74 Cuda LA360/904 noise, please listen #2559124
10/04/18 11:05 PM
10/04/18 11:05 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi All,
Finished my restore three years ago and been driving without issues. The engine is a 78 360 75k on it. I replaced all pumps and seals but left the piston, and crank assembly alone. I had the heads redone and replaced timing chain, etc.
The 904 is stock, I adjusted the bands and replaced the filter and drained everything including the torque converter.
I installed a B and M flex plate and verified the part number before posting this. Also I have dropped the transmission to check the plate and it looks fine, its still mounted, but I can see most of it.
I think I have had now for a while some piston slap that would disappear after warm up, so now I'm not sure if this sound is related.
So take a listen, hopefully I have copied this URL correctly.
If you can see in the video, the noise is most noticeable inside at the trans hump. I can also feel the knock on the passenger side motor mount.
https://youtu.be/LkGI0o7617w
Re: 74 Cuda LA360/904 noise, please listen [Re: cudabitten] #2559285
10/05/18 09:46 AM
10/05/18 09:46 AM
Australia
dodgy Offline
dodgy  Offline
Australia
hard to tell, sounds to me like its touching the body somewhere, maybe a socket or spanner fell down and got wedged against body/trans case, just a thought.
Re: 74 Cuda LA360/904 noise, please listen [Re: dodgy] #2559411
10/05/18 02:03 PM
10/05/18 02:03 PM
moparx Offline
moparx  Offline
when my brother was growing up, i had a bunch of tools come up missing. usually, some were found when "strange noises" came up for me to diagnose. laugh2 funny how that works. one time, i found a 5/8" open/box wrench still attached to the upper starter bolt on my sister's 74 satelite [318]. come to find out it was left there when my bro changed the battery cable on the starter, stuffed it back in, then couldn't get the wrench off the bolt after tightening it. ah well, just leave it in there ........ no noises, so i didn't find that one until a couple years later when she had starter problems.
beer
Re: 74 Cuda LA360/904 noise, please listen [Re: cudabitten] #2559414
10/05/18 02:08 PM
10/05/18 02:08 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Exhaust hitting the transmission cross member and did you use blue loctite on the converter bolts.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 74 Cuda LA360/904 noise, please listen [Re: cudabitten] #2559738
10/06/18 02:05 AM
10/06/18 02:05 AM
bearing (I think there are vids/info on how to somewhat accurately tell if it is a rod or a main). less likely piston/pin issue. Just me, the prognosis dont sound good (needs to be opened up).
Re: 74 Cuda LA360/904 noise, please listen [Re: cudabitten] #2559739
10/06/18 02:11 AM
10/06/18 02:11 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Check to see if one or more flex plate bolts has come loose.
If one or more back out, the bolt heads rub on the webbing at the back of the engine.
Re: 74 Cuda LA360/904 noise, please listen [Re: Alaskan_TA] #2559871
10/06/18 01:34 PM
10/06/18 01:34 PM
^^^ agreed, definitely an easier non invasive check.
Re: 74 Cuda LA360/904 noise, please listen [Re: Alaskan_TA] #2559876
10/06/18 01:43 PM
10/06/18 01:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
In his first post he said he dropped the plate and can see most of the flex plate.
I'd cut the oil filter open and I bet you find metal. If so time for a engine rebuild.
Re: 74 Cuda LA360/904 noise, please listen [Re: cudabitten] #2559952
10/06/18 05:08 PM
10/06/18 05:08 PM
GA
roadrunninMark Offline
GA
How is the transmission mount?
