78 motorhome 440. info needed
#2556344
09/29/18 06:46 PM
09/29/18 06:46 PM
RapidRobert
Got a line on one for reasonable $$$. Any caveats to lookout for on the eng? Not sure on the year, might be 80's. has thermoquad/ecu. Thank you for your time.
Re: 78 motorhome 440. info needed
[Re: RapidRobert]
#2556352
09/29/18 07:07 PM
09/29/18 07:07 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Typically they are low mileage and haven’t been rebuilt. Some had forged cranks. Many had HD rods. People will blow smoke about thin-walled cylinders, less ribbing, more or less nickel in he casting. Blow it all off. The only drawback is that it will be low compression. So they need a performance rebuild. No biggy. They are great rebuilders. Keep the block, crank and heads and toss the rest.
I’m listening.
[Re: Big Bad Bee]
#2556401
09/29/18 09:11 PM
09/29/18 09:11 PM
Posts: 4,695 Wichita
GY3
Wichita
'78 was the last year.
They make great engines, even with low compression.
People poo poo the cast cranks, but they are good for at least 600 hp.
Get the transmisson too. Sometimes they have a brake on the tailshaft, but the internals have 4 pinion planetaries and the front cases are the same as found in cars.
[Re: RapidRobert]
#2556408
09/29/18 09:30 PM
09/29/18 09:30 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Should have the 452 motorhome version head with the steam ports on the exhaust valves. Toss the heavy rods and low compression pistons. The later blocks aren't thin walled and actually have more ribbing than the earlier ones.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2556451
09/29/18 11:31 PM
09/29/18 11:31 PM
RapidRobert
Yeah I get the whole thing & its as big as a bus, 71K miles he said. thanks guys!
[Re: RapidRobert]
#2556479
09/30/18 12:34 AM
09/30/18 12:34 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Theres a decent chance the heads ar cracked.
Have a great day Iowan
"obsolete is neat"
[Re: GY3]
#2556480
09/30/18 12:35 AM
09/30/18 12:35 AM
Posts: 101 S.E. WI
RichL1967
S.E. WI
Get the transmisson too. Sometimes they have a brake on the tailshaft, but the internals have 4 pinion planetaries and the front cases are the same as found in cars. I have this same thing from a 73. After you build up the motor, anything special you would want to do to the transmission?
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
[Re: RichL1967]
#2556588
09/30/18 12:24 PM
09/30/18 12:24 PM
RapidRobert
After you build up the motor, anything special you would want to do to the transmission? the potential head cracks is bothersome. I was thinking of putting it in my 65D100 pickup for a daily driver. The guy is supposedly being kicked out of his storage (parents spacious acreage...) $350 ain't bad tho. If someone pulled the eng out for me they could have that trans. On second thought I may have to pass, as I just have way too many unfinished projexts as is but 440 grabbed my attention.
[Re: RichL1967]
#2558433
10/03/18 05:21 PM
10/03/18 05:21 PM
GY3
Wichita
Get the transmisson too. Sometimes they have a brake on the tailshaft, but the internals have 4 pinion planetaries and the front cases are the same as found in cars. I have this same thing from a 73. After you build up the motor, anything special you would want to do to the transmission? It is old enough that the seals and clutches need to be replaced. The rubber seals harden and quit working properly and the clutches start to flake off. A rebuild kit is under $150 from Transtar. Do a Trans-go shift kit to eliminate overlap while you are in there.
[Re: elmor353]
#2558507
10/03/18 06:22 PM
10/03/18 06:22 PM
GY3
Wichita
78 may be the last production year for big blocks, but they were used through the early 80's in motorhomes. I have a friend with an 81 motorhome and he told me it had a 440. I argued that it couldn't be because of the manufacture date of the unit, but sure enough, it is a factory 440 in a 1981. A Chrysler parts manager said that the motorhome companies bought truck chassis in bulk and had them sitting on their lots to build. Therefore many motorhomes were built in the 80's using older truck chassis and engines and titled them in whatever year the motorhome was built. So, if the op says he has an 80's motorhome with a 440, he has an 80's motorhome with a 440. Yes, but the engine itself will be '78 or earlier casting.
