Over Center Spring....69 Bee... #2557977
10/02/18 10:18 PM
10/02/18 10:18 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
...is a effin pain to get out of there. LOL I hammered a couple screwdrivers in there good. I disconnected the rod to the z bar and let the pedal to the floor.
Almost had it a few times. haha I had to walk away for now. I was sweating my butt off and getting frustrated. Just felt like venting. I'll get it eventually.
Scott
1969 Super Bee, 383/4 speed
Re: Over Center Spring....69 Bee... [Re: StukaJU87] #2557987
10/02/18 10:26 PM
10/02/18 10:26 PM
Chicago
PurpleBeeper Offline
Chicago
Yep, it's a PIA. It's pretty wedged in there, but it will come out.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Over Center Spring....69 Bee... [Re: StukaJU87] #2558108
10/03/18 07:32 AM
10/03/18 07:32 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Wedge a bunch of thick washers/spacers between each turn of the coils by just stretching the spring using the pedal, just tape each washer in place as you do it, eventually the spring will fall off on it's own
Re: Over Center Spring....69 Bee... [Re: DAYCLONA] #2558237
10/03/18 01:49 PM
10/03/18 01:49 PM
moparx Offline
moparx  Offline
pretty much the only way to do it without getting the "springinthface" sensation, or too much aggravation.
beer
Re: Over Center Spring....69 Bee... [Re: StukaJU87] #2558247
10/03/18 02:10 PM
10/03/18 02:10 PM
central il.
second 70 Offline
second 70  Offline
central il.
If you have wood shims you can use the pedal to stretch the spring and put shims in open area. Then release pedal and spring will fall off. You can leave the spring like that in case you ever want to reinstall it. I think the shims due to their size are easier to use because you can get them tight and don't slip out as you're adding more.
Re: Over Center Spring....69 Bee... [Re: StukaJU87] #2558479
10/03/18 05:52 PM
10/03/18 05:52 PM
Northern NJ
Northern NJ
Thank you for the suggestions. I appreciate it.
Let me ask this, as silly as it sounds. At what point in the pedal travel are the coils spread MOST?
I assumed the spring would be stretched most with the pedal in the full up position.
Scott
Re: Over Center Spring....69 Bee... [Re: StukaJU87] #2558634
10/03/18 10:38 PM
10/03/18 10:38 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I’ve had them not spread the coils enough, at any point, to get shims in between.
I want my fair share
