440 Build
#2557368
10/02/18 01:19 AM
10/02/18 01:19 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
I have a plan for my engine build (I already have a full car build post that I'll be updating as I learn new things): 440, .030 over, zero-decked JE SRP flat top pistons, -6cc, 10.1 compression Performer RPM Heads, 84 cc Performer 440 intake Holley vac sec. carb (750-850) Lunati 10230703 (old part #60303), Harland Sharp Rocker Arms, 1.5 ratio, KE version for Performer RPM heads Hedman 78038 headers, 1 3/4" ARP Wave Loc Rod Bolts Pushrods after the length is measured (lunati or comp cams probably) I was also just wondering if this build looks like it could make 500+ hp, I got alot of the ideas from a couple articles, one had 537+ HP, I can't find the other. Would this build be around that power level (just estimates obviously you can't know specifics)?
Re: 440 Build
[Re: 70charger512]
#2557401
10/02/18 02:45 AM
10/02/18 02:45 AM
RapidRobert
I ain't a cam guy but it does sound like a "reasonable" combo. I wouldn't think 500 HP tho. On a side note that intake is VG but it is very tall. Here's a BTT for ya.
Re: 440 Build
[Re: 70charger512]
#2557417
10/02/18 04:15 AM
10/02/18 04:15 AM
Posts: 43,251 Bend,OR USA
Cab_Burge
Can you post the cam specs for the duration at .050 lobe lift, total lobe lift and the lobe separation angle also If you don't have the headers yet I would go bigger, the key to making HP mopar B and Rb motors is to get the air and fuel in and out, no restrictions on either side Buy a 850 CFM carb also
Re: 440 Build
[Re: 70charger512]
#2557463
10/02/18 10:25 AM
10/02/18 10:25 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Just my opinion, but the cam is on the small side. Do you mean the Performer RPM intake? Or the Performer? BIGGG difference in performance there. The Performer RPM is a great manifold, but like RapidRobert said...it is pretty tall and has hood clearance issues w/ stock hoods. Also not a fan of vac. sec. carbs. I'd use a double pumper.
It depends on what you are looking for though. Are you gonna take it to the drag strip? Aiming for a particular ET range? Just street driving and burning up tires?
Re: 440 Build
[Re: Cab_Burge]
#2557728
10/02/18 04:06 PM
10/02/18 04:06 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Can you post the cam specs for the duration at .050 lobe lift, total lobe lift and the lobe separation angle also If you don't have the headers yet I would go bigger, the key to making HP mopar B and Rb motors is to get the air and fuel in and out, no restrictions on either side Buy a 850 CFM carb also Lift is .494/.513 Duration at .050 is 226/234 Adv Duration is 268/276 I have been considering bigger headers, however they would have clearance issues, especially with these heads.
Re: 440 Build
[Re: an8sec70cuda]
#2557737
10/02/18 04:17 PM
10/02/18 04:17 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
It depends on what you are looking for though. Are you gonna take it to the drag strip? Aiming for a particular ET range? Just street driving and burning up tires? I've seen plenty of articles on Performer vs Performer RPM, every result show that they're extremely similar, barely even a difference. My car came with the Performer so I figure I might as well keep it. It hasn't caused me any problems. I'm going with a vac. sec. because it is a daily driver. But of course I plan on bringing it to the strip, what else would be the point of more power?
Re: 440 Build
[Re: FurryStump]
#2557739
10/02/18 04:20 PM
10/02/18 04:20 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
They only thing I could add was I would go with Smith Bros. pushrods. Thanks (I haven't decided on the brand), do you think this would be above 500?
Re: 440 Build
[Re: 70charger512]
#2557747
10/02/18 04:33 PM
10/02/18 04:33 PM
an8sec70cuda
It depends on what you are looking for though. Are you gonna take it to the drag strip? Aiming for a particular ET range? Just street driving and burning up tires? I've seen plenty of articles on Performer vs Performer RPM, every result show that they're extremely similar, barely even a difference. My car came with the Performer so I figure I might as well keep it. It hasn't caused me any problems. I'm going with a vac. sec. because it is a daily driver. But of course I plan on bringing it to the strip, what else would be the point of more power? I'd like to see these articles you're referring to. The Performer is basically an aluminum version of the stock intake w/ slightly larger runners in some cases. Not much difference. The Performer RPM is MUCH different and better. The Edelbrock Performer RPM and the Holley Street Dominator are nearly identical power-wise...maybe that's what you're thinking of since they have been used in several intake tests. Smith Brothers or Manton would be a much better source for pushrods. Nothing wrong w/ daily driving a double pumper carb.
Re: 440 Build
[Re: an8sec70cuda]
#2557797
10/02/18 05:31 PM
10/02/18 05:31 PM
dogdays
https://www.edelbrock.com/performer-rpm-top-end-kit-for-b-b-chrysler-2087.htmlSomething like yours made 482hp and 528 lb-ft of torque. I would suggest forgetting your stock connecting rods and replacing them with Molnar or SCAT or Eagle or K1 or 440Source rods with 7/16" bolts (they all have 7/16 bolts rather than stock 3/8). The cost difference between rebuilding your stock rods with new bolts and just replacing the rods is small enough. One thing about doing that, the rods are all 6.760 not 6.768 which the stockers are supposed to be. You may be able to get the pin height in the pistons modified to get a zero deck. Some piston manufacturers will do one or two changes for very little cost. Because any piston you decide upon will be lighter than the boat anchor stock pistons and pins, the rotating assembly will have to be balanced anyway. May as well save a few more grams and get a stronger rod in the bargain, plus one without millions of tension-compression cycles already on it. Regarding camshaft, if your heads flow well you don't need to crutch them with a huge camshaft. What you've planned is big enough. I think you're going to need an 850 or so carb to maximize power output. R.
Re: 440 Build
[Re: 70charger512]
#2558026
10/02/18 11:37 PM
10/02/18 11:37 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Good luck. Your getting responses all over the map.
Here is one more guy's opinion;
1) Assume 475 HP motor, an RPM is going to be a little better than a regular Performer. Go with what you have now, but reevaluate when you have it all sorted out. If you like to experiment, a little intake divider work and spacer will get the std performer close to an RPM at your power level, IMO.
2) for headers, low elevens are a walk in the park with 1 3/4" headers. Are 1 7/8 better, maybe, but not much, and are certainly not your limiting factor. Go with the 1 3/4" if you want, knowing that you might be giving up a few peak HP numbers.
3) Cam choice seems reasonable.
Just one more guys opinion.
Re: 440 Build
[Re: 70charger512]
#2558038
10/02/18 11:50 PM
10/02/18 11:50 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
I’d call Dwayne porter and have him set the heads up and probably some mild porting. He’s fast68plymouth here on the board. Porter Racing Heads.
He can go over your cam choice and make sure you have the right springs on there, the machining on the heads is correct, etc.
I like the Hooker Super Comps myself. Whatever you go with, spend the few hundred extra and get the jet hot coating. You can get hedmans coated if you are dead set on those. Coated headers are way worth it.
Nothing wrong with using the intake you have since it’s gravy to change on a mopar. The RPM is a sweet piece though and will outdo what you have. Be mindful of the trans kick down no matter what you do or you’ll be right back asking what went wrong.
Getting those details right along with the right cam and you should be in the ballpark for your power goal.
I want my fair share
