727 Aluminum Drum #2557915
10/02/18 08:18 PM
10/02/18 08:18 PM
Ohio
O
Oldbracketracer Offline OP
O
Ohio
I am using an aluminum drum in my 727 equipped bracket car and I am unhappy with the fluid turning black so quickly since I put it in. I was thinking of having the band surface hard anodized to try to help this problem. Has anyone here tried anything like this? What was the result? Is there some other type of surface treatment or coating that might work? Need something normal humans can afford. Any experiences or ideas?
Re: 727 Aluminum Drum [Re: Oldbracketracer] #2558050
10/03/18 12:25 AM
10/03/18 12:25 AM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
We've been running the same A&A Aluminum drum for 10 years with A&A's Smooth Red Band and ATF Type IV. Trans fluid always comes out Red.
What kind of band are you running.
Re: 727 Aluminum Drum [Re: KD800X] #2558059
10/03/18 12:58 AM
10/03/18 12:58 AM
Ohio
O
O
Ohio
I am using a smooth red lined band, believe it came from Coan. Type f fluid. TCI transbrake, high 1.3 60 ft
Re: 727 Aluminum Drum [Re: Oldbracketracer] #2558106
10/03/18 07:20 AM
10/03/18 07:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Same here, smooth red Alto hard band. Drum and band looked like new at 350 pass inspection. How does yours look? How do the clutch fibers look?
Doug
Re: 727 Aluminum Drum [Re: Oldbracketracer] #2558224
10/03/18 01:24 PM
10/03/18 01:24 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
A little off topic but how often you do you folks with aluminum drums change fluid?
Re: 727 Aluminum Drum [Re: 340Cuda] #2558231
10/03/18 01:38 PM
10/03/18 01:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
100 passes.
Doug
Re: 727 Aluminum Drum [Re: dvw] #2558241
10/03/18 01:56 PM
10/03/18 01:56 PM
Ohio
O
O
Ohio
It's apart now at 200 runs for inspection, clutches look new, band looks almost new, drum shows slight wear on the surface where the band runs.
Re: 727 Aluminum Drum [Re: 340Cuda] #2558256
10/03/18 02:22 PM
10/03/18 02:22 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I haven't changed my fluid since I built the tranny in 2004. I don't put many passes each year now, but from 2004 to maybe 2012 it was 60-80 a year. Back in those days it had my 9 second engine in it. Not saying it is the wise thing to do but I feel that some people exaggerate aluminum drum maintenance.
Re: 727 Aluminum Drum [Re: B1MAXX] #2558463
10/03/18 05:43 PM
10/03/18 05:43 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
I had the Kevlar band and fluid was gray in 2 passes, switched to billet steel drum, also reaction times went to poop with gray fluid
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 727 Aluminum Drum [Re: Oldbracketracer] #2558560
10/03/18 08:52 PM
10/03/18 08:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Kevlar and aluminum drums don't mix. It'll chew it up.
Doug
Re: 727 Aluminum Drum [Re: dvw] #2558570
10/03/18 09:18 PM
10/03/18 09:18 PM
I wonder if the brand, age, material and heat treat, which alloy the drum is made of, with has some influence on the results? work
I've debated on buying a aluminum drum with a steel sleeve on it for the band to ride on over this same issue with the fluids work confused shruggy
Re: 727 Aluminum Drum [Re: Cab_Burge] #2558572
10/03/18 09:36 PM
10/03/18 09:36 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Currently using the aluminum full metal jacket drum in a street/strip app. No issues and clean fluid.
