tires since he is not building an OE car nor plans on doing that route.
