Is this a bare Stealth head? #2558060
10/03/18 12:59 AM
10/03/18 12:59 AM
West Plains, MO
DrCharles Offline OP
West Plains, MO
ebay 291722416620
$278 per head (bare) sounds pretty good, considering a Stealth is $500 and the valve springs/locks will be discarded, and I've read that the valve seats and guides may need work anyhow. They've sold a bunch of them.
Thoughts? work
Re: Is this a bare Stealth head? [Re: DrCharles] #2558062
10/03/18 01:18 AM
10/03/18 01:18 AM
Kirkland, Washington
Pacnorthcuda Offline
No, that is not a Stealth head.
Re: Is this a bare Stealth head? [Re: DrCharles] #2558168
10/03/18 11:29 AM
10/03/18 11:29 AM
West Plains, MO
West Plains, MO
Thanks. Any idea what it is? I would have said a Chinese copy but Stealths are already Chinese copies wink
Re: Is this a bare Stealth head? [Re: DrCharles] #2558174
10/03/18 11:39 AM
10/03/18 11:39 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I believe all stealth heads are factory looking on their ends. Not machined flat and polished.
Keep old mopars alive.
Re: Is this a bare Stealth head? [Re: DrCharles] #2558602
10/03/18 10:14 PM
10/03/18 10:14 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I have a set with PEP valves and comp springs and retainers. I did a quick bowl blend and had the shop cut the seats. 2 years no problems. Total cost $1100. Did the same with Source heads cost me $1400. They needed seat work and chamber work
Re: Is this a bare Stealth head? [Re: R/T1968R/T] #2558734
10/04/18 02:11 AM
10/04/18 02:11 AM
super stealths
Re: Is this a bare Stealth head? [Re: RapidRobert] #2559023
10/04/18 07:16 PM
10/04/18 07:16 PM
dogdays Offline
dogdays  Offline
If you spend time on your computer you can wade through all the engine parts being made in China and see that there are at least two companies making B heads.
https://www.alibaba.com/showroom/440-cylinder-heads.html
The Stealth head was developed by 440Source and it is not available from anyone else. The other heads have the slab ends. I believe the more expensive heads are what we know as Sidewinder heads or ProMaxx. The less expensive C. Haray heads are sold under many names and can be bought all the way from rough castings to finished and assembled.
These guys make everything! Cummins 6BT blocks, for example.
R.
Re: Is this a bare Stealth head? [Re: DrCharles] #2559062
10/04/18 08:55 PM
10/04/18 08:55 PM
West Plains, MO
West Plains, MO
Interesting! Thanks for the link.
Never heard of Chongqing Haray but I think you've identified the head I asked about.
It seems that no matter how expensive the head it still has to be checked 100% and probably some things repaired or resized. Even the high-dollar ones have been known to have water leaks, bad seats, etc.
So I'd just as soon buy bare heads cheap, and expect a shop to check/redo the valve seats & guides, do some mild porting, then put my valves, Comp springs and 10 degree locks on.
Re: Is this a bare Stealth head? [Re: DrCharles] #2563132
10/12/18 10:10 PM
10/12/18 10:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’ve done a few sets of Speedmaster BB heads.
They work fine when properly prepped.
We put a set with a Stage 1 type job on a 446 with an rpm intake, qft ss830 carb, Mancini rockers, .540 solid cam, decent rods and flat top pistons.
Re: Is this a bare Stealth head? [Re: DrCharles] #2563137
10/12/18 10:31 PM
10/12/18 10:31 PM
West Plains, MO
West Plains, MO
I just got the heads delivered today. They'll definitely need that step below the intake seat smoothed out.
Those dyno numbers look nice for that little .540 cam. Would you happen to have the flow sheet handy? smile
Re: Is this a bare Stealth head? [Re: DrCharles] #2563296
10/13/18 11:09 AM
10/13/18 11:09 AM
So. Burlington, Vt.
So. Burlington, Vt.
4.375” bore, 28” test pressure, radius plate on intake, no flow tube on exhaust:
Lift———in/ex
.100——70.4/59.6
.200—-145.6/108.5
.300—-211.2/146.4
.400—-255.0/178.1
.500—-280.5/203.0
.600—-287.9/219.6
.700—-284.9/228.6
