15x7 steel wheel options
#2558974
10/04/18 04:56 PM
10/04/18 04:56 PM
Posts: 4,051 Connecticut
jeff968
Connecticut
I'm thinking of getting a set of Steel wheels (2998450s) for my T/A since I learned they were original on the car. I always liked them on my old red T/A.
I see Tony sells repos for $1k a set. But I see there are other companies who have them for less money. I don't really care about the part numbers or date codes but I do want them to look correct and hold the hub cap and trim ring and show the proper gap. Any thoughts on the competitors compared to Tony's wheels? Thanks!
1970 Dodge Challenger T/A
Re: 15x7 steel wheel options
[Re: Morty426]
#2559056
10/04/18 08:46 PM
10/04/18 08:46 PM
jeff968
Connecticut
Why would you not want to support Tony and his effort to get these things reproduced?
I don't know what the other guys wheels look like but Tony's are very close to the real deal.
Something else could stick out like a sore thumb. It's not that I don't want to support him. That quality wheel is not exactly what I'm looking for. My car is a driver. These wheels are less $108 each. Are they the same minus the numbers? Thx Steelies
[Re: jeff968]
#2559149
10/04/18 11:51 PM
10/04/18 11:51 PM
Posts: 16,493 On the run…
BloFish
On the run…
It’s only money...life’s too short 😊
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 62maxwgn]
#2559231
10/05/18 02:39 AM
10/05/18 02:39 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
It’s only money...life’s too short 😊 Only to those who have excess!! Who has excess? Never met him Still I would spend extra for quality Actually since I am a purist I would only run an original wheel - even on a driver But that's just me
[Re: ratroaster]
#2559232
10/05/18 02:42 AM
10/05/18 02:42 AM
Morty426
Sacramento CA
If your gonna run a trim ring and hubcap on a driver you would be a fool to spend over twice the money for something you don't see. 9 out of ten guys walking by wouldn't know the difference. I can understand this, but if it is a real TA it needs real parts IMO. If you can't afford real parts get the best repo available. If it's a Clown car then go ahead and get Clown parts because no one cares
[Re: ratroaster]
#2559370
10/05/18 01:07 PM
10/05/18 01:07 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If your gonna run a trim ring and hubcap on a driver you would be a fool to spend over twice the money for something you don't see. 9 out of ten guys walking by wouldn't know the difference. That being the case,the late 70's Diplomat/Grand Fury and LeBaron used a 15x7 wheel, (bottom two) with cap and trim ring,as said most wouldn't know the difference ,depends on what you want.
[Re: ratroaster]
#2559417
10/05/18 02:14 PM
10/05/18 02:14 PM
jeff968
Connecticut
If your gonna run a trim ring and hubcap on a driver you would be a fool to spend over twice the money for something you don't see. 9 out of ten guys walking by wouldn't know the difference. Wise words and what I was looking for. Thanks for the thoughts. It is a real T/A, not matching numbers, a driver, not a clown car.
[Re: CDN72SE]
#2559511
10/05/18 04:31 PM
10/05/18 04:31 PM
jeff968
Connecticut
Didn't really get an answer to your question. I did. Others have stated that there are differences with the alternatives but nothing you can see with the cap and trim ring installed. I still may go the Tony's route but I have to think about it. Again, thanks for the thoughts.
[Re: jeff968]
#2559632
10/05/18 08:40 PM
10/05/18 08:40 PM
Morty426
Sacramento CA
Didn't really get an answer to your question. I did. Others have stated that there are differences with the alternatives but nothing you can see with the cap and trim ring installed. I still may go the Tony's route but I have to think about it. Again, thanks for the thoughts. Jeff why not go used and save even more money? I have two 15x7 wheels part number 4117054 that probably came on a 79 van or something. I fitted the trim ring and center cap - they fit perfect. Once the trim ring is on you can't tell. It would cost more in shipping then what I would want for the rims. You just need too find two more
[Re: jeff968]
#2560744
10/08/18 10:36 AM
10/08/18 10:36 AM
Posts: 314 Northeast Indiana
73DAD
Northeast Indiana
I have the cheap wheel vintiques 15x7 steelies. Compared to my factory 15x6 steelies, they aren't a crisp stamping. They also won't hold the hubcaps tight enough, they stay on when sitting still, but any driving is going to throw them off. My next set is going to be from Tony's. I've put 8k miles on them with no other complaints.
Duster 2, I saw your post after posting mine, I didn't realize you sold the newer repop as well. What town are you close to in Indiana? I'd love to take a look at those wheels if I ever have a free day again.
