Best buy/value in cast aluminum 727 trans pan? #2557050
10/01/18 02:44 PM
10/01/18 02:44 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I currently have the MP +1 qt plain steel pan w/ a billet filter extension and need to pull the pan & valve body. This would be a good time to upgrade the pan, if I'm going to do it.
What's the best buy / value in a cast aluminum 727 pan? I don't necessarily mean cheapest, since quality of the casting, hardware, etc., factor into this, too. Example: Which ones come w/ a nice matching filter extension, vs. something like the cheesy stamped-steel part I replaced w/ my MP pan?
Is there much benefit by stepping all the way up to a +4 qt model, or is the generic +2 qt sufficient? I always run synthetic ATF and have an external cooler, too.
Thanks - Brad
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557086
10/01/18 03:53 PM
10/01/18 03:53 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
We use the deep B&M cast pan, seals good and has a port for a temp. gauge.
Has the filter ext. and no scrapes in normal driving.
figured the extra fluid will never hurt....
Joe
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557135
10/01/18 05:24 PM
10/01/18 05:24 PM
AndyF Offline
AndyF  Offline
Put some bling under that car with the Moroso sheet metal pan. That is what I used on the Duster.
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557140
10/01/18 05:33 PM
10/01/18 05:33 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I used the Mopar Performance cast aluminum deep pan on my 518 (fits a 727 too) and it has a drain plug as well as the threaded bung for a temp sensor. Bought it off of a member year.
I think Summit sells a branded one just like it only significantly cheaper in price.
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557147
10/01/18 05:52 PM
10/01/18 05:52 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
No question the finned cast aluminum deep pan is the way to go. Better fluid cooling and a great way to stiffen up the case. I purchased a no name cast finned pan on Ebay for less than 100 bucks. up
Re: Best buy/value in cast aluminum 727 trans pan? [Re: ccdave] #2557151
10/01/18 05:55 PM
10/01/18 05:55 PM
an8sec70cuda Offline
iagree That's what my trans builder got for me. Looks just like the TCI piece, but has no name cast into it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557190
10/01/18 07:13 PM
10/01/18 07:13 PM
BradH Offline OP
BradH  Offline OP
At what point (extra capacity or additional depth below my +1 qt current steel pan) do people start having ground clearance issues? I was surprised by seeing more than a couple people complain about this while reading reviews of different brands/types of deep(er) pans.
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557226
10/01/18 08:28 PM
10/01/18 08:28 PM
AndyF Offline
AndyF  Offline
Is the pan the low spot on your car in that area now or is it the headers or transmission crossmember?
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557235
10/01/18 08:39 PM
10/01/18 08:39 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Brad I am with Andy on the Moroso sheet metal pan it is light, good pan rail,and nice quality. Be aware that some of the cast pans would be lighter if they were made of lead and just stupid heavy for what they do.
"Just a Bracket car dressed up like a streetcar"
Re: Best buy/value in cast aluminum 727 trans pan? [Re: jlatessa] #2557257
10/01/18 09:33 PM
10/01/18 09:33 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Joe
same here nice piece for the money. up
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557266
10/01/18 09:48 PM
10/01/18 09:48 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I bought one of these and love it. Great quality, and very rigid.
https://www.lpwracing.com/Trans_Pans/Deep_Transmission_Pans.html
Wasn't too expensive either.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557270
10/01/18 10:03 PM
10/01/18 10:03 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I use the B&M pan also. Nice piece for the money and seems to help keep my 727 cool. I’m pretty sure I added weight to the car though.... aluminum? Yes. Lighter than stock steel pan? NO!
Re: Best buy/value in cast aluminum 727 trans pan? [Re: MarkZ] #2557307
10/01/18 11:02 PM
10/01/18 11:02 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
I use the Summit cast pan. I like the idea of stiffening the case with a cast pan. Note that the fasteners which come with it are a little odd. If I remember correctly you need a 12 pt metric socket (10mm?).
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557388
10/02/18 02:03 AM
10/02/18 02:03 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Old 47RE on my 727. 42RE pan n my 904. Light and seals like a champ with the Mopar factory gasket torqued at 125”lb. those thick heavy pans do not dissipate heat well. The Moroso pan would be my “go-to” for aluminum.
Re: Best buy/value in cast aluminum 727 trans pan? [Re: J_BODY] #2557446
10/02/18 09:08 AM
10/02/18 09:08 AM
BradH Offline OP
BradH  Offline OP
I'm considering the Moroso, but know of one that leaked due to a flaw in the welding. I would hope that is an unlikely problem to run into.
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557474
10/02/18 10:35 AM
10/02/18 10:35 AM
Never had a problem w/ the trans pan hitting the ground. Oil pan and headers, yes.
CHIP
Re: Best buy/value in cast aluminum 727 trans pan? [Re: an8sec70cuda] #2557568
10/02/18 11:57 AM
10/02/18 11:57 AM
BradH Offline OP
BradH  Offline OP
Unfortunately, I don't have any pics from before the last tear-down that shows how close things were then.
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557579
10/02/18 12:07 PM
10/02/18 12:07 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Junk yard stock 518 pan with A&A filter extension. And the good Mopar pan gasket 2464 324AC. All in for $60 or so.
Master, again and still
Re: Best buy/value in cast aluminum 727 trans pan? [Re: BradH] #2557690
10/02/18 02:52 PM
10/02/18 02:52 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I just used a summit brand finned aluminum pan. It fit great, looks great, +2 quarts, and was only $150
Re: Best buy/value in cast aluminum 727 trans pan? [Re: radar] #2557700
10/02/18 03:01 PM
10/02/18 03:01 PM
BradH Offline OP
BradH  Offline OP
Yeah, I was looking at the cast Summit no-logo pan, too. Basically, it's $150 + a good gasket for that one, or $220 + a good gasket for the fabricated Moroso pan.
I appreciate people's feedback. Thanks - Brad
