Re: JE branded rings. Anyone?
[Re: ZIPPY]
#2559508
10/05/18 04:28 PM
10/05/18 04:28 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Thank you The marketing name I'm looking at is "Pro Seal Premium Sportsman Series" for what it's worth.
[Re: ZIPPY]
#2559540
10/05/18 05:17 PM
10/05/18 05:17 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
JE pistons and rings in mine also...
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: ZIPPY]
#2559563
10/05/18 05:50 PM
10/05/18 05:50 PM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Member Vic Elinger that races the 440 powered Volvo works for Wiseco and could easily answer this question but I havenโt seen him around in a long time. Iโm better there are only a few manufacturers and they are rebaged
[Re: ZIPPY]
#2559575
10/05/18 06:29 PM
10/05/18 06:29 PM
Posts: 3,396 Pa
Hot 340
Pa
Yep, added to watch list.
Is it the oil expander that jumps out at you?
I've never used total seal and don't know.
Do you think they are most likely Total Seal "Classic Race (street)" or whatever they are marketing their normal non-gapless ring as these days?
The JE branded (in the picture) appear to be an awful lot like FM/Speed Pro/Sealed Power/whatever they are calling themselves lately. Id bet they are a street friendly ring. The price and materials used warrant that assumption. Not sure what you mean about the oil expander tho...it was just like any other I have used...ive used Total Seal a few different times, motors always sealed up fine. I like their stuff.๐
[Re: ZIPPY]
#2559576
10/05/18 06:35 PM
10/05/18 06:35 PM
ZIPPY
S.E. Michigan
I was referring to what seems to be a gold-ish color to the oil expander, in the picture of that particular set.
The picture is probably not accurate though just like most other catalogs!
[Re: ZIPPY]
#2559584
10/05/18 06:47 PM
10/05/18 06:47 PM
Posts: 3,396 Pa
Hot 340
Pa
The rings had a "TS" marked on them, and were literally bagged in Total Seal packaging in the Howards box.
[Re: Discoquik]
#2562949
10/12/18 03:33 PM
10/12/18 03:33 PM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The Pro Seal ring is a Mahle piece, steel top, napier second, standard and light tension oil sets are available, FYI there are only a handful of ring suppliers to the automotive world, just like cam cores, gaskets, bearings, cranks and rods and yes even castings and forgings. Most times it is a matter of specifications that make a brand unique vs the material. Wholly Crap!!!!!!!!!!!!!! And I thought he disappeared.
